Cesium3DTilesContent::TileBoundingVolumes Class Reference
Provides functions for extracting bounding volumes types from the vectors stored in Cesium3DTiles::BoundingVolume. More...
#include <Cesium3DTilesContent/TileBoundingVolumes.h>
static std::optional< CesiumGeometry::OrientedBoundingBox > getOrientedBoundingBox (const Cesium3DTiles::BoundingVolume &boundingVolume)
 Gets the bounding box defined in a Cesium3DTiles::BoundingVolume, if any.
static void setOrientedBoundingBox (Cesium3DTiles::BoundingVolume &boundingVolume, const CesiumGeometry::OrientedBoundingBox &boundingBox)
 Sets the box property in a Cesium3DTiles::BoundingVolume based on an CesiumGeometry::OrientedBoundingBox.
static std::optional< CesiumGeospatial::BoundingRegion > getBoundingRegion (const Cesium3DTiles::BoundingVolume &boundingVolume, const CesiumGeospatial::Ellipsoid &ellipsoid=CesiumGeospatial::Ellipsoid::WGS84)
 Gets the bounding region defined in a Cesium3DTiles::BoundingVolume, if any.
static void setBoundingRegion (Cesium3DTiles::BoundingVolume &boundingVolume, const CesiumGeospatial::BoundingRegion &boundingRegion)
 Sets the region property in a Cesium3DTiles::BoundingVolume based on a CesiumGeospatial::BoundingRegion.
static std::optional< CesiumGeometry::BoundingSphere > getBoundingSphere (const Cesium3DTiles::BoundingVolume &boundingVolume)
 Gets the bounding sphere defined in a Cesium3DTiles::BoundingVolume, if any.
static void setBoundingSphere (Cesium3DTiles::BoundingVolume &boundingVolume, const CesiumGeometry::BoundingSphere &boundingSphere)
 Sets the sphere property in a Cesium3DTiles::BoundingVolume based on a CesiumGeometry::BoundingSphere.
static std::optional< CesiumGeospatial::S2CellBoundingVolume > getS2CellBoundingVolume (const Cesium3DTiles::BoundingVolume &boundingVolume, const CesiumGeospatial::Ellipsoid &ellipsoid=CesiumGeospatial::Ellipsoid::WGS84)
 Gets the S2 cell bounding volume defined in the 3DTILES_bounding_volume_S2 extension of a Cesium3DTiles::BoundingVolume, if any.
static void setS2CellBoundingVolume (Cesium3DTiles::BoundingVolume &boundingVolume, const CesiumGeospatial::S2CellBoundingVolume &s2BoundingVolume)
 Adds the 3DTILES_bounding_volume_S2 extension to a Cesium3DTiles::BoundingVolume based on a CesiumGeospatial::S2CellBoundingVolume.
static std::optional< CesiumGeometry::BoundingCylinderRegion > getBoundingCylinderRegion (const Cesium3DTiles::BoundingVolume &boundingVolume)
 Gets the bounding cylinder region defined in the 3DTILES_bounding_volume_cylinder extension of a Cesium3DTiles::BoundingVolume, if any.
static void setBoundingCylinderRegion (Cesium3DTiles::BoundingVolume &boundingVolume, const CesiumGeometry::BoundingCylinderRegion &boundingCylinderRegion)
 Adds the 3DTILES_bounding_volume_cylinder extension to a Cesium3DTiles::BoundingVolume based on a CesiumGeometry::BoundingCylinderRegion.
Definition at line 21 of file TileBoundingVolumes.h.
◆ getBoundingCylinderRegion()
static std::optional< CesiumGeometry::BoundingCylinderRegion > Cesium3DTilesContent::TileBoundingVolumes::getBoundingCylinderRegion ( const Cesium3DTiles::BoundingVolume & boundingVolume)
static
boundingVolumeThe bounding volume from which to get the bounding cylinder.
The cylinder region, or std::nullopt if the bounding volume does not define such a region. The cylinder is defined in the tile's coordinate system.
◆ getBoundingRegion()
static std::optional< CesiumGeospatial::BoundingRegion > Cesium3DTilesContent::TileBoundingVolumes::getBoundingRegion ( const Cesium3DTiles::BoundingVolume & boundingVolume,
static
boundingVolumeThe bounding volume from which to get the region.
ellipsoidThe ellipsoid on which the region should be defined.
The region, or std::nullopt if the bounding volume does not define a region. The region is defined in geographic coordinates.
◆ getBoundingSphere()
static std::optional< CesiumGeometry::BoundingSphere > Cesium3DTilesContent::TileBoundingVolumes::getBoundingSphere ( const Cesium3DTiles::BoundingVolume & boundingVolume)
static
boundingVolumeThe bounding volume from which to get the sphere.
The sphere, or std::nullopt if the bounding volume does not define a sphere. The sphere is defined in the tile's coordinate system.
◆ getOrientedBoundingBox()
static std::optional< CesiumGeometry::OrientedBoundingBox > Cesium3DTilesContent::TileBoundingVolumes::getOrientedBoundingBox ( const Cesium3DTiles::BoundingVolume & boundingVolume)
static
boundingVolumeThe bounding volume from which to get the box.
The box, or std::nullopt if the bounding volume does not define a box. The box is defined in the tile's coordinate system.
◆ getS2CellBoundingVolume()
static std::optional< CesiumGeospatial::S2CellBoundingVolume > Cesium3DTilesContent::TileBoundingVolumes::getS2CellBoundingVolume ( const Cesium3DTiles::BoundingVolume & boundingVolume,
static
boundingVolumeThe bounding volume from which to get the S2 cell bounding volume.
ellipsoidThe ellipsoid on which the S2 cell should be defined.
The S2 cell bounding volume, or std::nullopt if the bounding volume does not define an S2 cell bounding volume. The S2 cell bounding volume is defined in geographic coordinates.
◆ setBoundingCylinderRegion()
static void Cesium3DTilesContent::TileBoundingVolumes::setBoundingCylinderRegion ( Cesium3DTiles::BoundingVolume & boundingVolume,
const CesiumGeometry::BoundingCylinderRegion & boundingCylinderRegion )
static
Other bounding volume types, if any, are not modified.
boundingVolumeThe bounding volume to set.
boundingCylinderRegionThe bounding cylinder region with which to set the property.
◆ setBoundingRegion()
static void Cesium3DTilesContent::TileBoundingVolumes::setBoundingRegion ( Cesium3DTiles::BoundingVolume & boundingVolume,
const CesiumGeospatial::BoundingRegion & boundingRegion )
static
boundingRegionThe bounding region with which to set the property.
◆ setBoundingSphere()
static void Cesium3DTilesContent::TileBoundingVolumes::setBoundingSphere ( Cesium3DTiles::BoundingVolume & boundingVolume,
const CesiumGeometry::BoundingSphere & boundingSphere )
static
boundingSphereThe bounding sphere with which to set the property.
◆ setOrientedBoundingBox()
static void Cesium3DTilesContent::TileBoundingVolumes::setOrientedBoundingBox ( Cesium3DTiles::BoundingVolume & boundingVolume,
const CesiumGeometry::OrientedBoundingBox & boundingBox )
static
boundingBoxThe bounding box with which to set the property.
◆ setS2CellBoundingVolume()
static void Cesium3DTilesContent::TileBoundingVolumes::setS2CellBoundingVolume ( Cesium3DTiles::BoundingVolume & boundingVolume,
const CesiumGeospatial::S2CellBoundingVolume & s2BoundingVolume )
static
s2BoundingVolumeThe S2 bounding volume with which to set the property.
