Cesium for Unreal 2.31.0
Cesium for Unreal unlocks geospatial capabilities in Unreal Engine while also enabling developers to take advantage of in-engine features. As a result, people who use the plugin can often come with existing Unreal knowledge.
In order to make Cesium's integration as seamless as possible, we aim to mirror the paradigms and APIs of the engine where we can. This guide provides best practices for how we do that.
UObject is the underlying base class of gameplay objects in Unreal Engine. Most classes in the Cesium for Unreal plugin inherit from UObject, such that they expose their functionality to the systems in Unreal Engine.
The Overview points out some of the components involved when designing UObjects. If you are already familiar with these, feel free to skip to the Best Practices section.
UObjectThe official documentation already contains a summary of UObject, so we won't duplicate that here. However, we build on a few elements in UObject Creation and Destroying Objects below.
UObjects may only use default constructors. In other words, a UObject cannot have a constructor with arguments.BeginPlay method for specific initialization behavior. But most of our objects need to work in the Editor as well, where BeginPlay isn't called. We rely on a variety of other methods, like OnConstruction, PostLoad, Serialize, etc. to manage various aspects of the initialization. See Initialization for more detail.UObjects are automatically garbage collected when they are no longer referenced. Therefore, be mindful of "strong references" that can keep them alive (e.g., UProperties, class instances, TStrongObjectPtr).UObject will become invalid after it's garbage collected, and dereferencing the pointer will lead to undefined behavior.UObjects often contain member variables (or properties) important to the object's gameplay logic. However, beyond declaring the property in C++, you need an extra step to Unreal Engine recognize (and later manipulate) those variables.
The UPROPERTY macro identifies such properties. This macro should be put above a property that you wish to expose to Unreal Engine. Once recognized, the properties can be acted upon, e.g., made accessible through Blueprints or the Editor UI. It may also be used to enable event handlers and delegates.
UFUNCTION is the equivalent of UPROPERTY for C++ functions. By using this macro, a function can be made accessible to Blueprints, or even as a button in the Editor interface.
USTRUCT is the macro to expose structs to Unreal Engine. They are fairly straightforward, but a few elements of note are:
USTRUCTs don't inherit from UObject, so they are not managed by the Garbage Collection system.USTRUCTs can contain UPROPERTYs, and UObjects can also have USTRUCT type properties.USTRUCTs can be used in Blueprints depending on their specifiers.USTRUCT(BlueprintType) enables the Make node (to create the struct).Break node (for retrieval), they must have either BlueprintReadOnly or BlueprintReadWrite specifiers. See Specifiers below.UENUM is used for any enum classes that Unreal should use in a UObject context, e.g., as a type for UPROPERTY or Blueprints. UENUM should be used on an enum class of uint8; it typically does not work on pure enums.
Many UObject macros take arguments that influence their scope and behavior. The Quick Reference is included so you can focus on the most relevant ones.
For example, check out the MaximumScreenSpaceError property on ACesium3DTileset:
EditAnywhere specifier allows the property to appear and be modifiable by the user in the Details panel of the Editor.BlueprintGetter and BlueprintSetter define specific functions for getting and setting the value in Blueprints (see UFunctions).Category indicates how the property should be organized in the Details panel. It appears under the "Level of Detail" category, which itself is nested in the "Cesium" category.meta refers to additional metadata that augments how the property functions or appears. Here, ClampMin prevents the Details UI from setting it to smaller values. (It may still be set through C++ or Blueprints.)The official documentation for UPROPERTY explains the fundamentals, but it is not comprehensive. This masterlist of UPROPERTY specifiers by ben ui provides a more extensive look into what's possible.
The UFUNCTION macro also takes multiple arguments to influence its behavior. For instance,
BlueprintPure specifier allows the function to be executed in a Blueprint graph. The Pure keyword indicates that the function will not affect the owning object (ACesiumGeoreference) in any way.Category indicates how the property should be organized in Blueprint selection panel, under "Cesium" category.meta refers to additional metadata that augments how the property functions or appears. Here, ReturnDisplayName specifies how the output will be labeled in the Blueprint node.UFUNCTION must be used for any functions that are used for BlueprintGetter or BlueprintSetter. For BlueprintSetter, the function should be public and serve as the mechanism for setting the property from C++. A corresponding BlueprintGetter is usually needed for use by C++, even though it is often not needed for Blueprints.
Again, the official documentation for UFUNCTION explains the fundamentals, but this masterlist of UFUNCTION specifiers by ben ui is more extensive.
The following sections describe some best practices for designing UObjects in Cesium for Unreal.
