ArrayJsonHandler.h
3#include <CesiumJsonReader/DoubleJsonHandler.h>
4#include <CesiumJsonReader/IntegerJsonHandler.h>
5#include <CesiumJsonReader/JsonHandler.h>
6#include <CesiumJsonReader/JsonObjectJsonHandler.h>
7#include <CesiumJsonReader/Library.h>
8#include <CesiumJsonReader/StringJsonHandler.h>
9#include <CesiumUtility/Assert.h>
10#include <CesiumUtility/JsonValue.h>
11
12#include <functional>
13#include <memory>
14#include <vector>
15
23template <typename T, typename THandler>
24class CESIUMJSONREADER_API ArrayJsonHandler : public JsonHandler {
25public:
27 using ValueType = std::vector<T>;
28
35 template <typename... Ts>
36 ArrayJsonHandler(Ts&&... args) noexcept
37 : JsonHandler(),
38 _handlerFactory(
39 std::bind(handlerFactory<Ts...>, std::forward<Ts>(args)...)),
40 _objectHandler() {}
41
46 void reset(IJsonHandler* pParent, std::vector<T>* pArray) {
47 JsonHandler::reset(pParent);
48 this->_pArray = pArray;
49 this->_arrayIsOpen = false;
50 this->_objectHandler.reset(this->_handlerFactory());
51 }
52
53 virtual IJsonHandler* readNull() override {
54 return this->invalid("A null")->readNull();
55 }
56
57 virtual IJsonHandler* readBool(bool b) override {
58 return this->invalid("A boolean")->readBool(b);
59 }
60
61 virtual IJsonHandler* readInt32(int32_t i) override {
62 return this->invalid("An integer")->readInt32(i);
63 }
64
65 virtual IJsonHandler* readUint32(uint32_t i) override {
66 return this->invalid("An integer")->readUint32(i);
67 }
68
69 virtual IJsonHandler* readInt64(int64_t i) override {
70 return this->invalid("An integer")->readInt64(i);
71 }
72
73 virtual IJsonHandler* readUint64(uint64_t i) override {
74 return this->invalid("An integer")->readUint64(i);
75 }
76
77 virtual IJsonHandler* readDouble(double d) override {
78 return this->invalid("A double (floating-point)")->readDouble(d);
79 }
80
81 virtual IJsonHandler* readString(const std::string_view& str) override {
82 return this->invalid("A string")->readString(str);
83 }
84
85 virtual IJsonHandler* readObjectStart() override {
86 if (!this->_arrayIsOpen) {
87 return this->invalid("An object")->readObjectStart();
88 }
89
90 CESIUM_ASSERT(this->_pArray);
91 T& o = this->_pArray->emplace_back();
92 this->_objectHandler->reset(this, &o);
93 return this->_objectHandler->readObjectStart();
94 }
95
97 [[maybe_unused]] const std::string_view& str) noexcept override {
98 return nullptr;
99 }
100
101 virtual IJsonHandler* readObjectEnd() noexcept override { return nullptr; }
102
103 virtual IJsonHandler* readArrayStart() override {
104 if (this->_arrayIsOpen) {
105 return this->invalid("An array")->readArrayStart();
106 }
107
108 this->_arrayIsOpen = true;
109 this->_pArray->clear();
110 return this;
111 }
112
113 virtual IJsonHandler* readArrayEnd() override { return this->parent(); }
114
115 virtual void reportWarning(
116 const std::string& warning,
117 std::vector<std::string>&& context =
118 std::vector<std::string>()) override {
119 context.push_back(
120 std::string("[") + std::to_string(this->_pArray->size()) + "]");
121 this->parent()->reportWarning(warning, std::move(context));
122 }
123
124private:
125 IJsonHandler* invalid(const std::string& type) {
126 if (this->_arrayIsOpen) {
127 this->reportWarning(
128 type + " value is not allowed in the object array and has been "
129 "replaced with a default value.");
130 this->_pArray->emplace_back();
