BufferView.h
6#include <CesiumGltf/NamedObject.h>
8#include <cstdint>
9#include <optional>
10
11namespace CesiumGltf {
15struct CESIUMGLTF_API BufferView final : public CesiumGltf::NamedObject {
19 static constexpr const char* TypeName = "BufferView";
20
25 struct Target {
27 static constexpr int32_t ARRAY_BUFFER = 34962;
28
30 static constexpr int32_t ELEMENT_ARRAY_BUFFER = 34963;
31 };
32
36 int32_t buffer = -1;
37
41 int64_t byteOffset = 0;
42
46 int64_t byteLength = int64_t();
47
55 std::optional<int64_t> byteStride;
56
64 std::optional<int32_t> target;
65
72 int64_t getSizeBytes() const {
73 int64_t accum = 0;
74 accum += int64_t(sizeof(BufferView));
76 int64_t(sizeof(CesiumGltf::NamedObject));
77
78 return accum;
79 }
80};
81} // namespace CesiumGltf
Known values for The hint representing the intended GPU buffer type to use with this buffer view.
Definition BufferView.h:25
ELEMENT_ARRAY_BUFFER (34963)
Definition BufferView.h:30
ARRAY_BUFFER (34962)
Definition BufferView.h:27
A view into a buffer generally representing a subset of the buffer.
Definition BufferView.h:15
int64_t byteLength
The length of the bufferView in bytes.
Definition BufferView.h:46
Definition BufferView.h:19
Definition BufferView.h:72
int32_t buffer
The index of the buffer.
Definition BufferView.h:36
std::optional< int64_t > byteStride
The stride, in bytes.
Definition BufferView.h:55
std::optional< int32_t > target
Definition BufferView.h:64
int64_t byteOffset
The offset into the buffer in bytes.
Definition BufferView.h:41
Definition NamedObject.h:14
Definition NamedObject.h:28
