FCesiumMetadataEnumCollection Struct Reference
Contains a set of enum definitions obtained from a CesiumGltf::Schema. More...
#include <CesiumMetadataEnum.h>
 FCesiumMetadataEnumCollection ()
 Creates a new FCesiumMetadataEnumCollection without any enum definitions.
 FCesiumMetadataEnumCollection (const CesiumGltf::Schema &Schema)
 Creates a new FCesiumMetadataEnumCollection with definitions obtained from the enums property of the given CesiumGltf::Schema.
TSharedPtr< FCesiumMetadataEnum > Get (const FString &InKey) const
 Obtains the FCesiumMetadataEnum corresponding to the given key.
static TSharedRef< FCesiumMetadataEnumCollection > GetOrCreateFromSchema (CesiumGltf::Schema &Schema)
 Attempts to obtain a FCesiumMetadataEnumCollection from the given schema if one has already been created, or creates one if not.
static TSharedPtr< FCesiumMetadataEnumCollection > GetOrCreateFromModel (const CesiumGltf::Model &Model)
 Attempts to obtain a FCesiumMetadataEnumCollection from a schema attached to the given model, or returns an invalid TSharedPtr if no schema is present.
Definition at line 66 of file CesiumMetadataEnum.h.
◆ FCesiumMetadataEnumCollection() [1/2]
FCesiumMetadataEnumCollection::FCesiumMetadataEnumCollection ( )
Definition at line 74 of file CesiumMetadataEnum.h.
◆ FCesiumMetadataEnumCollection() [2/2]
FCesiumMetadataEnumCollection::FCesiumMetadataEnumCollection ( const CesiumGltf::Schema & Schema)
In most cases, FCesiumMetadataEnumCollection::GetOrCreateFromSchema should be used instead.
◆ Get()
TSharedPtr< FCesiumMetadataEnum > FCesiumMetadataEnumCollection::Get ( const FString & InKey) const
The input key should be one of the keys in the enums of the CesiumGltf::Schema that this collection is based on.
◆ GetOrCreateFromModel()
static TSharedPtr< FCesiumMetadataEnumCollection > FCesiumMetadataEnumCollection::GetOrCreateFromModel ( const CesiumGltf::Model & Model)
static
This method is equivalent to looking up the schema from the model yourself and calling FCesiumMetadataEnumCollection::GetOrCreateFromSchema.
ModelThe model to lookup the schema from.
◆ GetOrCreateFromSchema()
static TSharedRef< FCesiumMetadataEnumCollection > FCesiumMetadataEnumCollection::GetOrCreateFromSchema ( CesiumGltf::Schema & Schema)
static
This method utilizes a custom extension on the CesiumGltf::Schema to prevent duplicate enum collections from being created for the same schema, avoiding unnecessary allocations.
SchemaThe schema to create an enum collection from.