131 return this->ignoreAndContinue();
132 } else {
133 this->reportWarning(type + " is not allowed and has been ignored.");
134 return this->ignoreAndReturnToParent();
135 }
136 }
137
138 template <typename... Ts> static THandler* handlerFactory(Ts&&... args) {
139 return new THandler(std::forward<Ts>(args)...);
140 }
141
142 std::vector<T>* _pArray = nullptr;
143 bool _arrayIsOpen = false;
144
145 std::function<THandler*()> _handlerFactory;
146 std::unique_ptr<THandler> _objectHandler;
147};
148
153template <>
154class CESIUMJSONREADER_API
155 ArrayJsonHandler<CesiumUtility::JsonValue, JsonObjectJsonHandler>
156 : public JsonHandler {
157public:
159 using ValueType = std::vector<CesiumUtility::JsonValue>;
160
161 ArrayJsonHandler() noexcept : JsonHandler(), _objectHandler() {}
162
167 void
168 reset(IJsonHandler* pParent, std::vector<CesiumUtility::JsonValue>* pArray) {
169 JsonHandler::reset(pParent);
170 this->_pArray = pArray;
171 this->_arrayIsOpen = false;
172 }
173
174 virtual IJsonHandler* readNull() override {
175 if (!this->_arrayIsOpen) {
176 return this->invalid("A null")->readNull();
177 }
178
179 CESIUM_ASSERT(this->_pArray);
180 this->_pArray->emplace_back(nullptr);
181 return this;
182 }
183
184 virtual IJsonHandler* readBool(bool b) override {
185 if (!this->_arrayIsOpen) {
186 return this->invalid("A bool")->readBool(b);
187 }
188
189 CESIUM_ASSERT(this->_pArray);
190 this->_pArray->emplace_back(b);
191 return this;
192 }
193
194 virtual IJsonHandler* readInt32(int32_t i) override {
195 if (!this->_arrayIsOpen) {
196 return this->invalid("An integer")->readInt32(i);
197 }
198
199 CESIUM_ASSERT(this->_pArray);
200 this->_pArray->emplace_back(i);
201 return this;
202 }
203
204 virtual IJsonHandler* readUint32(uint32_t i) override {
205 if (!this->_arrayIsOpen) {
206 return this->invalid("An integer")->readUint32(i);
207 }
208
209 CESIUM_ASSERT(this->_pArray);
210 this->_pArray->emplace_back(i);
211 return this;
212 }
213
214 virtual IJsonHandler* readInt64(int64_t i) override {
215 if (!this->_arrayIsOpen) {
216 return this->invalid("An integer")->readInt64(i);
217 }
218
219 CESIUM_ASSERT(this->_pArray);
220 this->_pArray->emplace_back(i);
221 return this;
222 }
223
224 virtual IJsonHandler* readUint64(uint64_t i) override {
225 if (!this->_arrayIsOpen) {
226 return this->invalid("An integer")->readUint64(i);
227 }
228
229 CESIUM_ASSERT(this->_pArray);
230 this->_pArray->emplace_back(i);
231 return this;
232 }
233
234 virtual IJsonHandler* readDouble(double d) override {
235 if (!this->_arrayIsOpen) {
236 return this->invalid("A double (floating-point)")->readDouble(d);
237 }
238
239 CESIUM_ASSERT(this->_pArray);
240 this->_pArray->emplace_back(d);
241 return this;
242 }
243
244 virtual IJsonHandler* readString(const std::string_view& str) override {
245 if (!this->_arrayIsOpen) {
246 return this->invalid("A string")->readString(str);
247 }
248
249 CESIUM_ASSERT(this->_pArray);
250 this->_pArray->emplace_back(std::string(str));
251 return this;
252 }
253
254 virtual IJsonHandler* readObjectStart() override {
255 if (!this->_arrayIsOpen) {
256 return this->invalid("An object")->readObjectStart();
257 }
258
259 CESIUM_ASSERT(this->_pArray);
260 CesiumUtility::JsonValue& o = this->_pArray->emplace_back();
261 this->_objectHandler.reset(this, &o);
262 return this->_objectHandler.readObjectStart();
263 }
264
265 virtual IJsonHandler* readObjectKey(const std::string_view& str) override {
