CesiumPropertyAttribute.h
8#include "Kismet/BlueprintFunctionLibrary.h"
9#include "UObject/ObjectMacros.h"
10#include "CesiumPropertyAttribute.generated.h"
11
12namespace CesiumGltf {
13struct Model;
15} // namespace CesiumGltf
16
17/**
18 * @brief Reports the status of a FCesiumPropertyAttribute. If the property
19 * attribute cannot be accessed, this briefly indicates why.
20 */
21UENUM(BlueprintType)
23 /* The property attribute is valid. */
24 Valid = 0,
25 /* The property attribute instance was not initialized from an actual glTF
26 property attribute. */
28 /* The property attribute's class could not be found in the schema of the
29 metadata extension. */
31};
32
33/**
34 * A Blueprint-accessible wrapper for a glTF property attribute.
35 * Provides access to {@link FCesiumPropertyAttributeProperty} views of
36 * per-vertex metadata.
37 */
38USTRUCT(BlueprintType)
39struct CESIUMRUNTIME_API FCesiumPropertyAttribute {
40 GENERATED_USTRUCT_BODY()
41
42public:
43 /**
44 * Construct an empty property attribute instance.
45 */
49
50 /**
51 * Constructs a property attribute from the given glTF.
52 *
53 * @param model The model that stores EXT_structural_metadata.
54 * @param primitive The primitive that contains the target property attribute.
55 * @param propertyAttribute The target property attribute.
56 */
58 const CesiumGltf::Model& model,
59 const CesiumGltf::MeshPrimitive& primitive,
60 const CesiumGltf::PropertyAttribute& propertyAttribute)
62 model,
63 primitive,
64 propertyAttribute,
65 FCesiumMetadataEnumCollection::GetOrCreateFromModel(model)) {}
66
67 /**
68 * Constructs a property attribute from the given glTF.
69 *
70 * @param model The model that stores EXT_structural_metadata.
71 * @param primitive The primitive that contains the target property attribute.
72 * @param propertyAttribute The target property attribute.
73 * @param pEnumCollection The enum collection to use, if any.
74 */
76 const CesiumGltf::Model& model,
77 const CesiumGltf::MeshPrimitive& primitive,
78 const CesiumGltf::PropertyAttribute& propertyAttribute,
79 const TSharedPtr<FCesiumMetadataEnumCollection>& pEnumCollection);
80
81 /**
82 * Gets the name of the metadata class that this property attribute conforms
83 * to.
84 */
85 FString getClassName() const { return _className; }
86
87private:
89 FString _name;
90 FString _className;
91
92 int64 _elementCount;
93 TMap<FString, FCesiumPropertyAttributeProperty> _properties;
94
96};
97
98UCLASS()
100 : public UBlueprintFunctionLibrary {
101 GENERATED_BODY()
102
103public:
104 /**
105 * Gets the status of the property attribute. If an error occurred while
106 * parsing the property attribute from the glTF extension, this briefly
107 * conveys why.
108 *
109 * @param PropertyAttribute The property attribute.
110 */
111 UFUNCTION(
112 BlueprintCallable,
113 BlueprintPure,
114 Category = "Cesium|Metadata|PropertyAttribute")
116 UPARAM(ref) const FCesiumPropertyAttribute& PropertyAttribute);
117
118 /**
119 * Gets the name of the property attribute. If no name was specified in the
120 * glTF extension, this returns an empty string.
121 *
122 * @param PropertyAttribute The property attribute.
123 */
124 UFUNCTION(
125 BlueprintCallable,
126 BlueprintPure,
127 Category = "Cesium|Metadata|PropertyAttribute")
128 static const FString& GetPropertyAttributeName(
129 UPARAM(ref) const FCesiumPropertyAttribute& PropertyAttribute);
130
131 /**
132 * Gets all the properties of the property attribute, mapped by property name.
