UCesiumPropertyAttributeBlueprintLibrary Class Reference
#include <CesiumPropertyAttribute.h>
Inheritance diagram for UCesiumPropertyAttributeBlueprintLibrary:
static ECesiumPropertyAttributeStatus GetPropertyAttributeStatus (UPARAM(ref) const FCesiumPropertyAttribute &PropertyAttribute)
 Gets the status of the property attribute.
static const FString & GetPropertyAttributeName (UPARAM(ref) const FCesiumPropertyAttribute &PropertyAttribute)
 Gets the name of the property attribute.
static const TMap< FString, FCesiumPropertyAttributeProperty > & GetProperties (UPARAM(ref) const FCesiumPropertyAttribute &PropertyAttribute)
 Gets all the properties of the property attribute, mapped by property name.
static const TArray< FString > GetPropertyNames (UPARAM(ref) const FCesiumPropertyAttribute &PropertyAttribute)
 Gets the names of the properties in this property attribute.
static const FCesiumPropertyAttributeProperty & FindProperty (UPARAM(ref) const FCesiumPropertyAttribute &PropertyAttribute, const FString &PropertyName)
 Retrieve a FCesiumPropertyAttributeProperty by name.
static TMap< FString, FCesiumMetadataValue > GetMetadataValuesAtIndex (UPARAM(ref) const FCesiumPropertyAttribute &PropertyAttribute, int64 Index)
 Gets all of the property values for the given vertex index, mapped by property name.
Definition at line 99 of file CesiumPropertyAttribute.h.
◆ FindProperty()
static const FCesiumPropertyAttributeProperty & UCesiumPropertyAttributeBlueprintLibrary::FindProperty ( UPARAM(ref) const FCesiumPropertyAttribute & PropertyAttribute,
const FString & PropertyName )
static
If the property attribute does not contain a property with that name, this returns an invalid FCesiumPropertyAttributeProperty.
PropertyAttributeThe property attribute.
PropertyNameThe name of the property to find.
◆ GetMetadataValuesAtIndex()
static TMap< FString, FCesiumMetadataValue > UCesiumPropertyAttributeBlueprintLibrary::GetMetadataValuesAtIndex ( UPARAM(ref) const FCesiumPropertyAttribute & PropertyAttribute,
int64 Index )
static
This will only include values from valid property attribute properties.
If the index is out-of-bounds, the returned map will be empty.
IndexThe index of the target vertex.
The property values mapped by property name.
◆ GetProperties()
static const TMap< FString, FCesiumPropertyAttributeProperty > & UCesiumPropertyAttributeBlueprintLibrary::GetProperties ( UPARAM(ref) const FCesiumPropertyAttribute & PropertyAttribute)
static
◆ GetPropertyAttributeName()
static const FString & UCesiumPropertyAttributeBlueprintLibrary::GetPropertyAttributeName ( UPARAM(ref) const FCesiumPropertyAttribute & PropertyAttribute)
static
If no name was specified in the glTF extension, this returns an empty string.
◆ GetPropertyAttributeStatus()
static ECesiumPropertyAttributeStatus UCesiumPropertyAttributeBlueprintLibrary::GetPropertyAttributeStatus ( UPARAM(ref) const FCesiumPropertyAttribute & PropertyAttribute)
static
If an error occurred while parsing the property attribute from the glTF extension, this briefly conveys why.
◆ GetPropertyNames()
static const TArray< FString > UCesiumPropertyAttributeBlueprintLibrary::GetPropertyNames ( UPARAM(ref) const FCesiumPropertyAttribute & PropertyAttribute)
static