266 return this->_objectHandler.readObjectKey(str);
267 }
268
269 virtual IJsonHandler* readObjectEnd() override {
270 return this->_objectHandler.readObjectEnd();
271 }
272
273 virtual IJsonHandler* readArrayStart() override {
274 if (this->_arrayIsOpen) {
275 // An array inside an array
276 CESIUM_ASSERT(this->_pArray);
277 CesiumUtility::JsonValue& o = this->_pArray->emplace_back();
278 this->_objectHandler.reset(this, &o);
279 return this->_objectHandler.readArrayStart();
280 } else {
281 this->_arrayIsOpen = true;
282 this->_pArray->clear();
283 return this;
284 }
285 }
286
287 virtual IJsonHandler* readArrayEnd() override { return this->parent(); }
288
289 virtual void reportWarning(
290 const std::string& warning,
291 std::vector<std::string>&& context =
292 std::vector<std::string>()) override {
293 context.push_back(
294 std::string("[") + std::to_string(this->_pArray->size()) + "]");
295 this->parent()->reportWarning(warning, std::move(context));
296 }
297
298private:
299 IJsonHandler* invalid(const std::string& type) {
300 if (this->_arrayIsOpen) {
301 this->reportWarning(
302 type + " value is not allowed in the JSON value array "
303 "and has been replaced with a default value.");
304 this->_pArray->emplace_back();
305 return this->ignoreAndContinue();
306 } else {
307 this->reportWarning(type + " is not allowed and has been ignored.");
308 return this->ignoreAndReturnToParent();
309 }
310 }
311
312 std::vector<CesiumUtility::JsonValue>* _pArray = nullptr;
313 bool _arrayIsOpen = false;
314 CesiumJsonReader::JsonObjectJsonHandler _objectHandler;
315};
316
323template <>
324class CESIUMJSONREADER_API ArrayJsonHandler<double, DoubleJsonHandler>
325 : public JsonHandler {
326public:
328 using ValueType = std::vector<double>;
329
330 ArrayJsonHandler() noexcept : JsonHandler() {}
331
336 void reset(IJsonHandler* pParent, std::vector<double>* pArray) {
337 JsonHandler::reset(pParent);
338 this->_pArray = pArray;
339 this->_arrayIsOpen = false;
340 }
341
342 virtual IJsonHandler* readNull() override {
343 return this->invalid("A null")->readNull();
344 }
345
346 virtual IJsonHandler* readBool(bool b) override {
347 return this->invalid("A bool")->readBool(b);
348 }
349
350 virtual IJsonHandler* readInt32(int32_t i) override {
351 if (!this->_arrayIsOpen) {
352 return this->invalid("An integer")->readInt32(i);
353 }
354
355 CESIUM_ASSERT(this->_pArray);
356 this->_pArray->emplace_back(static_cast<double>(i));
357 return this;
358 }
359
360 virtual IJsonHandler* readUint32(uint32_t i) override {
361 if (!this->_arrayIsOpen) {
362 return this->invalid("An integer")->readUint32(i);
363 }
364
365 CESIUM_ASSERT(this->_pArray);
366 this->_pArray->emplace_back(static_cast<double>(i));
367 return this;
368 }
369
370 virtual IJsonHandler* readInt64(int64_t i) override {
371 if (!this->_arrayIsOpen) {
372 return this->invalid("An integer")->readInt64(i);
373 }
374
375 CESIUM_ASSERT(this->_pArray);
376 this->_pArray->emplace_back(static_cast<double>(i));
377 return this;
378 }
379
380 virtual IJsonHandler* readUint64(uint64_t i) override {
381 if (!this->_arrayIsOpen) {
382 return this->invalid("An integer")->readUint64(i);
383 }
384
385 CESIUM_ASSERT(this->_pArray);
386 this->_pArray->emplace_back(static_cast<double>(i));
387 return this;
388 }
389
390 virtual IJsonHandler* readDouble(double d) override {
