CesiumTilesetJson::Subtree Struct Referencefinal
An object describing the availability of tiles and content in a subtree, as well as availability of children subtrees. May also store metadata for available tiles and content. More...
#include <CesiumTilesetJson/Subtree.h>
Inheritance diagram for CesiumTilesetJson::Subtree:
std::vector< CesiumTilesetJson::Buffer > buffers
 An array of buffers.
std::vector< CesiumTilesetJson::BufferView > bufferViews
 An array of buffer views.
std::vector< CesiumTilesetJson::PropertyTable > propertyTables
 An array of property tables.
CesiumTilesetJson::Availability tileAvailability
 The availability of tiles in the subtree. The availability bitstream is a 1D boolean array where tiles are ordered by their level in the subtree and Morton index within that level. A tile's availability is determined by a single bit, 1 meaning a tile exists at that spatial index, and 0 meaning it does not. The number of elements in the array is (N^subtreeLevels - 1)/(N - 1) where N is 4 for subdivision scheme QUADTREE and 8 for OCTREE. Availability may be stored in a buffer view or as a constant value that applies to all tiles. If a non-root tile's availability is 1 its parent tile's availability shall also be 1. tileAvailability.constant: 0 is disallowed, as subtrees shall have at least one tile.
std::vector< CesiumTilesetJson::Availability > contentAvailability
 An array of content availability objects. If the tile has a single content this array will have one element; if the tile has multiple contents.
CesiumTilesetJson::Availability childSubtreeAvailability
 The availability of children subtrees. The availability bitstream is a 1D boolean array where subtrees are ordered by their Morton index in the level of the tree immediately below the bottom row of the subtree. A child subtree's availability is determined by a single bit, 1 meaning a subtree exists at that spatial index, and 0 meaning it does not. The number of elements in the array is N^subtreeLevels where N is 4 for subdivision scheme QUADTREE and 8 for OCTREE. Availability may be stored in a buffer view or as a constant value that applies to all child subtrees. If availability is 0 for all child subtrees, then the tileset does not subdivide further.
std::optional< int64_t > tileMetadata
 Index of the property table containing tile metadata. Tile metadata only exists for available tiles and is tightly packed by increasing tile index. To access individual tile metadata, implementations may create a mapping from tile indices to tile metadata indices.
std::vector< int64_t > contentMetadata
 An array of indexes to property tables containing content metadata. If the tile has a single content this array will have one element; if the tile has multiple contents - as supported by 3DTILES_multiple_contents and 3D Tiles 1.1 - this array will have multiple elements. Content metadata only exists for available contents and is tightly packed by increasing tile index. To access individual content metadata, implementations may create a mapping from tile indices to content metadata indices.
std::optional< CesiumTilesetJson::MetadataEntity > subtreeMetadata
 Subtree metadata encoded in JSON.
static constexpr const char * TypeName = "Subtree"
Definition at line 23 of file Subtree.h.
int64_t CesiumTilesetJson::Subtree::getSizeBytes ( ) const
Definition at line 111 of file Subtree.h.
◆ buffers
std::vector<CesiumTilesetJson::Buffer> CesiumTilesetJson::Subtree::buffers
Definition at line 33 of file Subtree.h.
◆ bufferViews
std::vector<CesiumTilesetJson::BufferView> CesiumTilesetJson::Subtree::bufferViews
Definition at line 38 of file Subtree.h.
◆ childSubtreeAvailability
CesiumTilesetJson::Availability CesiumTilesetJson::Subtree::childSubtreeAvailability
Definition at line 79 of file Subtree.h.
◆ contentAvailability
std::vector<CesiumTilesetJson::Availability> CesiumTilesetJson::Subtree::contentAvailability
  • as supported by 3DTILES_multiple_contents and 3D Tiles 1.1 - this array will have multiple elements.
Definition at line 65 of file Subtree.h.
◆ contentMetadata
std::vector<int64_t> CesiumTilesetJson::Subtree::contentMetadata
Definition at line 98 of file Subtree.h.
◆ propertyTables
std::vector<CesiumTilesetJson::PropertyTable> CesiumTilesetJson::Subtree::propertyTables
Definition at line 43 of file Subtree.h.
◆ subtreeMetadata
std::optional<CesiumTilesetJson::MetadataEntity> CesiumTilesetJson::Subtree::subtreeMetadata
Definition at line 103 of file Subtree.h.
◆ tileAvailability
CesiumTilesetJson::Availability CesiumTilesetJson::Subtree::tileAvailability
Definition at line 57 of file Subtree.h.
◆ tileMetadata
std::optional<int64_t> CesiumTilesetJson::Subtree::tileMetadata
Definition at line 87 of file Subtree.h.
const char* CesiumTilesetJson::Subtree::TypeName = "Subtree"
Definition at line 28 of file Subtree.h.
