CesiumGeometry Namespace Reference
Basic geometry classes for Cesium. More...
Classes
class  AvailabilityAccessor
 Accessor for use with AvailabilityView in order to safely obtain the contents of the view. More...
struct  AvailabilityNode
 Availability nodes wrap AvailabilitySubtree objects and link them together to form a downwardly traversable availability tree. More...
struct  AvailabilitySubtree
 The subtree data for an AvailabilityNode, containing information on tile, content, and subtree availability. More...
struct  AvailabilityTree
 A downwardly-traversable tree of AvailabilityNode objects. More...
struct  AxisAlignedBox
 An Axis-Aligned Bounding Box (AABB), where the axes of the box are aligned with the axes of the coordinate system. More...
class  BoundingCylinderRegion
 A bounding volume defined as a region following the surface of a cylinder between two radius values. Used for creating bounding volumes from 3DTILES_bounding_volume_cylinder. More...
class  BoundingSphere
 A bounding sphere with a center and a radius. More...
struct  ConstantAvailability
 An availability value that is a constant boolean value. More...
struct  CullingVolume
 A culling volume, defined by four planes. More...
struct  InterpolatedVertex
 A structure describing a vertex that results from interpolating two other vertices. More...
class  IntersectionTests
 Functions for computing the intersection between geometries such as rays, planes, triangles, and ellipsoids. More...
class  OctreeAvailability
 An availability tree for an octree, where availability can be stored and computed based on OctreeTileID. More...
struct  OctreeTileID
 A structure serving as a unique identifier for a node in an octree. More...
class  OctreeTilingScheme
 Defines how an AxisAlignedBox is divided into octree tiles. More...
class  OrientedBoundingBox
 A bounding volume defined as a closed and convex cuboid with any orientation. More...
class  Plane
 A plane in Hessian Normal Format. More...
class  QuadtreeAvailability
 An availability tree for a quadtree, where availability can be stored and computed based on QuadtreeTileID. More...
class  QuadtreeRectangleAvailability
 Manages information about the availability of tiles in a quadtree. More...
struct  QuadtreeTileID
 Uniquely identifies a node in a quadtree. More...
struct  QuadtreeTileRectangularRange
 A rectangular range of tiles at a particular level of a quadtree. More...
class  QuadtreeTilingScheme
 Defines how a rectangular region is divided into quadtree tiles. More...
class  Ray
 A ray that extends infinitely from the provided origin in the provided direction. More...
struct  Rectangle
 A 2D rectangle. More...
struct  SubtreeBufferView
 An availability value that needs to be obtained using an offset into a buffer. More...
struct  Transforms
 Coordinate system matrix constructions helpers. More...
struct  UpsampledQuadtreeNode
 A node of a tile hierarchy that was created by upsampling the tile content of a parent node. More...
Typedefs
typedef std::variant< ConstantAvailability, SubtreeBufferView > AvailabilityView
 A view into availability information for part of the availability tree. This could be either a constant boolean value or a descriptor pointing to a buffer in an AvailabilitySubtree where the information will be looked up.
using TriangleClipVertex = std::variant<int, InterpolatedVertex>
 A vertex resulting from clipping a triangle against a threshold.
Enumerations
enum class  Axis { X , Y , Z }
 An enum describing the x, y, and z axes. More...
enum class  CullingResult { Outside = -1 , Intersecting = 0 , Inside = 1 }
 The result of culling an object. More...
enum  TileAvailabilityFlags {
  TILE_AVAILABLE = 1U , CONTENT_AVAILABLE = 2U , SUBTREE_AVAILABLE = 4U , SUBTREE_LOADED = 8U ,
  REACHABLE = 16U
 A bitmask representing the availability state of a tile. More...
Functions
bool intersects (const AxisAlignedBox &b0, const AxisAlignedBox &b1)
 Test if two axis-aligned boxes intersect.
OrientedBoundingBox toOrientedBoundingBox (const AxisAlignedBox &box)
 Return the equivalent OrientedBoundingBox for an AxisAlignedBox. The axes will be the principal axes.
void clipTriangleAtAxisAlignedThreshold (double threshold, bool keepAbove, int i0, int i1, int i2, double u0, double u1, double u2, std::vector< TriangleClipVertex > &result) noexcept
 Splits a 2D triangle at given axis-aligned threshold value and returns the resulting polygon on a given side of the threshold.
CullingVolume createCullingVolume (const glm::dvec3 &position, const glm::dvec3 &direction, const glm::dvec3 &up, double fovx, double fovy) noexcept
 Creates a CullingVolume for a perspective frustum.
CullingVolume createCullingVolume (const glm::dmat4 &clipMatrix)
 Create a CullingVolume from a projection matrix.
CullingVolume createCullingVolume (const glm::dvec3 &position, const glm::dvec3 &direction, const glm::dvec3 &up, double l, double r, double b, double t, double n) noexcept
CullingVolume createOrthographicCullingVolume (const glm::dvec3 &position, const glm::dvec3 &direction, const glm::dvec3 &up, double l, double r, double b, double t, double n) noexcept
 Creates a CullingVolume for an orthographic frustum.
bool intersects (const OrientedBoundingBox &b1, const OrientedBoundingBox &b2)
 Test if two oriented bounding boxes intersect.
