UCesiumWebMapServiceRasterOverlay Class Reference
A raster overlay that directly accesses a Web Map Service (WMS) server. More...
#include <CesiumWebMapServiceRasterOverlay.h>
Inheritance diagram for UCesiumWebMapServiceRasterOverlay:
UCesiumRasterOverlay
FString BaseUrl
 The base url of the Web Map Service (WMS).
FString Layers
 Comma-separated layer names to request from the server.
int32 TileWidth = 256
 Image width.
int32 TileHeight = 256
 Image height.
int32 MinimumLevel = 0
 Minimum zoom level.
int32 MaximumLevel = 14
 Maximum zoom level.
TMap< FString, FString > RequestHeaders
 HTTP headers to be attached to each request made for this raster overlay.
- Public Attributes inherited from UCesiumRasterOverlay
FString MaterialLayerKey = "Overlay0"
 The key to use to match this overlay to a material layer.
FRasterOverlayRendererOptions rendererOptions
 Sets the texture filter and texture group of raster tile images.
Protected Member Functions
virtual std::unique_ptr< CesiumRasterOverlays::RasterOverlay > CreateOverlay (const CesiumRasterOverlays::RasterOverlayOptions &options={}) override
- Protected Member Functions inherited from UCesiumRasterOverlay
Cesium3DTilesSelection::Tileset * FindTileset () const
virtual void OnAdd (Cesium3DTilesSelection::Tileset *pTileset, CesiumRasterOverlays::RasterOverlay *pOverlay)
virtual void OnRemove (Cesium3DTilesSelection::Tileset *pTileset, CesiumRasterOverlays::RasterOverlay *pOverlay)
Additional Inherited Members
- Public Member Functions inherited from UCesiumRasterOverlay
 UCesiumRasterOverlay ()
void AddToTileset ()
 Displays this raster overlay on its owning Cesium 3D Tileset Actor, without changing its activation state.
void RemoveFromTileset ()
 Stops displaying this raster overlay on its owning Cesium 3D Tileset Actor.
void Refresh ()
double GetMaximumScreenSpaceError () const
void SetMaximumScreenSpaceError (double Value)
int32 GetMaximumTextureSize () const
void SetMaximumTextureSize (int32 Value)
int32 GetMaximumSimultaneousTileLoads () const
void SetMaximumSimultaneousTileLoads (int32 Value)
int64 GetSubTileCacheBytes () const
void SetSubTileCacheBytes (int64 Value)
 Activates this raster overlay, which will display it on the Cesium3DTileset to which the component is attached, if it isn't already displayed.
 Deactivates this raster overlay.
virtual bool IsReadyForFinishDestroy () override
- Protected Attributes inherited from UCesiumRasterOverlay
double MaximumScreenSpaceError = 2.0
int32 MaximumTextureSize = 2048
int32 MaximumSimultaneousTileLoads = 20
int64 SubTileCacheBytes = 16 * 1024 * 1024
bool ShowCreditsOnScreen
 Whether or not to show credits of this raster overlay on screen.
https://www.ogc.org/standards/wms
Definition at line 15 of file CesiumWebMapServiceRasterOverlay.h.
◆ CreateOverlay()
virtual std::unique_ptr< CesiumRasterOverlays::RasterOverlay > UCesiumWebMapServiceRasterOverlay::CreateOverlay ( const CesiumRasterOverlays::RasterOverlayOptions & options = {})
overrideprotectedvirtual
◆ BaseUrl
FString UCesiumWebMapServiceRasterOverlay::BaseUrl
◆ Layers
FString UCesiumWebMapServiceRasterOverlay::Layers
Definition at line 32 of file CesiumWebMapServiceRasterOverlay.h.
◆ MaximumLevel
int32 UCesiumWebMapServiceRasterOverlay::MaximumLevel = 14
Maximum zoom level.
Definition at line 76 of file CesiumWebMapServiceRasterOverlay.h.
◆ MinimumLevel
int32 UCesiumWebMapServiceRasterOverlay::MinimumLevel = 0
Minimum zoom level.
Take care when specifying this that the number of tiles at the minimum level is small, such as four or less. A larger number is likely to result in rendering problems.
Definition at line 66 of file CesiumWebMapServiceRasterOverlay.h.
◆ RequestHeaders
TMap<FString, FString> UCesiumWebMapServiceRasterOverlay::RequestHeaders
Definition at line 82 of file CesiumWebMapServiceRasterOverlay.h.
◆ TileHeight
int32 UCesiumWebMapServiceRasterOverlay::TileHeight = 256
Image height.
Definition at line 52 of file CesiumWebMapServiceRasterOverlay.h.
◆ TileWidth
int32 UCesiumWebMapServiceRasterOverlay::TileWidth = 256
Image width.
Definition at line 42 of file CesiumWebMapServiceRasterOverlay.h.
