UCesiumGeoJsonDocumentRasterOverlay Class Reference
#include <CesiumGeoJsonDocumentRasterOverlay.h>
Inheritance diagram for UCesiumGeoJsonDocumentRasterOverlay:
UCesiumRasterOverlay
ECesiumGeoJsonDocumentRasterOverlaySource Source
int64 IonAssetID
 The ID of the Cesium ion asset to use.
UCesiumIonServer * CesiumIonServer
 The Cesium ion Server from which this raster overlay is loaded.
FCesiumGeoJsonDocument GeoJsonDocument
 A FCesiumGeoJsonDocument to display.
FString Url
 A URL to load a GeoJSON document from.
TMap< FString, FString > RequestHeaders
 Headers to use while making a request to Url to load a GeoJSON document.
int32 MipLevels = 0
 The number of mip levels to generate for each tile of this raster overlay.
FCesiumVectorStyle DefaultStyle
 The default style to use for this raster overlay.
FCesiumGeoJsonDocumentRasterOverlayOnDocumentLoadedCallback OnDocumentLoaded
 A callback that will be called when the document has been loaded.
- Public Attributes inherited from UCesiumRasterOverlay
FString MaterialLayerKey = "Overlay0"
 The key to use to match this overlay to a material layer.
FRasterOverlayRendererOptions rendererOptions
 Sets the texture filter and texture group of raster tile images.
Protected Member Functions
virtual std::unique_ptr< CesiumRasterOverlays::RasterOverlay > CreateOverlay (const CesiumRasterOverlays::RasterOverlayOptions &options={}) override
- Protected Member Functions inherited from UCesiumRasterOverlay
Cesium3DTilesSelection::Tileset * FindTileset () const
virtual void OnAdd (Cesium3DTilesSelection::Tileset *pTileset, CesiumRasterOverlays::RasterOverlay *pOverlay)
virtual void OnRemove (Cesium3DTilesSelection::Tileset *pTileset, CesiumRasterOverlays::RasterOverlay *pOverlay)
Additional Inherited Members
- Public Member Functions inherited from UCesiumRasterOverlay
 UCesiumRasterOverlay ()
void AddToTileset ()
 Displays this raster overlay on its owning Cesium 3D Tileset Actor, without changing its activation state.
void RemoveFromTileset ()
 Stops displaying this raster overlay on its owning Cesium 3D Tileset Actor.
void Refresh ()
double GetMaximumScreenSpaceError () const
void SetMaximumScreenSpaceError (double Value)
int32 GetMaximumTextureSize () const
void SetMaximumTextureSize (int32 Value)
int32 GetMaximumSimultaneousTileLoads () const
void SetMaximumSimultaneousTileLoads (int32 Value)
int64 GetSubTileCacheBytes () const
void SetSubTileCacheBytes (int64 Value)
 Activates this raster overlay, which will display it on the Cesium3DTileset to which the component is attached, if it isn't already displayed.
 Deactivates this raster overlay.
virtual bool IsReadyForFinishDestroy () override
- Protected Attributes inherited from UCesiumRasterOverlay
double MaximumScreenSpaceError = 2.0
int32 MaximumTextureSize = 2048
int32 MaximumSimultaneousTileLoads = 20
int64 SubTileCacheBytes = 16 * 1024 * 1024
bool ShowCreditsOnScreen
 Whether or not to show credits of this raster overlay on screen.
Definition at line 44 of file CesiumGeoJsonDocumentRasterOverlay.h.
◆ CreateOverlay()
virtual std::unique_ptr< CesiumRasterOverlays::RasterOverlay > UCesiumGeoJsonDocumentRasterOverlay::CreateOverlay ( const CesiumRasterOverlays::RasterOverlayOptions & options = {})
overrideprotectedvirtual
◆ CesiumIonServer
UCesiumIonServer* UCesiumGeoJsonDocumentRasterOverlay::CesiumIonServer
Definition at line 76 of file CesiumGeoJsonDocumentRasterOverlay.h.
◆ DefaultStyle
FCesiumVectorStyle UCesiumGeoJsonDocumentRasterOverlay::DefaultStyle
If no style is set on a GeoJSON object or any of its parents, this style will be used instead.
Definition at line 135 of file CesiumGeoJsonDocumentRasterOverlay.h.
◆ GeoJsonDocument
FCesiumGeoJsonDocument UCesiumGeoJsonDocumentRasterOverlay::GeoJsonDocument
Definition at line 88 of file CesiumGeoJsonDocumentRasterOverlay.h.
◆ IonAssetID
int64 UCesiumGeoJsonDocumentRasterOverlay::IonAssetID
Definition at line 63 of file CesiumGeoJsonDocumentRasterOverlay.h.
◆ MipLevels
int32 UCesiumGeoJsonDocumentRasterOverlay::MipLevels = 0
Additional mip levels can improve the visual quality of tiles farther from the camera at the cost of additional rasterization time to create each mip level.
Definition at line 126 of file CesiumGeoJsonDocumentRasterOverlay.h.
◆ OnDocumentLoaded
FCesiumGeoJsonDocumentRasterOverlayOnDocumentLoadedCallback UCesiumGeoJsonDocumentRasterOverlay::OnDocumentLoaded
Definition at line 141 of file CesiumGeoJsonDocumentRasterOverlay.h.
◆ RequestHeaders
TMap<FString, FString> UCesiumGeoJsonDocumentRasterOverlay::RequestHeaders
Definition at line 112 of file CesiumGeoJsonDocumentRasterOverlay.h.
◆ Source
ECesiumGeoJsonDocumentRasterOverlaySource UCesiumGeoJsonDocumentRasterOverlay::Source
Initial value:
Definition at line 50 of file CesiumGeoJsonDocumentRasterOverlay.h.
◆ Url
FString UCesiumGeoJsonDocumentRasterOverlay::Url
Definition at line 100 of file CesiumGeoJsonDocumentRasterOverlay.h.
