Cesium Releases in January 2026
In December, the team was in Orlando for I/ITSEC and Exton for our quarterly refactor. Then came all the jolly action with the Cesium-powered NORAD Tracks Santa app.
Today, we opened the call for presentations for the 2026 Cesium Developer Conference. Submit your talk ideas, and we look forward to seeing you in June!
CesiumJS 1.137 release
CesiumJS 1.137 is now available. Highlights of the release include:
- Fixes for positioning in workflows that delete and recreate labels.
- Fixes for texture coordinates in large billboard collections.
CesiumJS rendering a large collection of billboards with high precision, using data from the iTwin Feature Service.
Cesium for Unreal 2.22.0 release
Cesium for Unreal v2.22.0 is now available. Note that this release removes support for Unreal Engine 5.4; Unreal Engine 5.5 or later is required.
Other highlights of this release include:
- Replaced the "Auto Fill" button on
UCesiumFeaturesMetadataComponentwith "Add Properties". This allows metadata properties and feature ID sets to be selectively added to the component, rather than adding them all in bulk. - Added
EnableDoubleSidedCollisionstoACesium3DTilesetto allow intersections and collisions with geometry to also work when hitting "back" faces. - Added an optional glTF model post-processing stage after the tile loading step to modify their models before they are displayed.
- Added support for refreshing Cesium ion login tokens after they expire and the refresh token is still valid.
- Fixed a material generation bug on
UCesiumFeaturesMetadataComponentwhere user-made connections toIfnodes were not preserved. - Fixed deprecation warnings when compiling with Unreal Engine 5.5+ by replacing deprecated
GetInputsView()calls withFExpressionInputIterator.
This release also updates cesium-native from v0.55.0 to v0.56.0. See the changelog for a complete list of changes in cesium-native.
A list of metadata properties available in the New York region of Cesium OSM Buildings.
Cesium for Unity 1.21.0 release
Cesium for Unity v1.21.0 is now available. Highlights of this release include:
- Setting CesiumGeoreference.ellipsoid at runtime will now correctly update the Georeference and associated transforms.
- Fixed a bug that could cause
Cesium3DTileset::Updateto be called more than once per frame in the Editor. - Further improved stability when Unity reloads the AppDomain, such as when editing scripts or entering Play mode.
In addition to the above, this release updates cesium-native from v0.55.0 to v0.56.0. See the changelog for a complete list of changes in cesium-native.
Cesium for Omniverse 0.26.0 release
Cesium for Omniverse v0.26.0 is now available. Highlights of this release include:
- Fixed loading KTX2 textures with mipmaps.
Cesium ion updates
Design Tiler
- Reduced memory usage when processing IFC files.
- Added support for nested IFC properties.
- (experimental) Added support for geospatially locating IFC exports from Archicad.
- Fixed a stack-overflow issue when processing some IFC elements on Windows.
- If an IFC property has multiple data types, the data will be cast to the most general type.
Reality Tiler
- Fixed an issue where a CRS origin could be applied incorrectly if the origin was set from the command line and also found in a sidecar file.
Virtual City Systems uses CesiumJS to power open source 3D urban planning tools like VC Map and VC Solar, enabling scalable, interactive city modeling and analysis for municipalities.
Engineering design and consulting firm WSB is using Cesium-powered geospatial capabilities in Bentley Infrastructure Cloud Connect to ensure design flaws are caught early.
In 2025, NORAD Tracks Santa turned 70. Cesium is proud to help track Santa each Christmas Eve since 2012.