133 *
134 * @param PropertyAttribute The property attribute.
135 */
136 UFUNCTION(
137 BlueprintCallable,
138 BlueprintPure,
139 Category = "Cesium|Metadata|PropertyAttribute")
140 static const TMap<FString, FCesiumPropertyAttributeProperty>&
141 GetProperties(UPARAM(ref) const FCesiumPropertyAttribute& PropertyAttribute);
142
143 /**
144 * Gets the names of the properties in this property attribute.
145 *
146 * @param PropertyAttribute The property attribute.
147 */
148 UFUNCTION(
149 BlueprintCallable,
150 BlueprintPure,
151 Category = "Cesium|Metadata|PropertyAttribute")
152 static const TArray<FString>
154 const FCesiumPropertyAttribute& PropertyAttribute);
155
156 /**
157 * Retrieve a FCesiumPropertyAttributeProperty by name. If the property
158 * attribute does not contain a property with that name, this returns an
159 * invalid FCesiumPropertyAttributeProperty.
160 *
161 * @param PropertyAttribute The property attribute.
162 * @param PropertyName The name of the property to find.
163 */
164 UFUNCTION(
165 BlueprintCallable,
166 BlueprintPure,
167 Category = "Cesium|Metadata|PropertyAttribute")
169 UPARAM(ref) const FCesiumPropertyAttribute& PropertyAttribute,
170 const FString& PropertyName);
171
172 /**
173 * Gets all of the property values for the given vertex index, mapped by
174 * property name. This will only include values from valid property attribute
175 * properties.
176 *
177 * If the index is out-of-bounds, the returned map will be empty.
178 *
179 * @param PropertyAttribute The property attribute.
180 * @param Index The index of the target vertex.
181 * @return The property values mapped by property name.
182 */
183 UFUNCTION(
184 BlueprintCallable,
185 BlueprintPure,
186 Category = "Cesium|Metadata|PropertyAttribute")
188 UPARAM(ref) const FCesiumPropertyAttribute& PropertyAttribute,
189 int64 Index);
190};
ECesiumPropertyAttributeStatus
static const TArray< FString > GetPropertyNames(UPARAM(ref) const FCesiumPropertyAttribute &PropertyAttribute)
static TMap< FString, FCesiumMetadataValue > GetMetadataValuesAtIndex(UPARAM(ref) const FCesiumPropertyAttribute &PropertyAttribute, int64 Index)
Gets all of the property values for the given vertex index, mapped by property name.
static const FCesiumPropertyAttributeProperty & FindProperty(UPARAM(ref) const FCesiumPropertyAttribute &PropertyAttribute, const FString &PropertyName)
static const TMap< FString, FCesiumPropertyAttributeProperty > & GetProperties(UPARAM(ref) const FCesiumPropertyAttribute &PropertyAttribute)
static const FString & GetPropertyAttributeName(UPARAM(ref) const FCesiumPropertyAttribute &PropertyAttribute)
static ECesiumPropertyAttributeStatus GetPropertyAttributeStatus(UPARAM(ref) const FCesiumPropertyAttribute &PropertyAttribute)
Contains a set of enum definitions obtained from a CesiumGltf::Schema.
A Blueprint-accessible wrapper for a glTF property attribute property in EXT_structural_metadata.
Gets the name of the metadata class that this property attribute conforms to.
friend class UCesiumPropertyAttributeBlueprintLibrary
FCesiumPropertyAttribute()
FCesiumPropertyAttribute(const CesiumGltf::Model &model, const CesiumGltf::MeshPrimitive &primitive, const CesiumGltf::PropertyAttribute &propertyAttribute)
FCesiumPropertyAttribute(const CesiumGltf::Model &model, const CesiumGltf::MeshPrimitive &primitive, const CesiumGltf::PropertyAttribute &propertyAttribute, const TSharedPtr< FCesiumMetadataEnumCollection > &pEnumCollection)
