Tiler Data Types and Formats
For a quick start on getting your data into Cesium ion, start with one of these guides:
If you’re looking for more in-depth information about the types of assets Cesium ion serves, supported file formats, and how to upload your data, read on below.
Data pipeline
  • When you upload data to Cesium ion, it is tiled into 3D Tiles for 3D content, or WMTS/TMS for imagery.
  • Vector files (KML, GeoJSON, or CZML) and small glTF files can be served as-is or tiled.
  • The upload options you choose determine which asset type is created. Cesium ion optimizes each asset type for typical usage in 3D geospatial applications.
  • Data can be uploaded through the REST API to automate your pipeline.
  • Similarly, the tiled data can be viewed in clients like CesiumJS that have built-in support for Cesium ion, or accessed directly through the REST API.
Cesium ion asset types
Cesium ion accepts a variety data formats and serves them as one of five types of assets:
Asset TypeDescription
3D TilesAn open specification for streaming massive heterogeneous 3D geospatial datasets. Check out Introducing 3D Tiles to learn more.
ImageryTMS and WMTS layers created from raster imagery.
TerrainA quantized-mesh tileset created from raster terrain.
glTFA binary glTF model.
NativeThe data is not processed by the tiling pipeline and is hosted in the same format it was uploaded as.
VectorCan serve .geojson directly, untiled.
Supported data formats
The following table lists accepted data formats and their corresponding asset types:
Format3D TilesTerrainImageryglTFNative
Zip Archive (.zip)✔✔✔✔
glTF (.gltf, .glb)✔✔
Filmbox (.fbx)✔✔
CityGML (.citygml, .xml, .gml)✔
CZML (.czml)✔
GeoJSON (.json, .geojson, .topojson)✔✔✔
KML (.kml, .kmz)✔✔
LASer (.las, .laz)✔
COLLADA (.dae)✔✔
Wavefront OBJ (.obj)✔✔
IFC (.ifc)✔
Revit (.rvt)✔
AutoCAD Drawing (.dwg)✔
Drawing Exchange Format (.dxf)✔
MicroStation Design (.dgn)✔
Floating Point Raster (.flt)✔✔
Arc/Info ASCII Grid (.asc)✔✔
Source Map (.src)✔✔
GeoTIFF (.tiff, .tif)✔✔
Erdas Imagine (.img)✔✔
USGS ASCII DEM and CDED (.dem)✔✔
JPEG (.jpg, .jpeg)✔
PNG (.png)✔
Cesium Terrain Database (.terraindb)✔
Digital Terrain Elevation Data (.dt0, .dt1, .dt2)✔
While not listed in the above table, raster sidecar files (.aux.xml, .tab, .tfw, .wld, .prj, .ovr, .rrd, etc.) and model textures (.jpg, .png, .bmp, .tga, .dds, etc.) are also supported. When in doubt, upload any additional files that came with your data.
We’re always adding support for more types of data. If you have a format you’d like us to support, let us know on the forum!
Upload instructions
  1. In Cesium ion on the My Assets tab, choose Add data.
  2. Select one or more files and push Open.
    You can continue to add more files, and they will all be uploaded using the same pipeline options.
    If you add multiple models at the same time, they will be merged into a single asset.
  3. Set the upload options using the information in the table below.
  4. After upload, if required, you can edit your data’s position, orientation, and scale using the location editor.
Source data"Kind of data" option to selectResulting asset typeUpload options and notes
Photogrammetry or LiDAR-derived mesh3D Capture3D TilesDraco compression • WebP Compression • Can be used with the location editor.
Point cloudsPoint Cloud3D TilesDraco compression • Can be used with the location editor.
3D buildings (KML/COLLADA)KML/COLLADA (tile as 3D Tiles)3D TilesDraco compression • Reference terrain (used to determine the height of features so they match the terrain you plan to use in your application)
3D buildings (CityGML)CityGML3D TilesDraco compression • Ignore colors • Ignore textures • Clamp to terrain • Clamp to terrain layer (if clamp to terrain is selected)
BIM/CAD models (RVT, IFC, DWG, DXF, DGN)BIM/CAD (3D Tiles) or BIM/CAD (3D Tiles + Database)3D TilesCan be used with location editor
Generic 3D models (OBJ, FBX)3D Model (tile as 3D Tiles)3D TilesCan be used with location editor
Simple 3D models3D Model (convert to glTF)glTFOptimize for rendering • Draco compression • For simple models that don't need to be tiled
Imagery (maps)Raster ImageryImagery (TMS and WMTS)
Terrain (heightmaps)Raster TerrainTerrain (quantized-mesh)Base terrain (terrain with which your raster data will be combined) • Height unit (the unit for the heights in the source data) • Height reference (the surface from which heights in the source data are measured)
Any data already in 3D Tiles3D Tiles3D Tiles
KML, CZML, or GeoJSONKML, CZML, or GeoJSON (host without tiling)Native
Vector TilesVector data (tile as 3D tiles)3D Tiles
Have a question?
The Cesium community forum is the fastest way to get an answer from the Cesium team.