--- comment: This file was generated by dep-graph-gen. DO NOT EDIT THIS FILE! title: CesiumGeometry Dependency Graph --- graph TD classDef dependencyNode fill:#fff,stroke:#ccc,color:#666,font-weight:bold,font-size:28px classDef libraryNode fill:#9f9,font-weight:bold,font-size:28px CesiumGeometry[CesiumGeometry] --> CesiumUtility[CesiumUtility] class CesiumUtility,CesiumGeometry libraryNode
Typedef Documentation
◆ AvailabilityView
Instead of using this type directly, AvailabilityAccessor can be used to work with it safely.
Definition at line 60 of file Availability.h.
◆ TriangleClipVertex
It may either be a simple index referring to an existing vertex, or an interpolation between two vertices.
Definition at line 59 of file clipTriangleAtAxisAlignedThreshold.h.
◆ Axis
enum class CesiumGeometry::Axis
strong
Enumerator
X
The x-axis.
Y
The y-axis.
Z
The z-axis.
Definition at line 10 of file Axis.h.
◆ CullingResult
enum class CesiumGeometry::CullingResult
strong
Enumerator
Outside
Indicates that an object lies completely outside the culling volume.
Intersecting
Indicates that an object intersects with the boundary of the culling volume.
This means that the object is partially inside and partially outside the culling volume.
Inside
Indicates that an object lies completely inside the culling volume.
Definition at line 10 of file CullingResult.h.
◆ TileAvailabilityFlags
Enumerator
TILE_AVAILABLE
The tile is known to be available.
CONTENT_AVAILABLE
The tile's content is known to be available.
SUBTREE_AVAILABLE
This tile has a subtree that is known to be available.
SUBTREE_LOADED
This tile has a subtree that is loaded.
REACHABLE
The tile is reachable through the tileset availability tree.
If a tile is not reachable, the above flags being false may simply indicate that a subtree needed to reach this tile has not yet been loaded.
Definition at line 12 of file TileAvailabilityFlags.h.
Function Documentation
◆ clipTriangleAtAxisAlignedThreshold()
void CesiumGeometry::clipTriangleAtAxisAlignedThreshold ( double threshold,
bool keepAbove,
int i0,
int i1,
int i2,
double u0,
double u1,
double u2,
std::vector< TriangleClipVertex > & result )
noexcept
The resulting polygon may have 0, 1, 2, 3, or 4 vertices.
thresholdThe threshold coordinate value at which to clip the triangle.
keepAbovetrue to keep the portion of the triangle above the threshold, or false to keep the portion below.
i0The index of the first vertex in the triangle in counter-clockwise order, used only to construct the TriangleClipVertex result.
i1The index of the second vertex in the triangle in counter-clockwise order, used only to construct the TriangleClipVertex result.
i2The index of the third vertex in the triangle in counter-clockwise order, used only to construct the TriangleClipVertex result.
u0The coordinate of the first vertex in the triangle, in counter-clockwise order.
u1The coordinate of the second vertex in the triangle, in counter-clockwise order.
u2The coordinate of the third vertex in the triangle, in counter-clockwise order.
resultOn return, contains the polygon that results after the clip, specified as a list of vertices. If this vector already contains elements, the result is pushed onto the end of the vector.
TODO port this CesiumJS example to cesium-native
var result = Cesium.Intersections2D.clipTriangleAtAxisAlignedThreshold(0.5,
false, 0.2, 0.6, 0.4);
// result === [2, 0, -1, 1, 0, 0.25, -1, 1, 2, 0.5]
◆ createCullingVolume() [1/3]
CullingVolume CesiumGeometry::createCullingVolume ( const glm::dmat4 & clipMatrix)
The matrix can be a composite view - projection matrix; the volume will then cull world coordinates. It can also be a model - view - projection matrix, which will cull model coordinates.
◆ createCullingVolume() [2/3]
CullingVolume CesiumGeometry::createCullingVolume ( const glm::dvec3 & position,
const glm::dvec3 & direction,
const glm::dvec3 & up,
double fovx,
double fovy )
noexcept
positionThe eye position
directionThe viewing direction
upThe up-vector of the frustum
fovxThe horizontal Field-Of-View angle, in radians
fovyThe vertical Field-Of-View angle, in radians
The CullingVolume
◆ createCullingVolume() [3/3]
double l,
double r,
double b,
double t,
double n )
noexcept
lleft edge
rright edge
ttop edge
bbottom edge
nnear plane distance
The CullingVolume
◆ createOrthographicCullingVolume()
CullingVolume CesiumGeometry::createOrthographicCullingVolume ( const glm::dvec3 & position,
double l,
double r,
double b,
double t,
double n )
noexcept
lleft edge
rright edge
ttop edge
bbottom edge
The CullingVolume
◆ intersects() [1/2]
bool CesiumGeometry::intersects ( const AxisAlignedBox & b0,
const AxisAlignedBox & b1 )
b0The first axis-aligned box.
b1The second axis-aligned box.
Whether the boxes intersect.
◆ intersects() [2/2]
bool CesiumGeometry::intersects ( const OrientedBoundingBox & b1,
const OrientedBoundingBox & b2 )
b1The first oriented bounding box.
b2The second oriented bounding box.
◆ toOrientedBoundingBox()
OrientedBoundingBox CesiumGeometry::toOrientedBoundingBox ( const AxisAlignedBox & box)
boxThe source axis-aligned bounding box.
The equivalent oriented bounding box.
