CesiumGeometry::SubtreeBufferView Struct Reference
An availability value that needs to be obtained using an offset into a buffer. More...
#include <CesiumGeometry/Availability.h>
uint32_t byteOffset
 The offset into the buffer to read from.
uint32_t byteLength
 The number of bytes after the offset to read until.
uint8_t buffer
 The index into AvailabilitySubtree::buffers that this SubtreeBufferView corresponds to.
Definition at line 35 of file Availability.h.
◆ buffer
uint8_t CesiumGeometry::SubtreeBufferView::buffer
Definition at line 48 of file Availability.h.
◆ byteLength
uint32_t CesiumGeometry::SubtreeBufferView::byteLength
Definition at line 43 of file Availability.h.
◆ byteOffset
uint32_t CesiumGeometry::SubtreeBufferView::byteOffset
Definition at line 39 of file Availability.h.