391 if (!this->_arrayIsOpen) {
392 return this->invalid("A double (floating-point)")->readDouble(d);
393 }
394
395 CESIUM_ASSERT(this->_pArray);
396 this->_pArray->emplace_back(d);
397 return this;
398 }
399
400 virtual IJsonHandler* readString(const std::string_view& str) override {
401 return this->invalid("A string")->readString(str);
402 }
403
404 virtual IJsonHandler* readObjectStart() override {
405 return this->invalid("An object")->readObjectStart();
406 }
407
408 virtual IJsonHandler* readArrayStart() override {
409 if (this->_arrayIsOpen) {
410 return this->invalid("An array")->readArrayStart();
411 }
412
413 this->_arrayIsOpen = true;
414 this->_pArray->clear();
415 return this;
416 }
417
418 virtual IJsonHandler* readArrayEnd() override { return this->parent(); }
419
420 virtual void reportWarning(
421 const std::string& warning,
422 std::vector<std::string>&& context =
423 std::vector<std::string>()) override {
424 context.push_back(
425 std::string("[") + std::to_string(this->_pArray->size()) + "]");
426 this->parent()->reportWarning(warning, std::move(context));
427 }
428
429private:
430 IJsonHandler* invalid(const std::string& type) {
431 if (this->_arrayIsOpen) {
432 this->reportWarning(
433 type + " value is not allowed in the double array and has been "
434 "replaced with a default value.");
435 this->_pArray->emplace_back();
436 return this->ignoreAndContinue();
437 } else {
438 this->reportWarning(type + " is not allowed and has been ignored.");
439 return this->ignoreAndReturnToParent();
440 }
441 }
442
443 std::vector<double>* _pArray = nullptr;
444 bool _arrayIsOpen = false;
445};
446
451template <typename T>
452class CESIUMJSONREADER_API ArrayJsonHandler<T, IntegerJsonHandler<T>>
453 : public JsonHandler {
454public:
456 using ValueType = std::vector<T>;
457
458 ArrayJsonHandler() noexcept : JsonHandler() {}
459
464 void reset(IJsonHandler* pParent, std::vector<T>* pArray) {
465 JsonHandler::reset(pParent);
466 this->_pArray = pArray;
467 this->_arrayIsOpen = false;
468 }
469
470 virtual IJsonHandler* readNull() override {
471 return this->invalid("A null")->readNull();
472 }
473
474 virtual IJsonHandler* readBool(bool b) override {
475 return this->invalid("A bool")->readBool(b);
476 }
477
478 virtual IJsonHandler* readInt32(int32_t i) override {
479 if (!this->_arrayIsOpen) {
480 return this->invalid("An integer")->readInt32(i);
481 }
482
483 CESIUM_ASSERT(this->_pArray);
484 this->_pArray->emplace_back(static_cast<T>(i));
485 return this;
486 }
487
488 virtual IJsonHandler* readUint32(uint32_t i) override {
489 if (!this->_arrayIsOpen) {
490 return this->invalid("An integer")->readUint32(i);
491 }
492
493 CESIUM_ASSERT(this->_pArray);
494 this->_pArray->emplace_back(static_cast<T>(i));
495 return this;
496 }
497
498 virtual IJsonHandler* readInt64(int64_t i) override {
499 if (!this->_arrayIsOpen) {
500 return this->invalid("An integer")->readInt64(i);
501 }
502
503 CESIUM_ASSERT(this->_pArray);
504 this->_pArray->emplace_back(static_cast<T>(i));
505 return this;
506 }
507
508 virtual IJsonHandler* readUint64(uint64_t i) override {
509 if (!this->_arrayIsOpen) {
510 return this->invalid("An integer")->readUint64(i);
511 }
512
513 CESIUM_ASSERT(this->_pArray);
514 this->_pArray->emplace_back(static_cast<T>(i));
515 return this;
516 }
517
518 virtual IJsonHandler* readDouble(double d) override {
519 return this->invalid("A double (floating-point)")->readDouble(d);
