Cesium Releases in July 2024
In June, we released the Japan 3D Buildings tileset in Cesium ion, passed the 10 million mark for total lifetime downloads of CesiumJS, announced a new set of Cesium Ecosystem Grant recipients, and shared that Vexcel 3D Cities are now available via Cesium ion Self-Hosted. At the end of July, we’ll be in Denver for SIGGRAPH 2024—let us know if you’ll be there!
CesiumJS 1.119 Release
CesiumJS 1.119 is now available. Highlights of the release include:
- Added
Ellipsoid.defaultto allow a central place to specify a default ellipsoid value to be used throughout the API where an ellipsoid is not otherwise specified. #4245 - Various defaults have been updated to adjust when
Ellipsoid.defaultis changed to a value other than the WGS84 ellipsoid. - Fixed diffuse color calculation for PBR materials. Many models will now appear slightly brighter. #12043
- Fixed the calculation of base color in materials using the KHR_materials_specular extension. #12041
- Adjusted spacing for on screen Credits and updated recommendations for positioning custom ones. #11912
PBR material glTF sample model, showcasing auto paint using the recently supported glTF extensions.
Cesium for Unreal 2.7.0 Release
Cesium for Unreal v2.7.0 is now available. Highlights of the release include:
- Added support for custom non-WGS84 ellipsoids.
- Fixed a bug in
CesiumCartographicRasterOverlaywhere small tiles would not be excluded. - Fixed a bug in
CesiumCartographicRasterOverlaythat could cause pieces of tiles to appear inside the excluded region. - Removed an unnecessary alpha check when selecting translucent base materials.
Cesium for Unity 1.11.0 Release
Cesium for Unity v1.11.0 is now available. Highlights of this release include:
- Fixed a bug that caused Cesium ion tokens to fail to save when selected through the Token panel.
- Cesium for Unity no longer requires the MSVC runtime library redistributable to be installed.
Cesium ion Updates
- Reality Tiler v2.0.0 is now available, with significant performance improvements for large models.
- Cesium ion Self-Hosted v1.2 is now available, including clipping support, importing from and exporting to S3, and additional enhancements and bug fixes.
- Vexcel 3D Cities data now available for Cesium ion Self-Hosted: offline access to high fidelity 3D data. Learn more here.
Vexcel 3D Cities data of New York City, New York, USA.