Most classes in Cesium for Unreal must work in Unreal Editor as well as Play Mode. But between the two modes, there are different methods that affect an object during its creation and loading process. We rely on a variety of methods to properly initialize the UObject, listed below.
| Name | What |
PostLoad | Called in both the Editor and during gameplay for actors that are already placed in a level. This is not called for newly spawned actors at runtime. |
OnConstruction | Called whenever objects are placed in the Editor or spawned during gameplay. May also be triggered after Blueprints are changed. |
Serialize | Called when the object is serialized during project load or save. |
PostInitProperties | Called after the C++ constructor of the UObject and after its properties have been initialized. |
BeginPlay | Called at the start of Play Mode. |
In other words,
PostLoad to initialize existing objects, and OnConstruction for newly-created ones.Serialize for scenarios like Deprecation and Backwards Compatibility.BeginPlay for exclusively runtime behavior.PostInitProperties is not used often in Cesium for Unreal. When it has been used, it was to intercept the object immediately after default construction in C++ to transfer specific settings. But this is a rare case.
Many Cesium for Unreal classes manage an internal state that must be carefully maintained when modifying properties. For instance, when properties on the ACesiumGeoreference are changed, it must call UpdateGeoreference() immediately after to ensure that all other properties are synced in response.
As a result, BlueprintReadWrite is rarely used for properties in Cesium for Unreal. Much of the time, there is additional logic needed after a property is "set", so the change needs to be specifically detected.
We have settled on the following standards for properties that require post-change logic:
private in the class. This prevents the property from being get or set directly from outside the class in C++ (which is important, because there is no mechanism like PostEditChangeProperty or BlueprintSetter available in code).Meta = (AllowPrivateAccess) to the UPROPERTY.BlueprintGetter and BlueprintSetter functions.PostEditChangeProperty method on the class. This allows it to be notified of changes to the property in the Editor.If a UPROPERTY is a struct type, then you may also need to override PostEditChangeChainProperty. This method works on chains of property changes—e.g., when a property inside the struct is changed.
Finally, beware of any consequences from users undoing modifications on a UObject, or even copy-pasting it. These changes can be handled by PostEditUndo and PostEditImport respectively.
In Cesium for Unreal, many UObjects have properties that depend on each other to enable behaviors. For instance, a property may only be enabled if some other boolean property is true, or if an enum property is set to a certain value.
Cesium3DTileset is a great example for these conditional properties. The enum Source property affects whether the URL property can be edited. The boolean Enable Culled Screen Space Error property activates Culled Screen Space Error accordingly.
| Example | Inactive | Active |
| Enum |
| Boolean |
You can use the meta = (EditCondition = "") specifier to implement these conditions. Make sure that conditional properties are listed below the properties that they depend on, both in C++ code and in the Details panel. This reinforces that logic and results in visual clarity.
The EditCondition is able to parse complex boolean logic, but it currently cannot reference functions.
It can only parse UPROPERTY values, too, so don't reference any variables that aren't made accessible to Unreal Engine.
There exists another specifier,
EditConditionHides, that hides the property from the Details panel instead of making it read-only (visible but greyed out). However, Cesium for Unreal prefers to simply show the properties as read-only.
Properties should be organized or modified in the Details panel such that they provide an intuitive user experience. Are the properties ordered in a logical manner? Is it clear which properties depend on each other?
Aside from implementing clear Conditional Properties, be diligent about organizing properties in reasonable groups using the Category specifier. In fact, failing to give a category to public properties can cause a failure at packaging time!
Most classes, properties, and functions in Cesium for Unreal are put under a broad Cesium category. But there are typically subcategories that should be accounted for, too. This can be achieved by using the | delimiter in the category name.
This categorization will apply to Blueprints as well. Use categories to make the scopes of functions obvious from a glance. For example, it is easy to find which functions are relevant to CesiumEllipsoid due to their category:
Properties under the same category should also be adjacent in C++ to reinforce the logical grouping. For example, don't interleave categories like this in C++ code:
Group them together:
Additionally, keep in mind the order in which properties will appear. A good principle is to start with properties that are more simple or fundamental to the UObject. They can cascade into the more advanced settings further down the Details panel. For instance, this is the order of properties as they appear in CesiumGeoreference.h:
Sometimes Unreal will position certain properties out-of-order, e.g., listing UObject-pointer properties below everything else. You can use meta = (DisplayAfter = "") or meta = (DisplayPriority = 0) specifiers to control the order in which properties appear. (Examples can be found here.)
You can also use the AdvancedDisplay specifier to explicitly delegate properties to the "Advanced" section of a category.
For convenience, here is a cheat sheet of some of the most relevant and/or helpful specifiers for use in Cesium for Unreal's development.
