Holds details of the Cesium3DTilesSelection::TileRenderContent that are useful for raster overlays. More...
#include <CesiumRasterOverlays/RasterOverlayDetails.h>
| RasterOverlayDetails () | |
| Construct an empty RasterOverlayDetails. | |
| RasterOverlayDetails (std::vector< CesiumGeospatial::Projection > &&rasterOverlayProjections, std::vector< CesiumGeometry::Rectangle > &&rasterOverlayRectangles, const CesiumGeospatial::BoundingRegion &boundingRegion) | |
| Construct a RasterOverlayDetails with given projections, the rectangles generated by the projections, and the bounding region covered those rectangles. | |
| const CesiumGeometry::Rectangle * | findRectangleForOverlayProjection (const CesiumGeospatial::Projection &projection) const |
| Finds the rectangle corresponding to a given projection in rasterOverlayProjections. | |
| void | merge (const RasterOverlayDetails &other, const CesiumGeospatial::Ellipsoid &ellipsoid=CesiumGeospatial::Ellipsoid::WGS84) |
| Merge the other RasterOverlayDetails's projections, rectangles, and bounding region together. | |
| std::vector< CesiumGeospatial::Projection > | rasterOverlayProjections |
| The raster overlay projections for which texture coordinates have been generated. | |
| std::vector< CesiumGeometry::Rectangle > | rasterOverlayRectangles |
| The rectangle covered by this tile in each of the rasterOverlayProjections. | |
| CesiumGeospatial::BoundingRegion | boundingRegion |
| The precise bounding region of this tile. | |
Definition at line 15 of file RasterOverlayDetails.h.
| CesiumRasterOverlays::RasterOverlayDetails::RasterOverlayDetails | ( | std::vector< CesiumGeospatial::Projection > && | rasterOverlayProjections, |
| std::vector< CesiumGeometry::Rectangle > && | rasterOverlayRectangles, | ||
| const CesiumGeospatial::BoundingRegion & | boundingRegion ) |
| rasterOverlayProjections | The raster overlay projections for which texture coordinates have been generated. |
| rasterOverlayRectangles | The rectangle covered by this tile in each of the rasterOverlayProjections. |
| boundingRegion | The precise bounding region of this tile. |
| const CesiumGeometry::Rectangle * CesiumRasterOverlays::RasterOverlayDetails::findRectangleForOverlayProjection | ( | const CesiumGeospatial::Projection & | projection | ) | const |
| projection | The projection. |
| void CesiumRasterOverlays::RasterOverlayDetails::merge | ( | const RasterOverlayDetails & | other, |
| const CesiumGeospatial::Ellipsoid & | ellipsoid = CesiumGeospatial::Ellipsoid::WGS84 ) |
| other | The other instance of RasterOverlayDetails that will be merged with this. |
| ellipsoid | The CesiumGeospatial::Ellipsoid. |
| CesiumGeospatial::BoundingRegion CesiumRasterOverlays::RasterOverlayDetails::boundingRegion |
Definition at line 79 of file RasterOverlayDetails.h.
| std::vector<CesiumGeospatial::Projection> CesiumRasterOverlays::RasterOverlayDetails::rasterOverlayProjections |
For the projection at index n, there is a set of texture coordinates with the attribute name _CESIUMOVERLAY_n that corresponds to that projection.
Definition at line 68 of file RasterOverlayDetails.h.
| std::vector<CesiumGeometry::Rectangle> CesiumRasterOverlays::RasterOverlayDetails::rasterOverlayRectangles |
Definition at line 74 of file RasterOverlayDetails.h.
