CesiumTilesetJson::Availability Struct Referencefinal
An object describing the availability of a set of elements. More...
#include <CesiumTilesetJson/Availability.h>
Inheritance diagram for CesiumTilesetJson::Availability:
Classes
struct  Constant
 Known values for Integer indicating whether all of the elements are available (1) or all are unavailable (0). More...
std::optional< int64_t > bitstream
 Index of a buffer view that indicates whether each element is available. The bitstream conforms to the boolean array encoding described in the 3D Metadata specification. If an element is available, its bit is 1, and if it is unavailable, its bit is 0.
std::optional< int64_t > availableCount
 A number indicating how many 1 bits exist in the availability bitstream.
std::optional< int32_t > constant
static constexpr const char * TypeName = "Availability"
Definition at line 15 of file Availability.h.
int64_t CesiumTilesetJson::Availability::getSizeBytes ( ) const
Definition at line 63 of file Availability.h.
◆ availableCount
std::optional<int64_t> CesiumTilesetJson::Availability::availableCount
Definition at line 46 of file Availability.h.
◆ bitstream
std::optional<int64_t> CesiumTilesetJson::Availability::bitstream
Definition at line 40 of file Availability.h.
◆ constant
std::optional<int32_t> CesiumTilesetJson::Availability::constant
Known values are defined in Constant.
Definition at line 55 of file Availability.h.
const char* CesiumTilesetJson::Availability::TypeName = "Availability"
Definition at line 20 of file Availability.h.
