CesiumGltf::PropertyAttribute Struct Referencefinal
Properties conforming to a class, organized as property values stored in attributes. More...
#include <CesiumGltf/PropertyAttribute.h>
Inheritance diagram for CesiumGltf::PropertyAttribute:
 The name of the property attribute, e.g. for display purposes.
std::string classProperty
 The class that property values conform to. The value must be a class ID declared in the classes dictionary.
std::unordered_map< std::string, CesiumGltf::PropertyAttributeProperty > properties
 A dictionary, where each key corresponds to a property ID in the class' properties dictionary and each value is an object describing where property values are stored. Required properties must be included in this dictionary.
static constexpr const char * TypeName = "PropertyAttribute"
Definition at line 18 of file PropertyAttribute.h.
int64_t CesiumGltf::PropertyAttribute::getSizeBytes ( ) const
Definition at line 51 of file PropertyAttribute.h.
◆ classProperty
std::string CesiumGltf::PropertyAttribute::classProperty
Definition at line 34 of file PropertyAttribute.h.
◆ name
std::optional<std::string> CesiumGltf::PropertyAttribute::name
Definition at line 28 of file PropertyAttribute.h.
◆ properties
std::unordered_map<std::string, CesiumGltf::PropertyAttributeProperty> CesiumGltf::PropertyAttribute::properties
Definition at line 43 of file PropertyAttribute.h.
const char* CesiumGltf::PropertyAttribute::TypeName = "PropertyAttribute"
Definition at line 23 of file PropertyAttribute.h.
