TileBoundingVolumes.h
3#include <CesiumGeometry/BoundingCylinderRegion.h>
4#include <CesiumGeometry/BoundingSphere.h>
5#include <CesiumGeometry/OrientedBoundingBox.h>
6#include <CesiumGeospatial/BoundingRegion.h>
7#include <CesiumGeospatial/S2CellBoundingVolume.h>
9#include <optional>
10
11namespace Cesium3DTiles {
12struct BoundingVolume;
13}
14
15namespace Cesium3DTilesContent {
16
22public:
31 static std::optional<CesiumGeometry::OrientedBoundingBox>
33
44 Cesium3DTiles::BoundingVolume& boundingVolume,
45 const CesiumGeometry::OrientedBoundingBox& boundingBox);
46
56 static std::optional<CesiumGeospatial::BoundingRegion> getBoundingRegion(
57 const Cesium3DTiles::BoundingVolume& boundingVolume,
58 const CesiumGeospatial::Ellipsoid& ellipsoid CESIUM_DEFAULT_ELLIPSOID);
59
69 static void setBoundingRegion(
70 Cesium3DTiles::BoundingVolume& boundingVolume,
71 const CesiumGeospatial::BoundingRegion& boundingRegion);
72
81 static std::optional<CesiumGeometry::BoundingSphere>
83
93 static void setBoundingSphere(
94 Cesium3DTiles::BoundingVolume& boundingVolume,
95 const CesiumGeometry::BoundingSphere& boundingSphere);
96
109 static std::optional<CesiumGeospatial::S2CellBoundingVolume>
111 const Cesium3DTiles::BoundingVolume& boundingVolume,
112 const CesiumGeospatial::Ellipsoid& ellipsoid CESIUM_DEFAULT_ELLIPSOID);
113
126 Cesium3DTiles::BoundingVolume& boundingVolume,
127 const CesiumGeospatial::S2CellBoundingVolume& s2BoundingVolume);
128
140 static std::optional<CesiumGeometry::BoundingCylinderRegion>
142 const Cesium3DTiles::BoundingVolume& boundingVolume);
143
156 Cesium3DTiles::BoundingVolume& boundingVolume,
157 const CesiumGeometry::BoundingCylinderRegion& boundingCylinderRegion);
158};
159
160} // namespace Cesium3DTilesContent
Provides functions for extracting bounding volumes types from the vectors stored in Cesium3DTiles::Bo...
static void setBoundingRegion(Cesium3DTiles::BoundingVolume &boundingVolume, const CesiumGeospatial::BoundingRegion &boundingRegion)
Sets the region property in a Cesium3DTiles::BoundingVolume based on a CesiumGeospatial::BoundingRegi...
static std::optional< CesiumGeometry::BoundingCylinderRegion > getBoundingCylinderRegion(const Cesium3DTiles::BoundingVolume &boundingVolume)
Gets the bounding cylinder region defined in the 3DTILES_bounding_volume_cylinder extension of a Cesi...
static void setBoundingSphere(Cesium3DTiles::BoundingVolume &boundingVolume, const CesiumGeometry::BoundingSphere &boundingSphere)
Sets the sphere property in a Cesium3DTiles::BoundingVolume based on a CesiumGeometry::BoundingSphere...
static std::optional< CesiumGeospatial::S2CellBoundingVolume > getS2CellBoundingVolume(const Cesium3DTiles::BoundingVolume &boundingVolume, const CesiumGeospatial::Ellipsoid &ellipsoid=CesiumGeospatial::Ellipsoid::WGS84)
Gets the S2 cell bounding volume defined in the 3DTILES_bounding_volume_S2 extension of a Cesium3DTil...
static void setOrientedBoundingBox(Cesium3DTiles::BoundingVolume &boundingVolume, const CesiumGeometry::OrientedBoundingBox &boundingBox)
Sets the box property in a Cesium3DTiles::BoundingVolume based on an CesiumGeometry::OrientedBounding...
static std::optional< CesiumGeometry::OrientedBoundingBox > getOrientedBoundingBox(const Cesium3DTiles::BoundingVolume &boundingVolume)
Gets the bounding box defined in a Cesium3DTiles::BoundingVolume, if any.
static void setS2CellBoundingVolume(Cesium3DTiles::BoundingVolume &boundingVolume, const CesiumGeospatial::S2CellBoundingVolume &s2BoundingVolume)
Adds the 3DTILES_bounding_volume_S2 extension to a Cesium3DTiles::BoundingVolume based on a CesiumGeo...
static std::optional< CesiumGeospatial::BoundingRegion > getBoundingRegion(const Cesium3DTiles::BoundingVolume &boundingVolume, const CesiumGeospatial::Ellipsoid &ellipsoid=CesiumGeospatial::Ellipsoid::WGS84)
Gets the bounding region defined in a Cesium3DTiles::BoundingVolume, if any.
static void setBoundingCylinderRegion(Cesium3DTiles::BoundingVolume &boundingVolume, const CesiumGeometry::BoundingCylinderRegion &boundingCylinderRegion)
Adds the 3DTILES_bounding_volume_cylinder extension to a Cesium3DTiles::BoundingVolume based on a Ces...
static std::optional< CesiumGeometry::BoundingSphere > getBoundingSphere(const Cesium3DTiles::BoundingVolume &boundingVolume)
Gets the bounding sphere defined in a Cesium3DTiles::BoundingVolume, if any.
A bounding volume defined as a region following the surface of a cylinder between two radius values....
A bounding sphere with a center and a radius.
A bounding volume defined as a closed and convex cuboid with any orientation.
A bounding volume specified as a longitude/latitude bounding box and a minimum and maximum height.
Definition Ellipsoid.h:39
Classes that support loading and converting 3D Tiles tile content.
Classes for using 3D Tiles.
Definition Buffer.h:7
A bounding volume that encloses a tile or its content. At least one bounding volume property is requi...
