ACesiumGeoreference Class Reference
Controls how global geospatial coordinates are mapped to coordinates in the Unreal Engine level. More...
#include <CesiumGeoreference.h>
Inheritance diagram for ACesiumGeoreference:
FVector GetOriginLongitudeLatitudeHeight () const
 Returns the georeference origin position as an FVector where X is longitude (degrees), Y is latitude (degrees), and Z is height above the ellipsoid (meters).
void SetOriginLongitudeLatitudeHeight (const FVector &TargetLongitudeLatitudeHeight)
 This aligns the specified longitude in degrees (X), latitude in degrees (Y), and height above the ellipsoid in meters (Z) to the Unreal origin.
FVector GetOriginEarthCenteredEarthFixed () const
 Returns the georeference origin position as an FVector in Earth-Centerd, Earth-Fixed (ECEF) coordinates.
void SetOriginEarthCenteredEarthFixed (const FVector &TargetEarthCenteredEarthFixed)
 This aligns the specified Earth-Centered, Earth-Fixed (ECEF) coordinates to the Unreal origin.
EOriginPlacement GetOriginPlacement () const
 Gets the placement of this Actor's origin (coordinate 0,0,0) within the tileset.
void SetOriginPlacement (EOriginPlacement NewValue)
 Sets the placement of this Actor's origin (coordinate 0,0,0) within the tileset.
double GetOriginLatitude () const
 Gets the latitude of the custom origin placement in degrees, in the range [-90, 90].
void SetOriginLatitude (double NewValue)
 Sets the latitude of the custom origin placement in degrees, in the range [-90, 90].
double GetOriginLongitude () const
 Gets the longitude of the custom origin placement in degrees, in the range [-180, 180].
void SetOriginLongitude (double NewValue)
 Sets the longitude of the custom origin placement in degrees, in the range [-180, 180].
double GetOriginHeight () const
 Gets the height of the custom origin placement in meters above the ellipsoid.
void SetOriginHeight (double NewValue)
 Sets the height of the custom origin placement in meters above the ellipsoid.
double GetScale () const
 Gets the percentage scale of the globe in the Unreal world.
void SetScale (double NewValue)
 Sets the percentage scale of the globe in the Unreal world.
APlayerCameraManager * GetSubLevelCamera () const
 Gets the camera to use to determine which sub-level is closest, so that one can be activated and all others deactivated.
void SetSubLevelCamera (APlayerCameraManager *NewValue)
 Sets the camera to use to determine which sub-level is closest, so that one can be activated and all others deactivated.
UCesiumSubLevelSwitcherComponent * GetSubLevelSwitcher () const
 Gets the component that allows switching between different sub-levels registered with this georeference.
UCesiumEllipsoid * GetEllipsoid () const
 Returns a pointer to the UCesiumEllipsoid currently being used by this georeference.
void SetEllipsoid (UCesiumEllipsoid *NewEllipsoid)
 Sets the UCesiumEllipsoid used by this georeference.
FVector TransformLongitudeLatitudeHeightPositionToUnreal (const FVector &LongitudeLatitudeHeight) const
 Transforms the given longitude in degrees (x), latitude in degrees (y), and height above the ellipsoid in meters (z) into Unreal coordinates.
FVector TransformUnrealPositionToLongitudeLatitudeHeight (const FVector &UnrealPosition) const
 Transforms a position in Unreal coordinates into longitude in degrees (x), latitude in degrees (y), and height above the ellipsoid in meters (z).
FVector TransformEarthCenteredEarthFixedPositionToUnreal (const FVector &EarthCenteredEarthFixedPosition) const
 Transforms a position in Earth-Centered, Earth-Fixed (ECEF) coordinates into Unreal coordinates.
FVector TransformUnrealPositionToEarthCenteredEarthFixed (const FVector &UnrealPosition) const
 Transforms the given position from Unreal coordinates to Earth-Centered, Earth-Fixed (ECEF).
FVector TransformEarthCenteredEarthFixedDirectionToUnreal (const FVector &EarthCenteredEarthFixedDirection) const
 Transforms a direction vector in Earth-Centered, Earth-Fixed (ECEF) coordinates into Unreal coordinates.
FVector TransformUnrealDirectionToEarthCenteredEarthFixed (const FVector &UnrealDirection) const
 Transforms the given direction vector from Unreal coordinates to Earth-Centered, Earth-Fixed (ECEF) coordinates.
