CesiumTilesetJson::BufferView Struct Referencefinal
A contiguous subset of a buffer. More...
#include <CesiumTilesetJson/BufferView.h>
Inheritance diagram for CesiumTilesetJson::BufferView:
int64_t buffer = int64_t()
 The index of the buffer.
int64_t byteOffset = int64_t()
 The offset into the buffer in bytes.
int64_t byteLength = int64_t()
 The total byte length of the buffer view.
 The name of the bufferView.
static constexpr const char * TypeName = "BufferView"
Definition at line 16 of file BufferView.h.
int64_t CesiumTilesetJson::BufferView::getSizeBytes ( ) const
Definition at line 49 of file BufferView.h.
◆ buffer
int64_t CesiumTilesetJson::BufferView::buffer = int64_t()
Definition at line 26 of file BufferView.h.
◆ byteLength
int64_t CesiumTilesetJson::BufferView::byteLength = int64_t()
Definition at line 36 of file BufferView.h.
◆ byteOffset
int64_t CesiumTilesetJson::BufferView::byteOffset = int64_t()
Definition at line 31 of file BufferView.h.
◆ name
std::optional<std::string> CesiumTilesetJson::BufferView::name
Definition at line 41 of file BufferView.h.
const char* CesiumTilesetJson::BufferView::TypeName = "BufferView"
Definition at line 21 of file BufferView.h.
