Functions for computing the intersection between geometries such as rays, planes, triangles, and ellipsoids. More...
#include <CesiumGeometry/IntersectionTests.h>
| static std::optional< glm::dvec3 > | rayPlane (const Ray &ray, const Plane &plane) noexcept |
| Computes the intersection of a ray and a plane. | |
| static std::optional< glm::dvec2 > | rayEllipsoid (const Ray &ray, const glm::dvec3 &radii) noexcept |
| Computes the intersection of a ray and an ellipsoid with the given radii, centered at the origin. | |
| static bool | pointInTriangle (const glm::dvec2 &point, const glm::dvec2 &triangleVertA, const glm::dvec2 &triangleVertB, const glm::dvec2 &triangleVertC) noexcept |
| Determines whether a given point is completely inside a triangle defined by three 2D points. | |
| static bool | pointInTriangle (const glm::dvec3 &point, const glm::dvec3 &triangleVertA, const glm::dvec3 &triangleVertB, const glm::dvec3 &triangleVertC) noexcept |
| Determines whether a given point is completely inside a triangle defined by three 3D points. | |
| static bool | pointInTriangle (const glm::dvec3 &point, const glm::dvec3 &triangleVertA, const glm::dvec3 &triangleVertB, const glm::dvec3 &triangleVertC, glm::dvec3 &barycentricCoordinates) noexcept |
| Determines whether the point is completely inside a triangle defined by three 3D points. If the point is inside, this also outputs the barycentric coordinates for the point. | |
| static std::optional< glm::dvec3 > | rayTriangle (const Ray &ray, const glm::dvec3 &p0, const glm::dvec3 &p1, const glm::dvec3 &p2, bool cullBackFaces=false) |
| Tests if a ray hits a triangle and returns the hit point. | |
| static std::optional< double > | rayTriangleParametric (const Ray &ray, const glm::dvec3 &p0, const glm::dvec3 &p1, const glm::dvec3 &p2, bool cullBackFaces=false) |
| Tests if an infinite ray hits a triangle and returns the parametric hit position. | |
| static std::optional< glm::dvec3 > | rayAABB (const Ray &ray, const AxisAlignedBox &aabb) |
| Computes the intersection of a ray and an axis aligned bounding box. | |
| static std::optional< double > | rayAABBParametric (const Ray &ray, const AxisAlignedBox &aabb) |
| Computes the intersection of an infinite ray and an axis aligned bounding box and returns the parametric hit position. | |
| static std::optional< glm::dvec3 > | rayOBB (const Ray &ray, const OrientedBoundingBox &obb) |
| Computes the intersection of a ray and an oriented bounding box. | |
| static std::optional< double > | rayOBBParametric (const Ray &ray, const OrientedBoundingBox &obb) |
| Computes the intersection of an infinite ray and an oriented bounding box and returns the parametric hit position. | |
| static std::optional< glm::dvec3 > | raySphere (const Ray &ray, const BoundingSphere &sphere) |
| Computes the intersection of a ray and a bounding sphere. | |
| static std::optional< double > | raySphereParametric (const Ray &ray, const BoundingSphere &sphere) |
| Computes the intersection of an infinite ray and a bounding sphere and returns the parametric hit position. | |
Definition at line 21 of file IntersectionTests.h.
staticnoexcept |
This function does not check for degeneracy of the triangle.
| point | The point to check. |
| triangleVertA | The first vertex of the triangle. |
| triangleVertB | The second vertex of the triangle. |
| triangleVertC | The third vertex of the triangle. |
staticnoexcept |
Returns false for degenerate triangles.
staticnoexcept |
| barycentricCoordinates | The barycentric coordinates for the point, if the point is inside the triangle. |
static |
| ray | The ray. |
| aabb | The axis aligned bounding box. |
std::nullopt if there is no intersection.
static |
The return value is positive if the intersection point is in front of the ray origin, negative if it is behind it, or zero if the two points coincide.
| ray | The ray. |
staticnoexcept |
Returns false if any of the radii are 0.
| ray | The ray. |
| radii | The radii of ellipsoid. |
std::nullopt if there are no intersections. X is the entry, and y is the exit.
static |
| ray | The ray. |
| obb | The oriented bounding box. |
static |
The return parameter is positive if the intersection point is in front of the ray origin, negative if it is behind it, or zero if the two points coincide.
| ray | The ray. |
staticnoexcept |
| ray | The ray. |
| plane | The plane. |
static |
| ray | The ray. |
| sphere | The bounding sphere. |
static |
| ray | The ray. |
static |
| ray | The ray. |
| p0 | The first vertex of the triangle. |
| p1 | The second vertex of the triangle. |
| p2 | The third vertex of the triangle. |
| cullBackFaces | Ignore triangles that face away from ray. Front faces use CCW winding order. |
static |
| ray | The ray. |
