UCesiumWebMapTileServiceRasterOverlay Class Reference
A raster overlay that directly accesses a Web Map Tile Service (WMTS) server. More...
#include <CesiumWebMapTileServiceRasterOverlay.h>
Inheritance diagram for UCesiumWebMapTileServiceRasterOverlay:
UCesiumRasterOverlay
virtual void Serialize (FArchive &Ar) override
- Public Member Functions inherited from UCesiumRasterOverlay
 UCesiumRasterOverlay ()
void AddToTileset ()
 Displays this raster overlay on its owning Cesium 3D Tileset Actor, without changing its activation state.
void RemoveFromTileset ()
 Stops displaying this raster overlay on its owning Cesium 3D Tileset Actor.
void Refresh ()
double GetMaximumScreenSpaceError () const
void SetMaximumScreenSpaceError (double Value)
int32 GetMaximumTextureSize () const
void SetMaximumTextureSize (int32 Value)
int32 GetMaximumSimultaneousTileLoads () const
void SetMaximumSimultaneousTileLoads (int32 Value)
int64 GetSubTileCacheBytes () const
void SetSubTileCacheBytes (int64 Value)
 Activates this raster overlay, which will display it on the Cesium3DTileset to which the component is attached, if it isn't already displayed.
 Deactivates this raster overlay.
virtual bool IsReadyForFinishDestroy () override
FString BaseUrl
 The base URL of the Web Map Tile Service (WMTS).
FString Layer
 The layer name for WMTS requests.
FString Style
 The style name for WMTS requests.
FString Format = "image/jpeg"
 The MIME type for images to retrieve from the server.
FString TileMatrixSetID
 The tile matrix set identifier for WMTS requests.
FString TileMatrixSetLabelPrefix
 The prefix to use for the tile matrix set labels.
bool bSpecifyTileMatrixSetLabels = false
 Set this to true to specify tile matrix set labels manually.
TArray< FString > TileMatrixSetLabels
 The manually specified tile matrix set labels.
bool UseWebMercatorProjection_DEPRECATED
ECesiumWebMapTileServiceRasterOverlayProjection Projection
 The type of projection used to project the WMTS imagery onto the globe.
bool bSpecifyTilingScheme = false
 Set this to true to specify the quadtree tiling scheme according to the specified root tile numbers and projected bounding rectangle.
int32 RootTilesX = 1
 The number of tiles corresponding to TileCol, also known as TileMatrixWidth.
int32 RootTilesY = 1
 The number of tiles corresponding to TileRow, also known as TileMatrixHeight.
double RectangleWest = -180
 The west boundary of the bounding rectangle used for the quadtree tiling scheme.
double RectangleSouth = -90
 The south boundary of the bounding rectangle used for the quadtree tiling scheme.
double RectangleEast = 180
 The east boundary of the bounding rectangle used for the quadtree tiling scheme.
double RectangleNorth = 90
 The north boundary of the bounding rectangle used for the quadtree tiling scheme.
bool bSpecifyZoomLevels = false
 Set this to true to directly specify the minimum and maximum zoom levels available from the server.
int32 MinimumLevel = 0
 Minimum zoom level.
int32 MaximumLevel = 25
 Maximum zoom level.
int32 TileWidth = 256
 The pixel width of the image tiles.
int32 TileHeight = 256
 The pixel height of the image tiles.
TMap< FString, FString > RequestHeaders
 HTTP headers to be attached to each request made for this raster overlay.
- Public Attributes inherited from UCesiumRasterOverlay
FString MaterialLayerKey = "Overlay0"
 The key to use to match this overlay to a material layer.
FRasterOverlayRendererOptions rendererOptions
 Sets the texture filter and texture group of raster tile images.
Protected Member Functions
virtual std::unique_ptr< CesiumRasterOverlays::RasterOverlay > CreateOverlay (const CesiumRasterOverlays::RasterOverlayOptions &options={}) override
- Protected Member Functions inherited from UCesiumRasterOverlay
Cesium3DTilesSelection::Tileset * FindTileset () const
virtual void OnAdd (Cesium3DTilesSelection::Tileset *pTileset, CesiumRasterOverlays::RasterOverlay *pOverlay)
virtual void OnRemove (Cesium3DTilesSelection::Tileset *pTileset, CesiumRasterOverlays::RasterOverlay *pOverlay)
Additional Inherited Members
- Protected Attributes inherited from UCesiumRasterOverlay
double MaximumScreenSpaceError = 2.0
int32 MaximumTextureSize = 2048
int32 MaximumSimultaneousTileLoads = 20
int64 SubTileCacheBytes = 16 * 1024 * 1024
bool ShowCreditsOnScreen
 Whether or not to show credits of this raster overlay on screen.
If you're using a Web Map Tile Service via Cesium ion, use the "Cesium ion Raster Overlay" component instead.
Definition at line 33 of file CesiumWebMapTileServiceRasterOverlay.h.
◆ CreateOverlay()
virtual std::unique_ptr< CesiumRasterOverlays::RasterOverlay > UCesiumWebMapTileServiceRasterOverlay::CreateOverlay ( const CesiumRasterOverlays::RasterOverlayOptions & options = {})
overrideprotectedvirtual
◆ Serialize()
virtual void UCesiumWebMapTileServiceRasterOverlay::Serialize ( FArchive & Ar)
overridevirtual
◆ BaseUrl
FString UCesiumWebMapTileServiceRasterOverlay::BaseUrl
This URL should not include query parameters. For example: https://tile.openstreetmap.org/{TileMatrix}/{TileCol}/{TileRow}.png
Definition at line 44 of file CesiumWebMapTileServiceRasterOverlay.h.