FRotator TransformUnrealRotatorToEastSouthUp (const FRotator &UnrealRotator, const FVector &UnrealLocation) const
 Given a Rotator that transforms an object into the Unreal coordinate system, returns a new Rotator that transforms that object into an East-South-Up frame centered at a given location.
FRotator TransformEastSouthUpRotatorToUnreal (const FRotator &EastSouthUpRotator, const FVector &UnrealLocation) const
 Given a Rotator that transforms an object into the East-South-Up frame centered at a given location, returns a new Rotator that transforms that object into Unreal coordinates.
FMatrix ComputeUnrealToEarthCenteredEarthFixedTransformation () const
 Computes the transformation matrix from the Unreal coordinate system to the Earth-Centered, Earth-Fixed (ECEF) coordinate system.
FMatrix ComputeEarthCenteredEarthFixedToUnrealTransformation () const
 Computes the transformation matrix from the Earth-Centered, Earth-Fixed (ECEF) coordinate system to the Unreal coordinate system.
FMatrix ComputeEastSouthUpToUnrealTransformation (const FVector &UnrealLocation) const
 Computes the matrix that transforms from an East-South-Up frame centered at a given location to the Unreal frame.
FMatrix ComputeEastSouthUpAtEarthCenteredEarthFixedPositionToUnrealTransformation (const FVector &EarthCenteredEarthFixedPosition) const
FMatrix ComputeUnrealToEastSouthUpTransformation (const FVector &UnrealLocation) const
 Computes the matrix that transforms from the Unreal frame to an East-South-Up frame centered at a given location.
GeoTransforms GetGeoTransforms () const noexcept
 ACesiumGeoreference ()
const CesiumGeospatial::LocalHorizontalCoordinateSystem & GetCoordinateSystem () const noexcept
static ACesiumGeoreference * GetDefaultGeoreference (const UObject *WorldContextObject)
 Finds and returns a CesiumGeoreference in the world.
static ACesiumGeoreference * GetDefaultGeoreferenceForActor (AActor *Actor)
 Finds and returns the CesiumGeoreference suitable for use with the given Actor.
FGeoreferenceUpdated OnGeoreferenceUpdated
 A delegate that will be called whenever the Georeference is modified in a way that affects its computations.
FGeoreferenceEllipsoidChanged OnEllipsoidChanged
 An event that will be called whenever the georeference's ellipsoid has been modified.
static const double kMinimumScale
 The minimum allowed value for the Scale property, 1e-6.
Protected Member Functions
virtual bool ShouldTickIfViewportsOnly () const override
virtual void Tick (float DeltaTime) override
virtual void Serialize (FArchive &Ar) override
virtual void BeginPlay () override
virtual void OnConstruction (const FTransform &Transform) override
virtual void PostLoad () override
Friends
class FCesiumGeoreferenceCustomization
Internally, Cesium uses a global Earth-centered, Earth-fixed (ECEF) ellipsoid-centered coordinate system, where the ellipsoid is usually the World Geodetic System 1984 (WGS84) ellipsoid. This is a right-handed system centered at the Earth's center of mass, where +X is in the direction of the intersection of the Equator and the Prime Meridian (zero degrees longitude), +Y is in the direction of the intersection of the Equator and +90 degrees longitude, and +Z is through the North Pole. This Actor is used by other Cesium Actors and components to control how this coordinate system is mapped into an Unreal Engine world and level.
Definition at line 49 of file CesiumGeoreference.h.
◆ ACesiumGeoreference()
ACesiumGeoreference::ACesiumGeoreference ( )
◆ BeginPlay()
virtual void ACesiumGeoreference::BeginPlay ( )
overrideprotectedvirtual
◆ ComputeEarthCenteredEarthFixedToUnrealTransformation()
FMatrix ACesiumGeoreference::ComputeEarthCenteredEarthFixedToUnrealTransformation ( ) const
The Unreal coordinates should generally not be interpreted as Unreal world coordinates, but rather a coordinate system based on some parent Actor's reference frame as defined by its transform. This way, the chain of Unreal transforms places and orients the "globe" in the Unreal world.
