A structure describing a vertex that results from interpolating two other vertices. More...
#include <CesiumGeometry/clipTriangleAtAxisAlignedThreshold.h>
| constexpr bool | operator== (const InterpolatedVertex &other) const noexcept |
| Compares this InterpolatedVertex against another. | |
| constexpr bool | operator!= (const InterpolatedVertex &other) const noexcept |
| The inverse of InterpolatedVertex::operator==. | |
| int | first |
| The index of the first vertex to interpolate between. | |
| int | second |
| The index of the second vertex to interpolate between. | |
| double | t |
| The fraction of the distance from first to second at which to interpolate. | |
The vertices to interpolate between are given via their indices. This is used as one representation of a vertex in a TriangleClipVertex.
Definition at line 17 of file clipTriangleAtAxisAlignedThreshold.h.
inlineconstexprnoexcept |
Definition at line 48 of file clipTriangleAtAxisAlignedThreshold.h.
Two InterpolatedVertex instances are considered equivalent if their first and second fields are equivalent and the difference between their t fields is less than std::numeric_limits<double>::epsilon().
Definition at line 41 of file clipTriangleAtAxisAlignedThreshold.h.
| int CesiumGeometry::InterpolatedVertex::first |
Definition at line 21 of file clipTriangleAtAxisAlignedThreshold.h.
| int CesiumGeometry::InterpolatedVertex::second |
Definition at line 26 of file clipTriangleAtAxisAlignedThreshold.h.
| double CesiumGeometry::InterpolatedVertex::t |
Definition at line 32 of file clipTriangleAtAxisAlignedThreshold.h.
