3#include <CesiumUtility/Result.h>
Supports conversion of subtrees between 3D Tiles 1.1 and 3D Tiles 2.0 (glTF 2.1).
static CesiumTilesetJson::Availability convertAvailability(CesiumGltf::Availability &&availability)
Converts a CesiumGltf::Availability to a CesiumTilesetJson::Availability.
static CesiumGltf::Availability convertAvailability(CesiumTilesetJson::Availability &&availability)
Converts a CesiumTilesetJson::Availability to a CesiumGltf::Availability.
static CesiumUtility::Result< CesiumGltf::Buffer > convertBuffer(CesiumTilesetJson::Buffer &&buffer)
Converts a CesiumTilesetJson::Buffer used for subtrees to a CesiumGltf::Buffer.
static CesiumUtility::Result< CesiumGltf::BufferView > convertBufferView(CesiumTilesetJson::BufferView &&bufferView)
Converts a CesiumTilesetJson::BufferView used for subtrees to a CesiumGltf::BufferView.
static CesiumUtility::Result< CesiumTilesetJson::BufferView > convertBufferView(CesiumGltf::BufferView &&bufferView)
Converts a CesiumGltf::BufferView to a CesiumTilesetJson::BufferView used for subtrees.
static CesiumUtility::Result< CesiumGltf::Model > convertToGltfModel(CesiumTilesetJson::Subtree &&subtree)
Converts a CesiumTilesetJson::Subtree to an equivalent CesiumGltf::Model with the CesiumGltf::Extensi...
static CesiumUtility::Result< CesiumTilesetJson::Buffer > convertBuffer(CesiumGltf::Buffer &&buffer)
Converts a CesiumGltf::Buffer to a CesiumTilesetJson::Buffer used for subtrees.
static CesiumUtility::Result< CesiumTilesetJson::Subtree > convertToTilesetJsonSubtree(CesiumGltf::Model &&model)
Converts a CesiumGltf::Model with the CesiumGltf::Extension3dTilesSubtree extension to an equivalent ...
Classes that represent or enable fundamental elements of 3D Tiles.
An object describing the availability of a set of elements.
A view into a buffer generally representing a subset of the buffer.
A contiguous subset of a buffer.
An object describing the availability of tiles and content in a subtree, as well as availability of c...
Holds the result of an operation. If the operation succeeds, it will provide a value....
