CesiumGeometry::Transforms Struct Referencefinal
Coordinate system matrix constructions helpers. More...
#include <CesiumGeometry/Transforms.h>
static glm::dmat4 createTranslationRotationScaleMatrix (const glm::dvec3 &translation, const glm::dquat &rotation, const glm::dvec3 &scale)
 Creates a translation-rotation-scale matrix, equivalent to translation * rotation * scale. So if a vector is multiplied with the resulting matrix, it will be first scaled, then rotated, then translated.
static void computeTranslationRotationScaleFromMatrix (const glm::dmat4 &matrix, glm::dvec3 *pTranslation, glm::dquat *pRotation, glm::dvec3 *pScale)
 Decomposes a matrix into translation, rotation, and scale components. This is the reverse of createTranslationRotationScaleMatrix.
static const glm::dmat4 & getUpAxisTransform (CesiumGeometry::Axis from, CesiumGeometry::Axis to)
 Gets a transform that converts from one up axis to another.
static glm::dmat4 createViewMatrix (const glm::dvec3 &position, const glm::dvec3 &direction, const glm::dvec3 &up)
 Create a view matrix.
static glm::dmat4 createPerspectiveMatrix (double fovx, double fovy, double zNear, double zFar)
 Compute a Vulkan-style perspective projection matrix with reversed Z.
static glm::dmat4 createPerspectiveMatrix (double left, double right, double bottom, double top, double zNear, double zFar)
static glm::dmat4 createOrthographicMatrix (double left, double right, double bottom, double top, double zNear, double zFar)
 Compute a Vulkan-style orthographic projection matrix with reversed Z.
static const glm::dmat4 Y_UP_TO_Z_UP
 A matrix to convert from y-up to z-up orientation, by rotating about PI/2 around the x-axis.
static const glm::dmat4 Z_UP_TO_Y_UP
 A matrix to convert from z-up to y-up orientation, by rotating about -PI/2 around the x-axis.
static const glm::dmat4 X_UP_TO_Z_UP
 A matrix to convert from x-up to z-up orientation, by rotating about -PI/2 around the y-axis.
static const glm::dmat4 Z_UP_TO_X_UP
 A matrix to convert from z-up to x-up orientation, by rotating about PI/2 around the y-axis.
static const glm::dmat4 X_UP_TO_Y_UP
 A matrix to convert from x-up to y-up orientation, by rotating about PI/2 around the z-axis.
static const glm::dmat4 Y_UP_TO_X_UP
 A matrix to convert from y-up to x-up orientation, by rotating about -PI/2 around the z-axis.
Definition at line 13 of file Transforms.h.
◆ computeTranslationRotationScaleFromMatrix()
static void CesiumGeometry::Transforms::computeTranslationRotationScaleFromMatrix ( const glm::dmat4 & matrix,
glm::dvec3 * pTranslation,
glm::dquat * pRotation,
glm::dvec3 * pScale )
static
The scale may be negative (i.e. when switching from a right-handed to a left-handed system), but skew and other funny business will result in undefined behavior.
matrixThe matrix to decompose.
pTranslationA pointer to the vector in which to store the translation, or nullptr if the translation is not needed.
pRotationA pointer to the quaternion in which to store the rotation, or nullptr if the rotation is not needed.
pScaleA pointer to the vector in which to store the scale, or nullptr if the scale is not needed.
◆ createOrthographicMatrix()
static glm::dmat4 CesiumGeometry::Transforms::createOrthographicMatrix ( double left,
double right,
double bottom,
double top,
double zNear,
double zFar )
static
"Vulkan-style", as return by this function and others, uses the following conventions:
  • X maps from -1 to 1 left to right
  • Y maps from 1 to -1 bottom to top
  • Z maps from 1 to 0 near to far (known as "reverse Z")
leftleft distance of near plane edge from center
rightright distance of near plane edge
bottombottom distance of near plane edge
toptop distance of near plane edge
zNeardistance of near plane
zFardistance of far plane. This can be infinite
◆ createPerspectiveMatrix() [1/2]
static glm::dmat4 CesiumGeometry::Transforms::createPerspectiveMatrix ( double fovx,
double fovy,
double zNear,
double zFar )
static
fovxhorizontal field of view in radians
fovyvertical field of view in radians
zNeardistance to near plane
zFardistance to far plane
◆ createPerspectiveMatrix() [2/2]
static glm::dmat4 CesiumGeometry::Transforms::createPerspectiveMatrix ( double left,
double right,
double bottom,
double top,
double zNear,
double zFar )
static
◆ createTranslationRotationScaleMatrix()
static glm::dmat4 CesiumGeometry::Transforms::createTranslationRotationScaleMatrix ( const glm::dvec3 & translation,
const glm::dquat & rotation,
const glm::dvec3 & scale )
static
translationThe translation.
rotationThe rotation.
scaleThe scale.
◆ createViewMatrix()
static glm::dmat4 CesiumGeometry::Transforms::createViewMatrix ( const glm::dvec3 & position,
const glm::dvec3 & direction,
const glm::dvec3 & up )
static
This is similar to glm::lookAt(), but uses the pose of the viewer to create the view matrix. The view matrix is the inverse of the pose matrix.
positionposition of the eye
directionview vector i.e., -z axis of the viewer's pose.
upup vector of viewer i.e., y axis of the viewer's pose.
The view matrix.
◆ getUpAxisTransform()
static const glm::dmat4 & CesiumGeometry::Transforms::getUpAxisTransform ( CesiumGeometry::Axis from,
CesiumGeometry::Axis to )
static
fromThe up axis to convert from.
toThe up axis to convert to.
The up axis transform.
◆ X_UP_TO_Y_UP
const glm::dmat4 CesiumGeometry::Transforms::X_UP_TO_Y_UP
static
Definition at line 43 of file Transforms.h.
◆ X_UP_TO_Z_UP
const glm::dmat4 CesiumGeometry::Transforms::X_UP_TO_Z_UP
static
Definition at line 31 of file Transforms.h.
◆ Y_UP_TO_X_UP
const glm::dmat4 CesiumGeometry::Transforms::Y_UP_TO_X_UP
static
Definition at line 49 of file Transforms.h.
◆ Y_UP_TO_Z_UP
const glm::dmat4 CesiumGeometry::Transforms::Y_UP_TO_Z_UP
static
Definition at line 19 of file Transforms.h.
◆ Z_UP_TO_X_UP
const glm::dmat4 CesiumGeometry::Transforms::Z_UP_TO_X_UP
static
Definition at line 37 of file Transforms.h.
◆ Z_UP_TO_Y_UP
const glm::dmat4 CesiumGeometry::Transforms::Z_UP_TO_Y_UP
static
Definition at line 25 of file Transforms.h.
