cesium-native 0.67.0
This class is not meant to be instantiated directly. Use Buffer instead. More...
#include <CesiumTilesetJson/Buffer.h>
| BufferCesium | cesium |
| Holds properties that are specific to the 3D Tiles loader rather than part of the 3D Tiles spec. | |
Public Attributes inherited from CesiumTilesetJson::BufferSpec | |
| std::optional< std::string > | uri |
The URI (or IRI) of the file that contains the binary buffer data. Relative paths are relative to the file containing the buffer JSON. uri is required when using the JSON subtree format and not required when using the binary subtree format - when omitted the buffer refers to the binary chunk of the subtree file. Data URIs are not allowed. | |
| int64_t | byteLength = int64_t() |
| The length of the buffer in bytes. | |
| The name of the buffer. | |
Public Member Functions inherited from CesiumTilesetJson::BufferSpec | |
Static Public Attributes inherited from CesiumTilesetJson::BufferSpec | |
| static constexpr const char * | TypeName = "Buffer" |
Protected Member Functions inherited from CesiumTilesetJson::BufferSpec | |
| BufferSpec ()=default | |
| This class is not meant to be instantiated directly. Use Buffer instead. | |
| BufferCesium CesiumTilesetJson::Buffer::cesium |
