CesiumRasterOverlays::UrlTemplateRasterOverlayOptions Struct Reference
Options for URL template overlays. More...
#include <CesiumRasterOverlays/UrlTemplateRasterOverlay.h>
std::optional< std::string > credit
std::optional< CesiumGeospatial::Projection > projection
 The CesiumGeospatial::Projection that is used.
std::optional< CesiumGeometry::QuadtreeTilingScheme > tilingScheme
 The CesiumGeometry::QuadtreeTilingScheme specifying how the ellipsoidal surface is broken into tiles.
uint32_t minimumLevel = 0
 The minimum level-of-detail supported by the imagery provider.
uint32_t maximumLevel = 25
 The maximum level-of-detail supported by the imagery provider.
uint32_t tileWidth = 256
 Pixel width of image tiles.
uint32_t tileHeight = 256
 Pixel height of image tiles.
std::optional< CesiumGeometry::Rectangle > coverageRectangle
 The CesiumGeometry::Rectangle, in radians, covered by the image.
Definition at line 28 of file UrlTemplateRasterOverlay.h.
◆ coverageRectangle
std::optional<CesiumGeometry::Rectangle> CesiumRasterOverlays::UrlTemplateRasterOverlayOptions::coverageRectangle
Definition at line 73 of file UrlTemplateRasterOverlay.h.
◆ credit
std::optional<std::string> CesiumRasterOverlays::UrlTemplateRasterOverlayOptions::credit
Definition at line 32 of file UrlTemplateRasterOverlay.h.
◆ maximumLevel
uint32_t CesiumRasterOverlays::UrlTemplateRasterOverlayOptions::maximumLevel = 25
Definition at line 57 of file UrlTemplateRasterOverlay.h.
◆ minimumLevel
uint32_t CesiumRasterOverlays::UrlTemplateRasterOverlayOptions::minimumLevel = 0
Take care when specifying this that the number of tiles at the minimum level is small, such as four or less. A larger number is likely to result in rendering problems.
Definition at line 52 of file UrlTemplateRasterOverlay.h.
◆ projection
std::optional<CesiumGeospatial::Projection> CesiumRasterOverlays::UrlTemplateRasterOverlayOptions::projection
Definition at line 37 of file UrlTemplateRasterOverlay.h.
◆ tileHeight
uint32_t CesiumRasterOverlays::UrlTemplateRasterOverlayOptions::tileHeight = 256
Definition at line 67 of file UrlTemplateRasterOverlay.h.
◆ tileWidth
uint32_t CesiumRasterOverlays::UrlTemplateRasterOverlayOptions::tileWidth = 256
Definition at line 62 of file UrlTemplateRasterOverlay.h.
◆ tilingScheme
std::optional<CesiumGeometry::QuadtreeTilingScheme> CesiumRasterOverlays::UrlTemplateRasterOverlayOptions::tilingScheme
Definition at line 43 of file UrlTemplateRasterOverlay.h.
