3#include <Cesium3DTiles/Library.h>
4#include <CesiumGeometry/BoundingCylinderRegion.h>
5#include <CesiumGeometry/BoundingSphere.h>
6#include <CesiumGeometry/OrientedBoundingBox.h>
7#include <CesiumGeospatial/BoundingRegion.h>
8#include <CesiumGeospatial/BoundingRegionWithLooseFittingHeights.h>
9#include <CesiumGeospatial/Ellipsoid.h>
10#include <CesiumGeospatial/GlobeRectangle.h>
11#include <CesiumGeospatial/S2CellBoundingVolume.h>
12#include <CesiumUtility/Result.h>
98 const glm::dmat4x4& transform,
107CESIUM3DTILES_API glm::dvec3
118CESIUM3DTILES_API std::optional<CesiumGeospatial::GlobeRectangle>
151CESIUM3DTILES_API
bool
A bounding volume defined as a region following the surface of a cylinder between two radius values....
A bounding sphere with a center and a radius.
A bounding volume defined as a closed and convex cuboid with any orientation.
A BoundingRegion whose heights might be very inaccurate and so distances should be estimated conserva...
A bounding volume specified as a longitude/latitude bounding box and a minimum and maximum height.
Classes that represent or enable fundamental elements of 3D Tiles.
const CesiumGeospatial::BoundingRegion * getBoundingRegionFromBoundingVolume(const BoundingVolume &boundingVolume)
Returns the bounding region if the bounding volume is a CesiumGeospatial::BoundingRegion or a CesiumG...
CesiumUtility::Result< BoundingVolume > getBoundingVolume(const CesiumTilesetJson::BoundingVolume &boundingVolume, const CesiumGeospatial::Ellipsoid &ellipsoid=CesiumGeospatial::Ellipsoid::WGS84)
Creates a Cesium3DTiles::BoundingVolume from a CesiumTilesetJson::BoundingVolume, if possible.
bool testIntersection(const BoundingVolume &volume0, const BoundingVolume &volume1)
Returns true if two bounding volumes intersect.
std::variant< CesiumGeometry::BoundingSphere, CesiumGeometry::OrientedBoundingBox, CesiumGeospatial::BoundingRegion, CesiumGeospatial::BoundingRegionWithLooseFittingHeights, CesiumGeospatial::S2CellBoundingVolume, CesiumGeometry::BoundingCylinderRegion > BoundingVolume
A bounding volume.
std::optional< CesiumGeospatial::GlobeRectangle > estimateGlobeRectangle(const BoundingVolume &boundingVolume, const CesiumGeospatial::Ellipsoid &ellipsoid=CesiumGeospatial::Ellipsoid::WGS84)
Estimates the bounding CesiumGeospatial::GlobeRectangle of the given BoundingVolume.
glm::dvec3 getBoundingVolumeCenter(const BoundingVolume &boundingVolume)
Returns the center of the given BoundingVolume.
BoundingVolume transformBoundingVolume(const glm::dmat4x4 &transform, const BoundingVolume &boundingVolume)
Transform the given BoundingVolume with the given matrix.
CesiumGeometry::OrientedBoundingBox getOrientedBoundingBoxFromBoundingVolume(const BoundingVolume &boundingVolume, const CesiumGeospatial::Ellipsoid &ellipsoid=CesiumGeospatial::Ellipsoid::WGS84)
Returns an oriented bounding box that contains the given BoundingVolume.
A bounding volume that encloses a tile or its content. At least one bounding volume property is requi...
Holds the result of an operation. If the operation succeeds, it will provide a value....