520 }
521
522 virtual IJsonHandler* readString(const std::string_view& str) override {
523 return this->invalid("A string")->readString(str);
524 }
525
526 virtual IJsonHandler* readObjectStart() override {
527 return this->invalid("An object")->readObjectStart();
528 }
529
530 virtual IJsonHandler* readArrayStart() override {
531 if (this->_arrayIsOpen) {
532 return this->invalid("An array")->readArrayStart();
533 }
534
535 this->_arrayIsOpen = true;
536 this->_pArray->clear();
537 return this;
538 }
539
540 virtual IJsonHandler* readArrayEnd() override { return this->parent(); }
541
542 virtual void reportWarning(
543 const std::string& warning,
544 std::vector<std::string>&& context =
545 std::vector<std::string>()) override {
546 context.push_back(
547 std::string("[") + std::to_string(this->_pArray->size()) + "]");
548 this->parent()->reportWarning(warning, std::move(context));
549 }
550
551private:
552 IJsonHandler* invalid(const std::string& type) {
553 if (this->_arrayIsOpen) {
554 this->reportWarning(
555 type + " value is not allowed in the integer array and has been "
556 "replaced with a default value.");
557 this->_pArray->emplace_back();
558 return this->ignoreAndContinue();
559 } else {
560 this->reportWarning(type + " is not allowed and has been ignored.");
561 return this->ignoreAndReturnToParent();
562 }
563 }
564
565 std::vector<T>* _pArray = nullptr;
566 bool _arrayIsOpen = false;
567};
568
573template <>
574class CESIUMJSONREADER_API ArrayJsonHandler<std::string, StringJsonHandler>
575 : public JsonHandler {
576public:
578 using ValueType = std::vector<std::string>;
579
580 ArrayJsonHandler() noexcept : JsonHandler() {}
581
586 void reset(IJsonHandler* pParent, std::vector<std::string>* pArray) {
587 JsonHandler::reset(pParent);
588 this->_pArray = pArray;
589 this->_arrayIsOpen = false;
590 }
591
592 virtual IJsonHandler* readNull() override {
593 return this->invalid("A null")->readNull();
594 }
595
596 virtual IJsonHandler* readBool(bool b) override {
597 return this->invalid("A bool")->readBool(b);
598 }
599
600 virtual IJsonHandler* readInt32(int32_t i) override {
601 return this->invalid("An integer")->readInt32(i);
602 }
603
604 virtual IJsonHandler* readUint32(uint32_t i) override {
605 return this->invalid("An integer")->readUint32(i);
606 }
607
608 virtual IJsonHandler* readInt64(int64_t i) override {
609 return this->invalid("An integer")->readInt64(i);
610 }
611
612 virtual IJsonHandler* readUint64(uint64_t i) override {
613 return this->invalid("An integer")->readUint64(i);
614 }
615
616 virtual IJsonHandler* readDouble(double d) override {
617 return this->invalid("A double (floating-point)")->readDouble(d);
618 }
619
620 virtual IJsonHandler* readObjectStart() override {
621 return this->invalid("An object")->readObjectStart();
622 }
623
624 virtual IJsonHandler* readArrayStart() override {
625 if (this->_arrayIsOpen) {
626 return this->invalid("An array")->readArrayStart();
627 }
628
629 this->_arrayIsOpen = true;
630 this->_pArray->clear();
631 return this;
632 }
633
634 virtual IJsonHandler* readArrayEnd() override { return this->parent(); }
635
636 virtual IJsonHandler* readString(const std::string_view& str) override {
637 if (!this->_arrayIsOpen) {
638 return this->invalid("A string")->readString(str);
639 }
640
641 CESIUM_ASSERT(this->_pArray);
642 this->_pArray->emplace_back(str);
