UCesiumUrlTemplateRasterOverlay Class Reference
A raster overlay that loads tiles from a templated URL. More...
#include <CesiumUrlTemplateRasterOverlay.h>
Inheritance diagram for UCesiumUrlTemplateRasterOverlay:
UCesiumRasterOverlay
FString TemplateUrl
 The URL containing template parameters that will be substituted when loading tiles.
ECesiumUrlTemplateRasterOverlayProjection Projection
 The type of projection used to project the imagery onto the globe.
bool bSpecifyTilingScheme = false
 Set this to true to specify the quadtree tiling scheme according to the specified root tile numbers and projected bounding rectangle.
int32 RootTilesX = 1
 If specified, this determines the number of tiles at the root of the quadtree tiling scheme in the X direction.
int32 RootTilesY = 1
 If specified, this determines the number of tiles at the root of the quadtree tiling scheme in the Y direction.
double RectangleWest = -180
 The west boundary of the bounding rectangle used for the quadtree tiling scheme.
double RectangleSouth = -90
 The south boundary of the bounding rectangle used for the quadtree tiling scheme.
double RectangleEast = 180
 The east boundary of the bounding rectangle used for the quadtree tiling scheme.
double RectangleNorth = 90
 The north boundary of the bounding rectangle used for the quadtree tiling scheme.
int32 MinimumLevel = 0
 Minimum zoom level.
int32 MaximumLevel = 25
 Maximum zoom level.
int32 TileWidth = 256
 The pixel width of the image tiles.
int32 TileHeight = 256
 The pixel height of the image tiles.
TMap< FString, FString > RequestHeaders
 HTTP headers to be attached to each request made for this raster overlay.
- Public Attributes inherited from UCesiumRasterOverlay
FString MaterialLayerKey = "Overlay0"
 The key to use to match this overlay to a material layer.
FRasterOverlayRendererOptions rendererOptions
 Sets the texture filter and texture group of raster tile images.
Protected Member Functions
virtual std::unique_ptr< CesiumRasterOverlays::RasterOverlay > CreateOverlay (const CesiumRasterOverlays::RasterOverlayOptions &options={}) override
- Protected Member Functions inherited from UCesiumRasterOverlay
Cesium3DTilesSelection::Tileset * FindTileset () const
virtual void OnAdd (Cesium3DTilesSelection::Tileset *pTileset, CesiumRasterOverlays::RasterOverlay *pOverlay)
virtual void OnRemove (Cesium3DTilesSelection::Tileset *pTileset, CesiumRasterOverlays::RasterOverlay *pOverlay)
Additional Inherited Members
- Public Member Functions inherited from UCesiumRasterOverlay
 UCesiumRasterOverlay ()
void AddToTileset ()
 Displays this raster overlay on its owning Cesium 3D Tileset Actor, without changing its activation state.
void RemoveFromTileset ()
 Stops displaying this raster overlay on its owning Cesium 3D Tileset Actor.
void Refresh ()
double GetMaximumScreenSpaceError () const
void SetMaximumScreenSpaceError (double Value)
int32 GetMaximumTextureSize () const
void SetMaximumTextureSize (int32 Value)
int32 GetMaximumSimultaneousTileLoads () const
void SetMaximumSimultaneousTileLoads (int32 Value)
int64 GetSubTileCacheBytes () const
void SetSubTileCacheBytes (int64 Value)
 Activates this raster overlay, which will display it on the Cesium3DTileset to which the component is attached, if it isn't already displayed.
 Deactivates this raster overlay.
virtual bool IsReadyForFinishDestroy () override
- Protected Attributes inherited from UCesiumRasterOverlay
double MaximumScreenSpaceError = 2.0
int32 MaximumTextureSize = 2048
int32 MaximumSimultaneousTileLoads = 20
int64 SubTileCacheBytes = 16 * 1024 * 1024
bool ShowCreditsOnScreen
 Whether or not to show credits of this raster overlay on screen.
Definition at line 31 of file CesiumUrlTemplateRasterOverlay.h.
◆ CreateOverlay()
virtual std::unique_ptr< CesiumRasterOverlays::RasterOverlay > UCesiumUrlTemplateRasterOverlay::CreateOverlay ( const CesiumRasterOverlays::RasterOverlayOptions & options = {})
overrideprotectedvirtual
◆ bSpecifyTilingScheme
bool UCesiumUrlTemplateRasterOverlay::bSpecifyTilingScheme = false
If false, the tiling scheme will be deduced from the projection.
