CesiumGeometry::QuadtreeRectangleAvailability Class Referencefinal
Manages information about the availability of tiles in a quadtree. More...
#include <CesiumGeometry/QuadtreeRectangleAvailability.h>
 QuadtreeRectangleAvailability (const QuadtreeTilingScheme &tilingScheme, uint32_t maximumLevel) noexcept
 Creates a new instance.
void addAvailableTileRange (const QuadtreeTileRectangularRange &range) noexcept
 Adds the specified range to the set of available tiles.
uint32_t computeMaximumLevelAtPosition (const glm::dvec2 &position) const noexcept
 Computes the maximum level for the given 2D position.
uint8_t isTileAvailable (const QuadtreeTileID &id) const noexcept
 Returns whether a certain tile is available.
Definition at line 18 of file QuadtreeRectangleAvailability.h.
◆ QuadtreeRectangleAvailability()
CesiumGeometry::QuadtreeRectangleAvailability::QuadtreeRectangleAvailability ( const QuadtreeTilingScheme & tilingScheme,
uint32_t maximumLevel )
noexcept
tilingSchemeThe QuadtreeTilingScheme.
maximumLevelThe maximum level (height of the tree) for which the availability should be tracked.
◆ addAvailableTileRange()
void CesiumGeometry::QuadtreeRectangleAvailability::addAvailableTileRange ( const QuadtreeTileRectangularRange & range)
noexcept
rangeThe QuadtreeTileRectangularRange that describes the range of available tiles.
◆ computeMaximumLevelAtPosition()
uint32_t CesiumGeometry::QuadtreeRectangleAvailability::computeMaximumLevelAtPosition ( const glm::dvec2 & position) const
noexcept
This will compute the maximum level of any available tile for the given position. The position refers to the 2D space that is covered by the nodes of the quadtree.
positionThe 2D position.
The maximum level at the given position. This may be 0 if the position is not covered by the quadtree at all.
◆ isTileAvailable()
uint8_t CesiumGeometry::QuadtreeRectangleAvailability::isTileAvailable ( const QuadtreeTileID & id) const
noexcept
This checks the availability of the tile that is described by the given QuadtreeTileID, which consists of the level and the x- and y- coordinates of the queried tile.
idThe quadtree tile ID.
The CesiumGeometry::TileAvailabilityFlags for this tile, encoded into an uint8_t.