643 return this;
644 }
645
646 virtual void reportWarning(
647 const std::string& warning,
648 std::vector<std::string>&& context =
649 std::vector<std::string>()) override {
650 context.push_back(
651 std::string("[") + std::to_string(this->_pArray->size()) + "]");
652 this->parent()->reportWarning(warning, std::move(context));
653 }
654
655private:
656 IJsonHandler* invalid(const std::string& type) {
657 if (this->_arrayIsOpen) {
658 this->reportWarning(
659 type + " value is not allowed in the string array and has been "
660 "replaced with a default value.");
661 this->_pArray->emplace_back();
662 return this->ignoreAndContinue();
663 } else {
664 this->reportWarning(type + " is not allowed and has been ignored.");
665 return this->ignoreAndReturnToParent();
666 }
667 }
668
669 std::vector<std::string>* _pArray = nullptr;
670 bool _arrayIsOpen = false;
671};
672
680template <typename T, typename THandler>
681class CESIUMJSONREADER_API
682 ArrayJsonHandler<std::vector<T>, ArrayJsonHandler<T, THandler>>
683 : public JsonHandler {
684public:
686 using ValueType = std::vector<T>;
687
694 template <typename... Ts>
695 ArrayJsonHandler(Ts&&... args) noexcept
696 : JsonHandler(),
697 _handlerFactory(
698 std::bind(handlerFactory<Ts...>, std::forward<Ts>(args)...)),
699 _elementHandler() {}
700
705 void reset(IJsonHandler* pParent, std::vector<std::vector<T>>* pArray) {
706 JsonHandler::reset(pParent);
707 this->_pArray = pArray;
708 this->_arrayIsOpen = false;
709 this->_elementHandler.reset(this->_handlerFactory());
710 }
711
712 virtual IJsonHandler* readNull() override {
713 return this->invalid("A null")->readNull();
714 }
715
716 virtual IJsonHandler* readBool(bool b) override {
717 return this->invalid("A bool")->readBool(b);
718 }
719
720 virtual IJsonHandler* readInt32(int32_t i) override {
721 return this->invalid("An integer")->readInt32(i);
722 }
723
724 virtual IJsonHandler* readUint32(uint32_t i) override {
725 return this->invalid("An integer")->readUint32(i);
726 }
727
728 virtual IJsonHandler* readInt64(int64_t i) override {
729 return this->invalid("An integer")->readInt64(i);
730 }
731
732 virtual IJsonHandler* readUint64(uint64_t i) override {
733 return this->invalid("An integer")->readUint64(i);
734 }
735
736 virtual IJsonHandler* readDouble(double d) override {
737 return this->invalid("A double (floating-point)")->readDouble(d);
738 }
739
740 virtual IJsonHandler* readString(const std::string_view& str) override {
741 return this->invalid("A string")->readString(str);
742 }
743
744 virtual IJsonHandler* readObjectStart() override {
745 return this->invalid("An object")->readObjectStart();
746 }
747
748 virtual IJsonHandler* readArrayStart() override {
749 if (this->_arrayIsOpen) {
750 CESIUM_ASSERT(this->_pArray);
751 std::vector<T>& o = this->_pArray->emplace_back();
752 this->_elementHandler->reset(this, &o);
753 return this->_elementHandler->readArrayStart();
754 } else {
755 this->_arrayIsOpen = true;
756 this->_pArray->clear();
757 return this;
758 }
759 }
760
761 virtual IJsonHandler* readArrayEnd() override { return this->parent(); }
762
763 virtual void reportWarning(
764 const std::string& warning,
765 std::vector<std::string>&& context =
766 std::vector<std::string>()) override {
767 context.push_back(
768 std::string("[") + std::to_string(this->_pArray->size()) + "]");
769 this->parent()->reportWarning(warning, std::move(context));
