CesiumGltf::TextureInfo Struct Reference
Reference to a texture. More...
#include <CesiumGltf/TextureInfo.h>
Inheritance diagram for CesiumGltf::TextureInfo:
CesiumUtility::ExtensibleObject CesiumGltf::FeatureIdTexture CesiumGltf::MaterialNormalTextureInfo CesiumGltf::MaterialOcclusionTextureInfo CesiumGltf::PropertyTextureProperty
int32_t index = -1
 The index of the texture.
int64_t texCoord = 0
 The set index of texture's TEXCOORD attribute used for texture coordinate mapping.
static constexpr const char * TypeName = "TextureInfo"
Definition at line 14 of file TextureInfo.h.
int64_t CesiumGltf::TextureInfo::getSizeBytes ( ) const
Definition at line 43 of file TextureInfo.h.
◆ index
int32_t CesiumGltf::TextureInfo::index = -1
Definition at line 23 of file TextureInfo.h.
◆ texCoord
int64_t CesiumGltf::TextureInfo::texCoord = 0
This integer value is used to construct a string in the format TEXCOORD_<set index> which is a reference to a key in mesh.primitives.attributes (e.g. a value of 0 corresponds to TEXCOORD_0). A mesh primitive MUST have the corresponding texture coordinate attributes for the material to be applicable to it.
Definition at line 35 of file TextureInfo.h.
const char* CesiumGltf::TextureInfo::TypeName = "TextureInfo"
Definition at line 18 of file TextureInfo.h.