UPROPERTY| Name | What | When to Use |
BlueprintReadOnly | Property is accessible in Blueprints but read-only. | Self-explanatory. |
BlueprintReadWrite | Property is editable from Blueprints. | When the "set" logic is simple enough that nothing additional must happen after the property is set. If additional logic is required, use BlueprintSetter instead. |
BlueprintGetter=[FunctionName] | Property uses the specified function to get the value. | Whenever you have to use BlueprintSetter. |
BlueprintSetter=[FunctionName] | Property uses the specified function to set the value. | Whenever you have to do additional work after setting a property, e.g., recomputing the object's internal state. |
BlueprintAssignable | For delegate or event properties, allows the property to be assigned in Blueprints. | Self-explanatory. |
UFUNCTION| Name | What | When to Use |
BlueprintCallable | Function can be executed in a Blueprint or Level Blueprint graph. | For functions that depend on a sequence of node execution. For example, UCesiumEllipsoid::Create requires that the ellipsoid be created before something is done on it.BlueprintCallable results in an "execution pin" to indicate what happens after the Blueprint moves on. For const functions, no execution pin will be generated, similar to BlueprintPure. |
BlueprintPure | Function can be executed in a Blueprint or Level Blueprint graph without an execution pin. | For functions whose execution does not require explicit sequencing logic, and for which it will not affect the owning object. For example, UCesiumEllipsoid::ScaleToGeodeticSurface will implicitly execute before its value is used, and it does not change the UCesiumEllipsoid itself, so it can be a "pure" function. |
BlueprintGetter | Function can be used as a BlueprintGetter for a UPROPERTY. | Can replace BlueprintCallable, if desired, to signal its use in BlueprintGetter for a UPROPERTY. |
BlueprintSetter | Function can be used as a BlueprintSetter for a UPROPERTY. | Can replace BlueprintCallable, if desired, to signal its use in BlueprintSetter for a UPROPERTY. |
BlueprintNativeEvent | For functions that are designed to be overridden by a Blueprint, this indicates that there is a default native implementation. The implementation function must be named [OriginalFunctionName]_Implementation. | For achieving behavior in Blueprints similar to virtual functions. Not used often by the plugin. |
meta = (ReturnDisplayName = "") | Function output on the Blueprint node will be labeled with the specified name. | Good in general for visual clarity. |
VisibleAnywhere | Property is read-only in the Details panel. | For read-only variables. Don't use this for variables that shouldn't be visible to the user (e.g., implementation details, internal state management). |
EditAnywhere | Property is editable in the Details panel. | For properties that should be user-editable through the Editor UI. |
AdvancedDisplay | Property is separated into a dropdown "advanced" section that is hidden by default. | For advanced or complex properties that won't realistically be used by most users, e.g., ACesium3DTileset::CesiumIonServer. This prevents beginners from being confused, while still allowing advanced users to access that functionality. |
meta = (DisplayName = "") | Property name is changed to DisplayName in the Details Panel (as well as its corresponding Blueprint). | Can be used to shorten property names or reword them for clarity. |
meta = (DisplayAfter = "") | Property will be displayed below the DisplayAfter property in the Details Panel. | See Organization. |
meta = (DisplayPriority = 0) | Property will be assigned and sorted by numeric priority in the Details Panel. | See Organization. |
meta = (EditCondition = "") | Property is read-only if EditCondition is not met. | See Conditional Properties. |
meta = (ClampMin = 0) | Property is clamped to the minimum value or higher when edited in the Details panel. | To avoid invalid numeric values, e.g., an OriginLatitude below -90 degrees. |
meta = (ClampMax = 0) | Property is clamped to the maximum value or lower when edited in the Details panel. | To avoid invalid numeric values, e.g., an OriginLatitude above 90 degrees. |
meta = (ShowOnlyInnerProperties) | For struct properties, display their properties without nesting them in an expandable dropdown. | Use sparingly. This can help reduce visual clutter, e.g., to remove a level from multiple nested dropdowns. However, don't use this when the struct's name is important for clarity. |
meta = (ValidEnumValues="A, B") | Property is restricted to the enum values listed in the string. | Useful for limiting which values are acceptable for property. Avoids having to create duplicate enums or handle special cases. |
meta = (InvalidEnumValues="A, B") | Property is disallowed from being the enum values listed in the string. | When using the above is too tedious. |
CallInEditor | Function can be executed using a button in the Details panel. | Any helpful in-editor functionality that a user can easily access, e.g., RefreshTileset. Note that the function must have no parameters and no return value. |
Category = "" | Property will appear under the given category in the Details panel. | Required on all public UPROPERTYs. |
Transient | Property is not serialized when the UObject is saved. | For anything that shouldn't be saved, e.g., temporary references to objects at runtime. |
meta = (AllowPrivateAccess) | Property that is private in C++ can be accessed in Blueprints. | Use in accordance with the practices under Change Detection. |
meta = (DeprecatedProperty) | Property is marked as deprecated. | See Deprecation and Backwards Compatibility. |
meta = (DeprecatedFunction) | Function is marked as deprecated. | See Deprecation and Backwards Compatibility. |
Blueprints are a visual scripting option in Unreal Engine that users may use over C++ code. Part of the API design in Cesium for Unreal therefore includes creating sensible Blueprints for less code-savvy users.
