CesiumGeometry::OctreeTilingScheme Class Reference
Defines how an AxisAlignedBox is divided into octree tiles. More...
#include <CesiumGeometry/OctreeTilingScheme.h>
 OctreeTilingScheme (const AxisAlignedBox &box, uint32_t rootTilesX, uint32_t rootTilesY, uint32_t rootTilesZ) noexcept
const AxisAlignedBox & getBox () const noexcept
 Return the overall box that is tiled.
uint32_t getRootTilesX () const noexcept
 Returns the number of root tiles, in x-direction.
uint32_t getRootTilesY () const noexcept
 Returns the number of root tiles, in y-direction.
uint32_t getRootTilesZ () const noexcept
 Returns the number of root tiles, in z-direction.
uint32_t getNumberOfXTilesAtLevel (uint32_t level) const noexcept
 Returns the number of tiles, in x-direction, at the given level.
uint32_t getNumberOfYTilesAtLevel (uint32_t level) const noexcept
 Returns the number of tiles, in y-direction, at the given level.
uint32_t getNumberOfZTilesAtLevel (uint32_t level) const noexcept
 Returns the number of tiles, in z-direction, at the given level.
std::optional< CesiumGeometry::OctreeTileID > positionToTile (const glm::dvec3 &position, uint32_t level) const noexcept
 Computes the CesiumGeometry::OctreeTileID for a given position and level.
AxisAlignedBox tileToBox (const CesiumGeometry::OctreeTileID &tileID) const noexcept
 Returns the AxisAlignedBox that is covered by the specified tile.
Definition at line 17 of file OctreeTilingScheme.h.
◆ OctreeTilingScheme()
CesiumGeometry::OctreeTilingScheme::OctreeTilingScheme ( const AxisAlignedBox & box,
uint32_t rootTilesZ )
noexcept
boxThe overall box that is tiled, expressed in projected coordinates.
rootTilesXThe number of tiles at the root of the quadtree in the X direction.
rootTilesYThe nubmer of tiles at the root of the quadtree in the Y direction.
rootTilesZThe number of tiles at the root of the quadtree in the Z direction.
◆ getBox()
const AxisAlignedBox & CesiumGeometry::OctreeTilingScheme::getBox ( ) const
inlinenoexcept
Definition at line 40 of file OctreeTilingScheme.h.
◆ getRootTilesX()
uint32_t CesiumGeometry::OctreeTilingScheme::getRootTilesX ( ) const
inlinenoexcept
Definition at line 45 of file OctreeTilingScheme.h.
◆ getRootTilesY()
uint32_t CesiumGeometry::OctreeTilingScheme::getRootTilesY ( ) const
inlinenoexcept
Definition at line 50 of file OctreeTilingScheme.h.
◆ getRootTilesZ()
uint32_t CesiumGeometry::OctreeTilingScheme::getRootTilesZ ( ) const
inlinenoexcept
Definition at line 55 of file OctreeTilingScheme.h.
◆ positionToTile()
std::optional< CesiumGeometry::OctreeTileID > CesiumGeometry::OctreeTilingScheme::positionToTile ( const glm::dvec3 & position,
uint32_t level ) const
noexcept
If the projected position is within the getBox of this tiling scheme, then this will compute the octree tile ID for the tile that contains the given position at the given level. Otherwise, nullopt is returned.
positionThe position in projected coordinates.
levelThe level
The tile ID, or nullopt.
◆ tileToBox()
AxisAlignedBox CesiumGeometry::OctreeTilingScheme::tileToBox ( const CesiumGeometry::OctreeTileID & tileID) const
noexcept
The volume that is covered by the tile that is identified with the given CesiumGeometry::OctreeTileID will be computed, based on the getBox of this tiling scheme.
tileIDThe tile ID
The box
