ActivatedRasterOverlay.h
3#include <CesiumAsync/Future.h>
4#include <CesiumAsync/Promise.h>
5#include <CesiumAsync/SharedFuture.h>
6#include <CesiumGeometry/Rectangle.h>
7#include <CesiumGeospatial/Ellipsoid.h>
8#include <CesiumRasterOverlays/Library.h>
9#include <CesiumUtility/IntrusivePointer.h>
10#include <CesiumUtility/ReferenceCounted.h>
11
12#include <glm/vec2.hpp>
13
14namespace CesiumRasterOverlays {
15
16class RasterOverlay;
22
23} // namespace CesiumRasterOverlays
24
25namespace CesiumRasterOverlays {
26
74
83class CESIUMRASTEROVERLAYS_API ActivatedRasterOverlay
84 : public CesiumUtility::ReferenceCountedNonThreadSafe<
86public:
98 const RasterOverlayExternals& externals,
100 const CesiumGeospatial::Ellipsoid& ellipsoid
101 CESIUM_DEFAULT_ELLIPSOID) noexcept;
102
108
116 CesiumAsync::SharedFuture<void>& getReadyEvent();
117
123
129 getTileProvider() const noexcept;
130
133
146 const CesiumUtility::IntrusivePointer<RasterOverlayTileProvider>&
147 pTileProvider);
148
157
161
167 getPlaceholderTile() const noexcept;
168
171
193 const CesiumGeometry::Rectangle& rectangle,
194 const glm::dvec2& targetScreenPixels);
195
199 int64_t getTileDataBytes() const noexcept;
200
204 uint32_t getNumberOfTilesLoading() const noexcept;
205
217
237
261
268 void tick();
269
270private:
272 doLoad(RasterOverlayTile& tile, bool isThrottledLoad);
273
281 void beginTileLoad(bool isThrottledLoad) noexcept;
282
291 void finalizeTileLoad(bool isThrottledLoad) noexcept;
292
293 CesiumUtility::IntrusivePointer<const CesiumRasterOverlays::RasterOverlay>
294 _pOverlay;
295 CesiumUtility::IntrusivePointer<
297 _pPlaceholderTileProvider;
299 _pPlaceholderTile;
300 CesiumUtility::IntrusivePointer<
302 _pTileProvider;
303
304 int64_t _tileDataBytes;
305 int32_t _totalTilesCurrentlyLoading;
306 int32_t _throttledTilesCurrentlyLoading;
307
308 CesiumAsync::Promise<void> _readyPromise;
309 CesiumAsync::SharedFuture<void> _readyEvent;
310};
311
312} // namespace CesiumRasterOverlays
Definition Ellipsoid.h:39
A RasterOverlay that has been activated for use. While a RasterOverlayTileProvider can be used direct...
CesiumAsync::SharedFuture< void > & getReadyEvent()
Gets a shared future that resolves when this instance is ready to provide tiles.
const CesiumRasterOverlays::RasterOverlay & getOverlay() const noexcept
Gets the RasterOverlay that was activated to create this instance.
ActivatedRasterOverlay(const RasterOverlayExternals &externals, const CesiumUtility::IntrusivePointer< const RasterOverlay > &pOverlay, const CesiumGeospatial::Ellipsoid &ellipsoid=CesiumGeospatial::Ellipsoid::WGS84) noexcept
const CesiumRasterOverlays::RasterOverlayTile * getPlaceholderTile() const noexcept
Gets the placeholder tile created by the getPlaceholderTileProvider.
CesiumUtility::IntrusivePointer< CesiumRasterOverlays::RasterOverlayTile > getTile(const CesiumGeometry::Rectangle &rectangle, const glm::dvec2 &targetScreenPixels)
Returns a new RasterOverlayTile with the given specifications.
void setTileProvider(const CesiumUtility::IntrusivePointer< RasterOverlayTileProvider > &pTileProvider)
Sets the tile provider for this activated overlay.
bool loadTileThrottled(RasterOverlayTile &tile)
Loads a tile, unless there are too many tile loads already in progress.
Returns the number of tiles that are currently loading.
void removeTile(RasterOverlayTile *pTile) noexcept
Removes a no-longer-referenced tile from this provider's cache and deletes it.
CesiumAsync::Future< RasterOverlayTileLoadResult > loadTile(RasterOverlayTile &tile)
Loads a tile immediately, without throttling requests.
void tick()
Ticks the underlying raster overlay. This should be called frequently, such as once per frame,...
const CesiumRasterOverlays::RasterOverlayTileProvider * getTileProvider() const noexcept
Gets the tile provider created for this activated overlay. This will be nullptr before getReadyEvent ...
const CesiumRasterOverlays::RasterOverlayTileProvider * getPlaceholderTileProvider() const noexcept
Gets the placeholder tile provider.
Gets the number of bytes of tile data that are currently loaded.
~ActivatedRasterOverlay() noexcept
Destroys the instance. Use addReference and releaseReference instead of destroying this instance dire...
External interfaces used by a RasterOverlay.
Provides individual tiles for a RasterOverlay on demand.
Raster image data for a tile in a quadtree.
The base class for a rasterized image that can be draped over a Cesium3DTilesSelection::Tileset....
Classes that support asynchronous operations.
Classes for raster overlays, which allow draping massive 2D textures over a model.
Utility classes for Cesium.
Holds a tile and its corresponding activated raster overlay. Used as the return value of ActivatedRas...
RasterOverlayTileLoadResult(const CesiumUtility::IntrusivePointer< ActivatedRasterOverlay > &pActivated_, const CesiumUtility::IntrusivePointer< RasterOverlayTile > &pTile_) noexcept
Constructs an instance.
CesiumUtility::IntrusivePointer< ActivatedRasterOverlay > pActivated
A CesiumUtility::IntrusivePointer to the ActivatedRasterOverlay used for this tile.
CesiumUtility::IntrusivePointer< RasterOverlayTile > pTile
A CesiumUtility::IntrusivePointer to the RasterOverlayTile used for this tile.
