UCesiumTileMapServiceRasterOverlay Class Reference
A raster overlay that directly accesses a Tile Map Service (TMS) server. More...
#include <CesiumTileMapServiceRasterOverlay.h>
Inheritance diagram for UCesiumTileMapServiceRasterOverlay:
UCesiumRasterOverlay
FString Url
 The base URL of the Tile Map Service (TMS).
bool bSpecifyZoomLevels = false
 True to directly specify minum and maximum zoom levels available from the server, or false to automatically determine the minimum and maximum zoom levels from the server's tilemapresource.xml file.
int32 MinimumLevel = 0
 Minimum zoom level.
int32 MaximumLevel = 10
 Maximum zoom level.
TMap< FString, FString > RequestHeaders
 HTTP headers to be attached to each request made for this raster overlay.
- Public Attributes inherited from UCesiumRasterOverlay
FString MaterialLayerKey = "Overlay0"
 The key to use to match this overlay to a material layer.
FRasterOverlayRendererOptions rendererOptions
 Sets the texture filter and texture group of raster tile images.
Protected Member Functions
virtual std::unique_ptr< CesiumRasterOverlays::RasterOverlay > CreateOverlay (const CesiumRasterOverlays::RasterOverlayOptions &options={}) override
- Protected Member Functions inherited from UCesiumRasterOverlay
Cesium3DTilesSelection::Tileset * FindTileset () const
virtual void OnAdd (Cesium3DTilesSelection::Tileset *pTileset, CesiumRasterOverlays::RasterOverlay *pOverlay)
virtual void OnRemove (Cesium3DTilesSelection::Tileset *pTileset, CesiumRasterOverlays::RasterOverlay *pOverlay)
Additional Inherited Members
- Public Member Functions inherited from UCesiumRasterOverlay
 UCesiumRasterOverlay ()
void AddToTileset ()
 Displays this raster overlay on its owning Cesium 3D Tileset Actor, without changing its activation state.
void RemoveFromTileset ()
 Stops displaying this raster overlay on its owning Cesium 3D Tileset Actor.
void Refresh ()
double GetMaximumScreenSpaceError () const
void SetMaximumScreenSpaceError (double Value)
int32 GetMaximumTextureSize () const
void SetMaximumTextureSize (int32 Value)
int32 GetMaximumSimultaneousTileLoads () const
void SetMaximumSimultaneousTileLoads (int32 Value)
int64 GetSubTileCacheBytes () const
void SetSubTileCacheBytes (int64 Value)
 Activates this raster overlay, which will display it on the Cesium3DTileset to which the component is attached, if it isn't already displayed.
 Deactivates this raster overlay.
virtual bool IsReadyForFinishDestroy () override
- Protected Attributes inherited from UCesiumRasterOverlay
double MaximumScreenSpaceError = 2.0
int32 MaximumTextureSize = 2048
int32 MaximumSimultaneousTileLoads = 20
int64 SubTileCacheBytes = 16 * 1024 * 1024
bool ShowCreditsOnScreen
 Whether or not to show credits of this raster overlay on screen.
If you're using a Tile Map Service via Cesium ion, use the "Cesium ion Raster Overlay" component instead.
Definition at line 16 of file CesiumTileMapServiceRasterOverlay.h.
◆ CreateOverlay()
virtual std::unique_ptr< CesiumRasterOverlays::RasterOverlay > UCesiumTileMapServiceRasterOverlay::CreateOverlay ( const CesiumRasterOverlays::RasterOverlayOptions & options = {})
overrideprotectedvirtual
◆ bSpecifyZoomLevels
bool UCesiumTileMapServiceRasterOverlay::bSpecifyZoomLevels = false
Definition at line 33 of file CesiumTileMapServiceRasterOverlay.h.
◆ MaximumLevel
int32 UCesiumTileMapServiceRasterOverlay::MaximumLevel = 10
Maximum zoom level.
Definition at line 53 of file CesiumTileMapServiceRasterOverlay.h.
◆ MinimumLevel
int32 UCesiumTileMapServiceRasterOverlay::MinimumLevel = 0
Minimum zoom level.
Definition at line 43 of file CesiumTileMapServiceRasterOverlay.h.
◆ RequestHeaders
TMap<FString, FString> UCesiumTileMapServiceRasterOverlay::RequestHeaders
Definition at line 59 of file CesiumTileMapServiceRasterOverlay.h.
◆ Url
FString UCesiumTileMapServiceRasterOverlay::Url
Definition at line 25 of file CesiumTileMapServiceRasterOverlay.h.
