CesiumGltf::BoundingVolume Struct Referencefinal
A bounding volume. More...
#include <CesiumGltf/BoundingVolume.h>
Inheritance diagram for CesiumGltf::BoundingVolume:
std::vector< double > rotation = {0, 0, 0, 1}
 The bounding volume's unit quaternion rotation relative to the node's local coordinate system.
std::vector< double > scale = {1, 1, 1}
 The bounding volume's scale along the rotated local X, Y, and Z axes.
int32_t shape = -1
 The index of the shape in the top-level shapes array used for this bounding volume. Required.
std::vector< double > translation = {0, 0, 0}
 The bounding volume's translation along the node's local X, Y, and Z axes.
static constexpr const char * TypeName = "BoundingVolume"
A bounding volume.
Definition at line 15 of file BoundingVolume.h.
int64_t CesiumGltf::BoundingVolume::getSizeBytes ( ) const
Definition at line 52 of file BoundingVolume.h.
◆ rotation
std::vector<double> CesiumGltf::BoundingVolume::rotation = {0, 0, 0, 1}
Definition at line 26 of file BoundingVolume.h.
◆ scale
std::vector<double> CesiumGltf::BoundingVolume::scale = {1, 1, 1}
Definition at line 32 of file BoundingVolume.h.
◆ shape
int32_t CesiumGltf::BoundingVolume::shape = -1
Definition at line 38 of file BoundingVolume.h.
◆ translation
std::vector<double> CesiumGltf::BoundingVolume::translation = {0, 0, 0}
Definition at line 44 of file BoundingVolume.h.
const char* CesiumGltf::BoundingVolume::TypeName = "BoundingVolume"
Definition at line 20 of file BoundingVolume.h.