◆ ComputeEastSouthUpAtEarthCenteredEarthFixedPositionToUnrealTransformation()
FMatrix ACesiumGeoreference::ComputeEastSouthUpAtEarthCenteredEarthFixedPositionToUnrealTransformation ( const FVector & EarthCenteredEarthFixedPosition) const
The location is expressed as an Earth-Centered, Earth-Fixed (ECEF) position. To use an Unreal position instead, use ComputeUnrealToEastSouthUpTransformation.
In an East-South-Up frame, +X points East, +Y points South, and +Z points Up. However, the directions of "East", "South", and "Up" in Unreal or ECEF coordinates vary depending on where on the globe we are talking about. That is why this function takes a location, expressed in ECEF coordinates, that defines the origin of the East-South-Up frame of interest.
The resulting matrix should generally not be relative to the Unreal world, but rather be expressed in some parent Actor's reference frame as defined by its Transform. This way, the chain of Unreal transforms places and orients the "globe" in the Unreal world.
◆ ComputeEastSouthUpToUnrealTransformation()
FMatrix ACesiumGeoreference::ComputeEastSouthUpToUnrealTransformation ( const FVector & UnrealLocation) const
In an East-South-Up frame, +X points East, +Y points South, and +Z points Up. However, the directions of "East", "South", and "Up" in Unreal or ECEF coordinates vary depending on where on the globe we are talking about. That is why this function takes a location, expressed in Unreal coordinates, that defines the origin of the East-South-Up frame of interest.
The Unreal location and the resulting matrix should generally not be relative to the Unreal world, but rather be expressed in some parent Actor's reference frame as defined by its Transform. This way, the chain of Unreal transforms places and orients the "globe" in the Unreal world.
◆ ComputeUnrealToEarthCenteredEarthFixedTransformation()
FMatrix ACesiumGeoreference::ComputeUnrealToEarthCenteredEarthFixedTransformation ( ) const
◆ ComputeUnrealToEastSouthUpTransformation()
FMatrix ACesiumGeoreference::ComputeUnrealToEastSouthUpTransformation ( const FVector & UnrealLocation) const
The location is expressed in Unreal coordinates. To use an Earth-Centered, Earth-Fixed position instead, use ComputeEastSouthUpAtEarthCenteredEarthFixedPositionToUnrealTransformation.
◆ GetCoordinateSystem()
const CesiumGeospatial::LocalHorizontalCoordinateSystem & ACesiumGeoreference::GetCoordinateSystem ( ) const
inlinenoexcept
Definition at line 841 of file CesiumGeoreference.h.
◆ GetDefaultGeoreference()
static ACesiumGeoreference * ACesiumGeoreference::GetDefaultGeoreference ( const UObject * WorldContextObject)
static
It searches in the following order:
  1. A CesiumGeoreference that is tagged with "DEFAULT_GEOREFERENCE" and found in the PersistentLevel.
  2. A CesiumGeoreference with the name "CesiumGeoreferenceDefault" and found in the PersistentLevel.
  3. Any CesiumGeoreference in the PersistentLevel.
If no CesiumGeoreference is found with this search, a new one is created in the persistent level and given the "DEFAULT_GEOREFERENCE" tag.
◆ GetDefaultGeoreferenceForActor()
static ACesiumGeoreference * ACesiumGeoreference::GetDefaultGeoreferenceForActor ( AActor * Actor)
static
  1. A CesiumGeoreference that is an attachment parent of the given Actor.
  2. A CesiumGeoreference that is tagged with "DEFAULT_GEOREFERENCE" and found in the PersistentLevel.
  3. A CesiumGeoreference with the name "CesiumGeoreferenceDefault" and found in the PersistentLevel.
  4. Any CesiumGeoreference in the PersistentLevel.
◆ GetEllipsoid()
UCesiumEllipsoid * ACesiumGeoreference::GetEllipsoid ( ) const
◆ GetGeoTransforms()
GeoTransforms ACesiumGeoreference::GetGeoTransforms ( ) const
noexcept
◆ GetOriginEarthCenteredEarthFixed()
FVector ACesiumGeoreference::GetOriginEarthCenteredEarthFixed ( ) const
Only valid if the placement type is Cartographic Origin (i.e. Longitude / Latitude / Height).