Definition at line 86 of file CesiumUrlTemplateRasterOverlay.h.
◆ MaximumLevel
int32 UCesiumUrlTemplateRasterOverlay::MaximumLevel = 25
Maximum zoom level.
Definition at line 201 of file CesiumUrlTemplateRasterOverlay.h.
◆ MinimumLevel
int32 UCesiumUrlTemplateRasterOverlay::MinimumLevel = 0
Minimum zoom level.
Take care when specifying this that the number of tiles at the minimum level is small, such as four or less. A larger number is likely to result in rendering problems.
Definition at line 191 of file CesiumUrlTemplateRasterOverlay.h.
◆ Projection
ECesiumUrlTemplateRasterOverlayProjection UCesiumUrlTemplateRasterOverlay::Projection
Initial value:
For instance, EPSG:4326 uses geographic projection and EPSG:3857 uses Web Mercator.
Definition at line 77 of file CesiumUrlTemplateRasterOverlay.h.
◆ RectangleEast
double UCesiumUrlTemplateRasterOverlay::RectangleEast = 180
Specified in longitude degrees in the range [-180, 180].
Only applicable if "Specify Tiling Scheme" is set to true.
Definition at line 161 of file CesiumUrlTemplateRasterOverlay.h.
◆ RectangleNorth
double UCesiumUrlTemplateRasterOverlay::RectangleNorth = 90
Specified in latitude degrees in the range [-90, 90].
Definition at line 177 of file CesiumUrlTemplateRasterOverlay.h.
◆ RectangleSouth
double UCesiumUrlTemplateRasterOverlay::RectangleSouth = -90
Definition at line 145 of file CesiumUrlTemplateRasterOverlay.h.
◆ RectangleWest
double UCesiumUrlTemplateRasterOverlay::RectangleWest = -180
Definition at line 128 of file CesiumUrlTemplateRasterOverlay.h.
◆ RequestHeaders
TMap<FString, FString> UCesiumUrlTemplateRasterOverlay::RequestHeaders
Definition at line 227 of file CesiumUrlTemplateRasterOverlay.h.
◆ RootTilesX
int32 UCesiumUrlTemplateRasterOverlay::RootTilesX = 1
Definition at line 99 of file CesiumUrlTemplateRasterOverlay.h.
◆ RootTilesY
int32 UCesiumUrlTemplateRasterOverlay::RootTilesY = 1
Definition at line 112 of file CesiumUrlTemplateRasterOverlay.h.
◆ TemplateUrl
FString UCesiumUrlTemplateRasterOverlay::TemplateUrl
The following template parameters are supported in url:
  • {x} - The tile X coordinate in the tiling scheme, where 0 is the westernmost tile.
  • {y} - The tile Y coordinate in the tiling scheme, where 0 is the southernmost tile.
  • {z} - The level of the tile in the tiling scheme, where 0 is the root of the quadtree pyramid.
  • {reverseX} - The tile X coordinate in the tiling scheme, where 0 is the easternmost tile.
  • {reverseY} - The tile Y coordinate in the tiling scheme, where 0 is the northernmost tile.
  • {reverseZ} - The tile Z coordinate in the tiling scheme, where 0 is equivalent to urlTemplateOptions.maximumLevel.
  • {westDegrees} - The western edge of the tile in geodetic degrees.
  • {southDegrees} - The southern edge of the tile in geodetic degrees.
  • {eastDegrees} - The eastern edge of the tile in geodetic degrees.
  • {northDegrees} - The northern edge of the tile in geodetic degrees.
  • {minimumX} - The minimum X coordinate of the tile's projected coordinates.
  • {minimumY} - The minimum Y coordinate of the tile's projected coordinates.
  • {maximumX} - The maximum X coordinate of the tile's projected coordinates.
  • {maximumY} - The maximum Y coordinate of the tile's projected coordinates.
  • {width} - The width of each tile in pixels.
  • {height} - The height of each tile in pixels.
Definition at line 69 of file CesiumUrlTemplateRasterOverlay.h.
◆ TileHeight
int32 UCesiumUrlTemplateRasterOverlay::TileHeight = 256
Definition at line 221 of file CesiumUrlTemplateRasterOverlay.h.
◆ TileWidth
int32 UCesiumUrlTemplateRasterOverlay::TileWidth = 256
Definition at line 211 of file CesiumUrlTemplateRasterOverlay.h.