◆ bSpecifyTileMatrixSetLabels
bool UCesiumWebMapTileServiceRasterOverlay::bSpecifyTileMatrixSetLabels = false
If false, the labels will be constructed from the specified levels and prefix (if one is specified).
Definition at line 89 of file CesiumWebMapTileServiceRasterOverlay.h.
◆ bSpecifyTilingScheme
bool UCesiumWebMapTileServiceRasterOverlay::bSpecifyTilingScheme = false
If false, the tiling scheme will be deduced from the projection.
Definition at line 123 of file CesiumWebMapTileServiceRasterOverlay.h.
◆ bSpecifyZoomLevels
bool UCesiumWebMapTileServiceRasterOverlay::bSpecifyZoomLevels = false
If false, the minimum and maximum zoom levels will be retrieved from the server's tilemapresource.xml file.
Definition at line 224 of file CesiumWebMapTileServiceRasterOverlay.h.
◆ Format
FString UCesiumWebMapTileServiceRasterOverlay::Format = "image/jpeg"
Definition at line 62 of file CesiumWebMapTileServiceRasterOverlay.h.
◆ Layer
FString UCesiumWebMapTileServiceRasterOverlay::Layer
Definition at line 50 of file CesiumWebMapTileServiceRasterOverlay.h.
◆ MaximumLevel
int32 UCesiumWebMapTileServiceRasterOverlay::MaximumLevel = 25
Maximum zoom level.
Definition at line 248 of file CesiumWebMapTileServiceRasterOverlay.h.
◆ MinimumLevel
int32 UCesiumWebMapTileServiceRasterOverlay::MinimumLevel = 0
Minimum zoom level.
Take care when specifying this that the number of tiles at the minimum level is small, such as four or less. A larger number is likely to result in rendering problems.
Definition at line 238 of file CesiumWebMapTileServiceRasterOverlay.h.
◆ Projection
ECesiumWebMapTileServiceRasterOverlayProjection UCesiumWebMapTileServiceRasterOverlay::Projection
Initial value:
For instance, EPSG:4326 uses geographic projection and EPSG:3857 uses Web Mercator.
Definition at line 114 of file CesiumWebMapTileServiceRasterOverlay.h.
◆ RectangleEast
double UCesiumWebMapTileServiceRasterOverlay::RectangleEast = 180
Specified in longitude degrees in the range [-180, 180].
Only applicable if "Specify Tiling Scheme" is set to true.
Definition at line 200 of file CesiumWebMapTileServiceRasterOverlay.h.
◆ RectangleNorth
double UCesiumWebMapTileServiceRasterOverlay::RectangleNorth = 90
Specified in latitude degrees in the range [-90, 90].
Definition at line 216 of file CesiumWebMapTileServiceRasterOverlay.h.
◆ RectangleSouth
double UCesiumWebMapTileServiceRasterOverlay::RectangleSouth = -90
Definition at line 184 of file CesiumWebMapTileServiceRasterOverlay.h.
◆ RectangleWest
double UCesiumWebMapTileServiceRasterOverlay::RectangleWest = -180
Definition at line 167 of file CesiumWebMapTileServiceRasterOverlay.h.
◆ RequestHeaders
TMap<FString, FString> UCesiumWebMapTileServiceRasterOverlay::RequestHeaders
Definition at line 274 of file CesiumWebMapTileServiceRasterOverlay.h.
◆ RootTilesX
int32 UCesiumWebMapTileServiceRasterOverlay::RootTilesX = 1
If specified, this determines the number of tiles at the root of the quadtree tiling scheme in the X direction.
Definition at line 137 of file CesiumWebMapTileServiceRasterOverlay.h.
◆ RootTilesY
int32 UCesiumWebMapTileServiceRasterOverlay::RootTilesY = 1
If specified, this determines the number of tiles at the root of the quadtree tiling scheme in the Y direction.
Definition at line 151 of file CesiumWebMapTileServiceRasterOverlay.h.
◆ Style
FString UCesiumWebMapTileServiceRasterOverlay::Style
Definition at line 56 of file CesiumWebMapTileServiceRasterOverlay.h.
◆ TileHeight
int32 UCesiumWebMapTileServiceRasterOverlay::TileHeight = 256
Definition at line 268 of file CesiumWebMapTileServiceRasterOverlay.h.
◆ TileMatrixSetID
FString UCesiumWebMapTileServiceRasterOverlay::TileMatrixSetID
Definition at line 68 of file CesiumWebMapTileServiceRasterOverlay.h.
◆ TileMatrixSetLabelPrefix
FString UCesiumWebMapTileServiceRasterOverlay::TileMatrixSetLabelPrefix
For instance, setting "EPSG:4326:" as prefix generates label list ["EPSG:4326:0", "EPSG:4326:1", "EPSG:4326:2", ...] Only applicable when "Specify Tile Matrix Set Labels" is false.
Definition at line 81 of file CesiumWebMapTileServiceRasterOverlay.h.
◆ TileMatrixSetLabels
TArray<FString> UCesiumWebMapTileServiceRasterOverlay::TileMatrixSetLabels
Only applicable when "Specify Tile Matrix Set Labels" is true.
Definition at line 101 of file CesiumWebMapTileServiceRasterOverlay.h.
◆ TileWidth
int32 UCesiumWebMapTileServiceRasterOverlay::TileWidth = 256
Definition at line 258 of file CesiumWebMapTileServiceRasterOverlay.h.
◆ UseWebMercatorProjection_DEPRECATED
bool UCesiumWebMapTileServiceRasterOverlay::UseWebMercatorProjection_DEPRECATED
Definition at line 106 of file CesiumWebMapTileServiceRasterOverlay.h.
