CesiumGeometry::OctreeAvailability Class Referencefinal
An availability tree for an octree, where availability can be stored and computed based on OctreeTileID. More...
#include <CesiumGeometry/OctreeAvailability.h>
 OctreeAvailability (uint32_t subtreeLevels, uint32_t maximumLevel) noexcept
uint8_t computeAvailability (const OctreeTileID &tileID) const noexcept
 Determines the currently known availability status of the given tile.
bool addSubtree (const OctreeTileID &tileID, AvailabilitySubtree &&newSubtree) noexcept
 Attempts to add an availability subtree into the existing overall availability tree.
uint8_t computeAvailability (const OctreeTileID &tileID, const AvailabilityNode *pNode) const noexcept
AvailabilityNode * addNode (const OctreeTileID &tileID, AvailabilityNode *pParentNode) noexcept
 Attempts to add a child subtree node onto the given parent node.
bool addLoadedSubtree (AvailabilityNode *pNode, AvailabilitySubtree &&newSubtree) noexcept
 Attempts to add a loaded subtree onto the given node.
std::optional< uint32_t > findChildNodeIndex (const OctreeTileID &tileID, const AvailabilityNode *pParentNode) const
 Find the child node index corresponding to this tile ID and parent node.
AvailabilityNode * findChildNode (const OctreeTileID &tileID, AvailabilityNode *pParentNode) const
 Find the child node corresponding to this tile ID and parent node.
constexpr uint32_t getSubtreeLevels () const noexcept
 Gets the number of levels in each subtree.
constexpr uint32_t getMaximumLevel () const noexcept
 Gets the index of the maximum level in this implicit tileset.
AvailabilityNode * getRootNode () noexcept
 Gets a pointer to the root subtree node of this implicit tileset.
Definition at line 19 of file OctreeAvailability.h.
◆ OctreeAvailability()
CesiumGeometry::OctreeAvailability::OctreeAvailability ( uint32_t subtreeLevels,
uint32_t maximumLevel )
noexcept
subtreeLevelsThe number of levels in each subtree.
maximumLevelThe index of the maximum level in this tileset.
◆ addLoadedSubtree()
bool CesiumGeometry::OctreeAvailability::addLoadedSubtree ( AvailabilityNode * pNode,
AvailabilitySubtree && newSubtree )
noexcept
The node must have been created earlier from a call to addNode.
pNodeThe node on which to add the subtree.
newSubtreeThe new subtree to add.
Whether the insertion was successful.
◆ addNode()
AvailabilityNode * CesiumGeometry::OctreeAvailability::addNode ( const OctreeTileID & tileID,
AvailabilityNode * pParentNode )
noexcept
Priming with a known parent subtree node avoids the need to traverse the entire availability tree so far. If the parent node is nullptr and the tile ID indicates this is the root tile, the subtree will be attached to the root.
tileIDThe root tile's ID of the subtree we are trying to add.
pParentNodeThe parent subtree node. The tileID should fall exactly at the end of this parent subtree.
The newly created node if the insertion was successful, nullptr otherwise.
◆ addSubtree()
bool CesiumGeometry::OctreeAvailability::addSubtree ( const OctreeTileID & tileID,
noexcept
tileIDThe CesiumGeometry::OctreeTileID for the tile.
newSubtreeThe CesiumGeometry::AvailabilitySubtree to add.
◆ computeAvailability() [1/2]
uint8_t CesiumGeometry::OctreeAvailability::computeAvailability ( const OctreeTileID & tileID) const
noexcept
The TileAvailabilityFlags for this tile encoded into a uint8_t.
◆ computeAvailability() [2/2]
uint8_t CesiumGeometry::OctreeAvailability::computeAvailability ( const OctreeTileID & tileID,
const AvailabilityNode * pNode ) const
noexcept
Priming with a known parent subtree node avoids the need to traverse the entire availability tree so far. The node must have a loaded subtree
tileIDThe tile ID to get the availability for.
pNodeThe subtree node to look for the tileID in. The tileID should be within this subtree node.
◆ findChildNode()
AvailabilityNode * CesiumGeometry::OctreeAvailability::findChildNode ( const OctreeTileID & tileID,
AvailabilityNode * pParentNode ) const
Attempts to find the child node for the tile with the given ID and parent node. The parent node is used to speed up the search significantly. Note that if the given tile ID does not correspond exactly to an immediate child node of the parent node, nullptr will be returned. If a tileID outside the given parent node's subtree is given, an incorrect child index may be returned.
tileIDThe tile ID of the child node we are looking for.
pParentNodeThe immediate parent to the child node we are looking for.
The child node if found, nullptr otherwise.
◆ findChildNodeIndex()
std::optional< uint32_t > CesiumGeometry::OctreeAvailability::findChildNodeIndex ( const OctreeTileID & tileID,
const AvailabilityNode * pParentNode ) const
The child node index if found, std::nullopt otherwise.
◆ getMaximumLevel()
uint32_t CesiumGeometry::OctreeAvailability::getMaximumLevel ( ) const
inlineconstexprnoexcept
The index of the maximum level.
Definition at line 155 of file OctreeAvailability.h.
◆ getRootNode()
AvailabilityNode * CesiumGeometry::OctreeAvailability::getRootNode ( )
inlinenoexcept
The root node of the availability tree.
Definition at line 164 of file OctreeAvailability.h.
◆ getSubtreeLevels()
uint32_t CesiumGeometry::OctreeAvailability::getSubtreeLevels ( ) const
Definition at line 146 of file OctreeAvailability.h.
