Ktx2TranscodeTargets.h
3#include <CesiumImage/Library.h>
5namespace CesiumImage {
6
98
111 bool ETC1_RGB{};
113 bool ETC2_RGBA{};
115 bool BC1_RGB{};
117 bool BC3_RGBA{};
119 bool BC4_R{};
121 bool BC5_RG{};
123 bool BC7_RGBA{};
138};
139
213
214} // namespace CesiumImage
Classes that support reading, decoding, and manipulating images.
Definition ImageAsset.h:11
GpuCompressedPixelFormat
Supported GPU compressed pixel formats.
@ PVRTC2_4_RGBA
The data is a PVRTC2-compressed RGBA4444 texture.
@ BC5_RG
The data is a BC5-compressed RG88 texture.
@ BC3_RGBA
The data is a BC3-compressed RGBA5658 texture.
@ BC1_RGB
The data is a BC1-compressed RGB565 texture.
@ PVRTC2_4_RGB
The data is a PVRTC2-compressed RGB444 texture.
@ ASTC_4x4_RGBA
The data is a ASTC-compressed RGBA texture with a 4x4 block footprint.
@ PVRTC1_4_RGB
The data is a PVRTC1-compressed RGB444 texture.
@ BC4_R
The data is a BC4-compressed R8 texture.
@ ETC1_RGB
The data is an ETC1-compressed RGB888 texture.
@ BC7_RGBA
The data is a BC7-compressed RGBA8888 texture.
@ PVRTC1_4_RGBA
The data is a PVRTC1-compressed RGBA4444 texture.
@ ETC2_EAC_RG11
The data is a ETC2 RG11 EAC-compressed texture with two channels.
@ ETC2_RGBA
The data is an ETC2-compressed RGBA8888 texture.
@ ETC2_EAC_R11
The data is a ETC2 R11 EAC-compressed texture with a single channel.
GpuCompressedPixelFormat ETC1S_RGBA
The gpu pixel compression format to transcode RGBA ETC1S textures into. If NONE, it will be decompres...
The gpu pixel compression format to transcode Red ETC1S textures into. If NONE, it will be decompress...
Ktx2TranscodeTargets(const SupportedGpuCompressedPixelFormats &supportedFormats, bool preserveHighQuality)
Determine ideal transcode targets based on a list of supported gpu compressed formats.
GpuCompressedPixelFormat UASTC_R
The gpu pixel compression format to transcode Red UASTC textures into. If NONE, it will be decompress...
GpuCompressedPixelFormat UASTC_RGB
The gpu pixel compression format to transcode RGB UASTC textures into. If NONE, it will be decompress...
GpuCompressedPixelFormat UASTC_RGBA
The gpu pixel compression format to transcode RGBA UASTC textures into. If NONE, it will be decompres...
The gpu pixel compression format to transcode Red-Green ETC1S textures into, if one exists....
The gpu pixel compression format to transcode RGB ETC1S textures into. If NONE, it will be decompress...
The gpu pixel compression format to transcode Red-Green UASTC textures into. If NONE,...
Represents the status of support for all GpuCompressedPixelFormat s on a client platform.
bool BC3_RGBA
bool PVRTC1_4_RGBA
bool PVRTC2_4_RGB
bool ETC1_RGB
bool ASTC_4x4_RGBA
bool PVRTC1_4_RGB
bool PVRTC2_4_RGBA
bool ETC2_RGBA
bool BC1_RGB
bool BC5_RG
bool ETC2_EAC_RG11
bool ETC2_EAC_R11
bool BC7_RGBA
bool BC4_R
