A Label draws viewport-aligned text positioned in the 3D scene.  This constructor
    LabelCollection#add.
    Throws:
    eyeOffset : Cartesian3
    Gets and sets the 3D Cartesian offset applied to this label in eye coordinates. Eye coordinates is a left-handed coordinate system, wherexpoints towards the viewer's right,ypoints up, andzpoints into the screen. Eye coordinates use the same scale as world and model coordinates, which is typically meters.
    fillColor : Color
 Example:// Use a top, right origin l.horizontalOrigin = Cesium.HorizontalOrigin.RIGHT; l.verticalOrigin = Cesium.VerticalOrigin.TOP;
    outlineColor : Color
    pixelOffset : Cartesian2
    Gets or sets the pixel offset in screen space from the origin of this label. This is commonly used to align multiple labels and billboards at the same position, e.g., an image and text. The screen space origin is the top, left corner of the canvas;xincreases from left to right, andyincreases from top to bottom.
 The label's origin is indicated by the yellow point.default l.pixeloffset = new Cartesian2(25, 75);
    Gets or sets near and far pixel offset scaling properties of a Label based on the Label's distance from the camera. A label's pixel offset will be scaled between theNearFarScalar#nearValueandNearFarScalar#farValuewhile the camera distance falls within the upper and lower bounds of the specifiedNearFarScalar#nearandNearFarScalar#far. Outside of these ranges the label's pixel offset scaling remains clamped to the nearest bound. If undefined, pixelOffsetScaleByDistance will be disabled.Examples:// Example 1. // Set a label's pixel offset scale to 0.0 when the // camera is 1500 meters from the label and scale pixel offset to 10.0 pixels // in the y direction the camera distance approaches 8.0e6 meters. text.pixelOffset = new Cesium.Cartesian2(0.0, 1.0); text.pixelOffsetScaleByDistance = new Cesium.NearFarScalar(1.5e2, 0.0, 8.0e6, 10.0);// Example 2. // disable pixel offset by distance text.pixelOffsetScaleByDistance = undefined;
    position : Cartesian3
    Gets or sets the uniform scale that is multiplied with the label's size in pixels. A scale of1.0does not change the size of the label; a scale greater than1.0enlarges the label; a positive scale less than1.0shrinks the label.
 Applying a large scale value may pixelate the label. To make text larger without pixelation, use a larger font size when callingLabel#fontinstead.
 From left to right in the above image, the scales are0.5,1.0, and2.0.
    style : LabelStyle
    Gets or sets near and far translucency properties of a Label based on the Label's distance from the camera. A label's translucency will interpolate between theNearFarScalar#nearValueandNearFarScalar#farValuewhile the camera distance falls within the upper and lower bounds of the specifiedNearFarScalar#nearandNearFarScalar#far. Outside of these ranges the label's translucency remains clamped to the nearest bound. If undefined, translucencyByDistance will be disabled.Examples:// Example 1. // Set a label's translucencyByDistance to 1.0 when the // camera is 1500 meters from the label and disappear as // the camera distance approaches 8.0e6 meters. text.translucencyByDistance = new Cesium.NearFarScalar(1.5e2, 1.0, 8.0e6, 0.0);// Example 2. // disable translucency by distance text.translucencyByDistance = undefined;
    Computes the screen-space position of the label's origin, taking into account eye and pixel offsets. The screen space origin is the top, left corner of the canvas;xincreases from left to right, andyincreases from top to bottom.Name Type Description sceneScene The scene the label is in. resultCartesian2 optional The object onto which to store the result. Returns:The screen-space position of the label.Example:console.log(l.computeScreenSpacePosition(scene).toString());See:
    Determines if this label equals another label. Labels are equal if all their properties are equal. Labels in different collections can be equal.Name Type Description otherLabel The label to compare for equality. Returns:trueif the labels are equal; otherwise,false.
 If this object was destroyed, it should not be used; calling any function other thanisDestroyedwill result in aDeveloperErrorexception.Returns:True if this object was destroyed; otherwise, false.