First, defer to Unreal Engine's naming schemes for existing Blueprint functions and parameters. For example, texture coordinates in Blueprints are often referred to as "UV". Cesium for Unreal tries to match this by naming its own texture coordinate parameters as "UV".
Ideally, the language between our Blueprints and those of Unreal Engine should be well integrated, and users should not feel like they have to "translate" ideas between different Blueprints.
Additionally, parameters should be listed in order of from most to least important, or from most to least essential. This means that when you write the function in C++, the first parameters should be the most fundamental or necessary ones. The more advanced parameters can come after. For example:
This function's most important input is the Hit, so it is listed first. FeatureIDSetIndex is an advanced parameter that users are less likely ave to use. The order here translates to the Blueprint, since Hit appears at the top:
Sometimes API changes can result in breaking or unexpected behavior between versions. To avoid user frustration, we implement several measures to help users upgrade to new versions.
If you end up renaming a class, function, property, or even an enum, it is possible to link between the old and new names to preserve existing Blueprint scripts using [CoreRedirects]. These configurations can be found in Config/Engine.ini.
The official documentation includes examples for every kind of redirect, but there are plenty of previous cases in Cesium for Unreal. Note that each redirect must take up one line; adding line breaks will prevent it from being parsed correctly.
Read this short and sweet overview by Jonathan Hale that explains how to deprecate anything in Unreal Engine. This section expands briefly on some points, but most of it is already covered.
DeprecationMessage to succinctly inform the user of the deprecation and redirect them to its replacement, if applicable.struct or class is deprecated, prefer to use the UE_DEPRECATED macro in a forward declaration of the class before it is actually defined. For example:PRAGMA_DISABLE_DEPRECATION_WARNINGS and PRAGMA_ENABLE_DEPRECATION_WARNINGS. This will reduce the spam in the Unreal logs that can otherwise occur during the build process.Sometimes, a UObject's property is deprecated or replaced by an alternative solution. However, it may have been set with a value that must translate successfully to the new implementation. This can be resolved by creating "custom versions" of the plugin for resolving differences at load time.
Custom versions boil down to an enum called Versions that captures the current state of the plugin. Versions is stored in CesiumCustomVersion.h and can be expanded in the future. When objects are loaded from serialization, their properties can be intercepted if saved under a previous version.
Depending on the type of property, there are two methods to override. Simple properties like bools and enums can be set in Serialize, which handles object state during loads and saves. However, properties that refer to other objects (e.g., pointers) must be set in PostLoad. Otherwise, their values will not be reliably be set by Serialize—they can be overwritten later in the load process.
Let's look at how to create a new version called WebMapTileServiceProjectionAsEnum. In this version, a boolean property on UCesiumWebMapTileServiceRasterOverlay will be replaced with an enum.
First, deprecate the old property by following the guide linked in Deprecation Specifiers. Use the Core Redirects as needed to redirect properties to their _DEPRECATED counterparts.
Then, create a new version in the Versions enum. The enum value should:
VersionPlusOne.SerializeAn enum property is simple enough that it can be handled in Serialize. Add the virtual Serialize function to the target class, if it does not already exist.
In Serialize, you can retrieve the version associated with the UObject and implement compatibility measures. Here, the deprecated value of UseWebMercatorProjection (which has been redirected by [CoreRedirects]) is used to set the new property as needed.
PostLoadNow, let's look at a different property—one that would have to be set in PostLoad. Previously, we released support for configuring multiple and/or self-hosted Cesium ion servers on an Unreal project. This depended on CesiumIonServer, a new data asset that no project could have contained prior to the release. If we didn't handle this, everyone's project would be "missing" a Cesium ion server, and their data would fail to stream.
CesiumIonServers are referenced by pointers, so we have to handle this case in ACesium3DTileset::PostLoad. You can use GetLinkerCustomVersion to get the custom version that the UObject was saved with. Then, use a similar if statement to check for the version and resolve internal state as necessary.