770 }
771
772private:
773 IJsonHandler* invalid(const std::string& type) {
774 if (this->_arrayIsOpen) {
775 this->reportWarning(
776 type + " value is not allowed in the array of arrays and has been "
777 "replaced with a default value.");
778 this->_pArray->emplace_back();
779 return this->ignoreAndContinue();
780 } else {
781 this->reportWarning(type + " is not allowed and has been ignored.");
782 return this->ignoreAndReturnToParent();
783 }
784 }
785
786 template <typename... Ts>
787 static ArrayJsonHandler<T, THandler>* handlerFactory(Ts&&... args) {
788 return new ArrayJsonHandler<T, THandler>(std::forward<Ts>(args)...);
789 }
790
791 std::vector<std::vector<T>>* _pArray = nullptr;
792 bool _arrayIsOpen = false;
793
794 std::function<ArrayJsonHandler<T, THandler>*()> _handlerFactory;
795 std::unique_ptr<ArrayJsonHandler<T, THandler>> _elementHandler;
796};
797
798} // namespace CesiumJsonReader
virtual IJsonHandler * readInt32(int32_t i) override
virtual IJsonHandler * readUint32(uint32_t i) override
virtual IJsonHandler * readString(const std::string_view &str) override
virtual IJsonHandler * readInt64(int64_t i) override
virtual IJsonHandler * readUint64(uint64_t i) override
virtual void reportWarning(const std::string &warning, std::vector< std::string > &&context=std::vector< std::string >()) override
virtual IJsonHandler * readArrayEnd() override
virtual IJsonHandler * readObjectKey(const std::string_view &str) override
virtual IJsonHandler * readNull() override
virtual IJsonHandler * readObjectEnd() override
void reset(IJsonHandler *pParent, std::vector< CesiumUtility::JsonValue > *pArray)
Resets the parent and destination array of this ArrayJsonHandler.
virtual IJsonHandler * readObjectStart() override
virtual IJsonHandler * readArrayStart() override
virtual IJsonHandler * readBool(bool b) override
std::vector< CesiumUtility::JsonValue > ValueType
The destination type.
virtual IJsonHandler * readDouble(double d) override
void reset(IJsonHandler *pParent, std::vector< T > *pArray)
void reset(IJsonHandler *pParent, std::vector< double > *pArray)
void reset(IJsonHandler *pParent, std::vector< std::string > *pArray)
std::vector< std::string > ValueType
void reset(IJsonHandler *pParent, std::vector< std::vector< T > > *pArray)
std::vector< T > ValueType
virtual IJsonHandler * readObjectKey(const std::string_view &str) noexcept override
ArrayJsonHandler(Ts &&... args) noexcept
Creates a new ArrayJsonHandler.
virtual IJsonHandler * readObjectEnd() noexcept override
IJsonHandler for reading double values.
virtual IJsonHandler * readUint32(uint32_t i)=0
virtual IJsonHandler * readObjectKey(const std::string_view &str)=0
virtual IJsonHandler * readUint64(uint64_t i)=0
virtual IJsonHandler * readNull()=0
virtual IJsonHandler * readObjectEnd()=0
virtual IJsonHandler * readDouble(double d)=0
virtual IJsonHandler * readBool(bool b)=0
virtual IJsonHandler * readObjectStart()=0
virtual IJsonHandler * readString(const std::string_view &str)=0
virtual IJsonHandler * readInt64(int64_t i)=0
virtual IJsonHandler * readInt32(int32_t i)=0
IJsonHandler for reading integer values.
IJsonHandler * parent()
void reset(IJsonHandler *pParent)
IJsonHandler for arbitrary CesiumUtility::JsonValue JsonValue objects.
IJsonHandler for reading string values.
Definition JsonValue.h:53
Classes for reading JSON.
Utility classes for Cesium.
STL namespace.
