Tiling Drone or Satellite Imagery
Cesium ion allows you to tile drone or satellite imagery, combine it into a mosaic, and drape it on global 3D terrain.
This guide explains how.
Satellite imagery from Bing maps draped over Cesium World Terrain at Glen Canyon, Arizona.
Cesium ion is an open platform for tiling and hosting.
| Format | File extensions |
| GeoTIFF | .tiff, .tif |
| Floating Point Raster | .flt |
| Arc/Info ASCII Grid | .asc |
| Source Map | .src |
| Erdas Imagine | .img |
| USGS ASCII DEM and CDED | .dem |
| JPEG | .jpg, .jpeg |
| PNG | .png |
| Other common raster formats |
Imagery files must be georeferenced before being loaded into Cesium ion.
- Files may be zipped.
- Include any sidecar files when uploading (such as .aux, .xml, .tab, .tfw, .wld, .prj, .ovr, .rrd).
- Uploaded imagery is automatically reprojected to EPSG:3857.
Cesium ion tiles your imagery into WMTS/TMS. Here’s a sample GeoTIFF you can download to try this out.
- On the My Assets tab of Cesium ion, press Add Data to upload your model.
- Select Raster Imagery.
- Imagery files must be georeferenced before being loaded into Cesium ion.
The easiest way to visualize and share your asset is using Cesium Stories.
- In the Stories tab, click New Story.
- Under Assets, click the Add asset button and choose your asset.
- Click on the zoom button (magnifying glass) to go to your asset in the scene. Adjust the view to your liking.
- Click on Capture view to save the view.
- Click Share and give your story a name.
You can now share your data in an interactive scene! Learn more about Stories with this tutorial.
When you click on an asset in My Assets, you’ll see a preview panel on the right side of the screen.
- The preview panel displays the asset ID, which you’ll need for loading this asset in CesiumJS or other engines.
- You’ll find a code snippet for loading this asset in CesiumJS at the bottom of this panel.
- Click Open complete code example to see your asset in Sandcastle.
Learn how to set up a CesiumJS app with the quickstart guide.
Live code examples for imagery
Check out these live code examples to see what you can do with imagery:
Tips
- Compress your GeoTIFF with LZW or other compression methods for faster uploads.
- Tiling time will vary based on size, resolution, and projection of the data. Imagery that’s already in EPSG:3857 will tile faster.
