Cesium Releases in November 2024
In October, we discussed our collaborations with Esri, highlighted AERO AI’s work on reintegrating WebODM with Cesium ion, shared progress on the Cesium Revit Add-In, introduced Japan Regional Terrain and updates to Japan 3D Buildings, dove into how to become a Cesium Certified Developer in Japanese, and explained key updates to glTF rendering in CesiumJS.
CesiumJS 1.123 Release
CesiumJS 1.123 is now available. Highlights of the release include:
- Updated default 3D Tiles and Model lighting when using PBR in order to create a more realistic appearance. #12129
- Added
ScreenSpaceCameraController.maximumTiltAngleto limit how much the camera can tilt. #12169 by new contributor albek446 - Updated Japan Buildings sandcastle to use Japan Regional Terrain. #12259
- Moved
Viewerfunctionality toCesiumWidgetto increase usability. Makes theCesiumWidgetcloser to a drop in replacement for theViewerwhen not utilizing the extraViewerwidgets. #11967. - Fixed flickering issue caused by bounding sphere retrieval being blocked by the bounding sphere of another entity. #12230
Updates to default 3D Tiles and Model lighting when using PBR create a more realistic appearance.
Cesium for Unreal 2.10.0 Release
Cesium for Unreal v2.10.0 is now available. Highlights of the release include:
- Added a shared assets system that ensures external images referenced by different glTFs will only be loaded once per image. Previously, these images would be loaded again for each glTF that referenced them. This significantly reduces memory usage for tilesets that reuse the same textures.
- Added
CircumscribedGroundHeightproperty toCesiumSunSky. It defaults to 0, which is consistent with the previous behavior. It can be set to a larger value (like 40) to avoid dark splotchy artifacts when zoomed out far from the globe in certain tilesets where geometry extends very far beyond the ellipsoid in the low-detail representation, such as Google Photorealistic 3D Tiles. - Fixed a bug that caused incorrect lighting for tilesets using
KHR_materials_unlit. - Reduced the memory used by tiles with
KHR_materials_unlit. CesiumGlobeAnchorproperties are no longer shown on the mainCesiumSunSkyDetails panel, because it is almost never necessary to set these. They can still be set on the component's own Details panel if needed.- Fixed error messages in the Unreal log about uninitialized fields in
FCesiumSampleHeightResult.
Google Photorealistic 3D Tiles captured from an outer space view, after improvements to its generated normals and surrounding atmosphere.
Cesium for Unity 1.13.1 Release
Cesium for Unity v1.13.1 is now available. Highlights of this release include:
- Added restrictions to
CesiumRuntime.asmdefto prevent the plugin from attempting to load on platforms not supported by Cesium Native.
Cesium for Omniverse 0.24.0 Release
Cesium for Omniverse v0.24.0 is now available. Highlights of this release include:
- Fixed bug where smooth normals setting would crash.
Cesium ion Updates
Cesium ion SaaS
- Japan Regional Terrain is now available in the Cesium ion Asset Depot. Details are in this blog post.
- Japan 3D Buildings includes updated building heights and additional bridge features.
- Available soon: adding annotations to Cesium Stories. Look for an announcement on the community forum and let us know what you think!
Asset Server
An improved Asset Server is now available.
The Asset Server allows users to serve Cesium data like Cesium World Terrain, their own data, and other data in environments where Cesium ion Self-Hosted is not deployed. It’s included in subscriptions for Cesium ion Self-Hosted and data like Cesium World Terrain. If you license Cesium content and received an Asset Server from Cesium before September 2024, we recommend upgrading to this newer server. The Asset Server is available on the Downloads page now for current Cesium ion Self-Hosted users; it will soon be downloadable by users with a subscription to Cesium data. If you’d like to access it sooner, please contact your account team.
Improvements include:
- Caching for improved performance
- A smaller binary
- Support for geopackage
- Auto detection of file types
- File watchers that update the content and cache as source files change
Powered by Cesium
“Reentry” blends a game with a simulator, so users learn to operate spacecraft with realistic procedures and, soon, Cesium Moon Terrain. Within a few hours of hearing about Cesium Moon Terrain, creator Petri Wilhelmsen began incorporating it into Reentry via Cesium ion and Cesium for Unity. Wilhelmsen reports it took only 30 minutes to replace his lower fidelity Moon with Cesium Moon Terrain.
The Lunar Module preparing for descent and landing on the lunar surface. Courtesy Petri Wilhelmsen.
