CesiumGltf::Availability Struct Referencefinal
An object describing the availability of a set of elements. More...
#include <CesiumGltf/Availability.h>
Inheritance diagram for CesiumGltf::Availability:
Classes
struct  Constant
 Known values for Integer indicating whether all of the elements are available (1) or all are unavailable (0). More...
int32_t bitstream = -1
 Index of a buffer view that contains availability bits. If an element is available, its bit is 1, and if it is unavailable, its bit is 0.
std::optional< int64_t > availableCount
 A number indicating how many 1 bits exist in the availability bitstream.
std::optional< int32_t > constant
static constexpr const char * TypeName = "Availability"
Definition at line 15 of file Availability.h.
int64_t CesiumGltf::Availability::getSizeBytes ( ) const
Definition at line 61 of file Availability.h.
◆ availableCount
std::optional<int64_t> CesiumGltf::Availability::availableCount
Definition at line 44 of file Availability.h.
◆ bitstream
int32_t CesiumGltf::Availability::bitstream = -1
Definition at line 38 of file Availability.h.
◆ constant
std::optional<int32_t> CesiumGltf::Availability::constant
Known values are defined in Constant.
Definition at line 53 of file Availability.h.
const char* CesiumGltf::Availability::TypeName = "Availability"
Definition at line 20 of file Availability.h.