◆ GetOriginHeight()
double ACesiumGeoreference::GetOriginHeight ( ) const
◆ GetOriginLatitude()
double ACesiumGeoreference::GetOriginLatitude ( ) const
◆ GetOriginLongitude()
double ACesiumGeoreference::GetOriginLongitude ( ) const
◆ GetOriginLongitudeLatitudeHeight()
FVector ACesiumGeoreference::GetOriginLongitudeLatitudeHeight ( ) const
◆ GetOriginPlacement()
EOriginPlacement ACesiumGeoreference::GetOriginPlacement ( ) const
3D Tiles tilesets often use Earth-centered, Earth-fixed coordinates, such that the tileset content is in a small bounding volume 6-7 million meters (the radius of the Earth) away from the coordinate system origin. This property allows an alternative position, other then the tileset's true origin, to be treated as the origin for the purpose of this Actor. Using this property will preserve vertex precision (and thus avoid jittering) much better than setting the Actor's Transform property.
◆ GetScale()
double ACesiumGeoreference::GetScale ( ) const
If this value is 50, for example, one meter on the globe occupies half a meter in the Unreal world.
◆ GetSubLevelCamera()
APlayerCameraManager * ACesiumGeoreference::GetSubLevelCamera ( ) const
◆ GetSubLevelSwitcher()
UCesiumSubLevelSwitcherComponent * ACesiumGeoreference::GetSubLevelSwitcher ( ) const
Definition at line 415 of file CesiumGeoreference.h.
◆ OnConstruction()
virtual void ACesiumGeoreference::OnConstruction ( const FTransform & Transform)
◆ PostLoad()
virtual void ACesiumGeoreference::PostLoad ( )
◆ Serialize()
virtual void ACesiumGeoreference::Serialize ( FArchive & Ar)
◆ SetEllipsoid()
void ACesiumGeoreference::SetEllipsoid ( UCesiumEllipsoid * NewEllipsoid)
Calling this will cause all tilesets under this georeference to be reloaded.
◆ SetOriginEarthCenteredEarthFixed()
void ACesiumGeoreference::SetOriginEarthCenteredEarthFixed ( const FVector & TargetEarthCenteredEarthFixed)
That is, it moves the globe so that these coordinates exactly fall on the origin. Only valid if the placement type is Cartographic Origin (i.e. Longitude / Latitude / Height). Note that if the provided ECEF coordiantes are near the center of the Earth so that Longitude, Latitude, and Height are undefined, this function will instead place the origin at 0 degrees longitude, 0 degrees latitude, and 0 meters height about the ellipsoid.
◆ SetOriginHeight()
void ACesiumGeoreference::SetOriginHeight ( double NewValue)
◆ SetOriginLatitude()
void ACesiumGeoreference::SetOriginLatitude ( double NewValue)
◆ SetOriginLongitude()
void ACesiumGeoreference::SetOriginLongitude ( double NewValue)
◆ SetOriginLongitudeLatitudeHeight()
void ACesiumGeoreference::SetOriginLongitudeLatitudeHeight ( const FVector & TargetLongitudeLatitudeHeight)
◆ SetOriginPlacement()
void ACesiumGeoreference::SetOriginPlacement ( EOriginPlacement NewValue)
◆ SetScale()
void ACesiumGeoreference::SetScale ( double NewValue)
◆ SetSubLevelCamera()
void ACesiumGeoreference::SetSubLevelCamera ( APlayerCameraManager * NewValue)
◆ ShouldTickIfViewportsOnly()
virtual bool ACesiumGeoreference::ShouldTickIfViewportsOnly ( ) const
◆ Tick()
virtual void ACesiumGeoreference::Tick ( float DeltaTime)
◆ TransformEarthCenteredEarthFixedDirectionToUnreal()
FVector ACesiumGeoreference::TransformEarthCenteredEarthFixedDirectionToUnreal ( const FVector & EarthCenteredEarthFixedDirection) const
The resulting direction vector should generally not be interpreted as an Unreal world vector, but rather a vector expressed in some parent Actor's reference frame as defined by its transform. This way, the chain of Unreal transforms places and orients the "globe" in the Unreal world.
◆ TransformEarthCenteredEarthFixedPositionToUnreal()
FVector ACesiumGeoreference::TransformEarthCenteredEarthFixedPositionToUnreal ( const FVector & EarthCenteredEarthFixedPosition) const
The resulting position should generally not be interpreted as an Unreal world position, but rather a position expressed in some parent Actor's reference frame as defined by its transform. This way, the chain of Unreal transforms places and orients the "globe" in the Unreal world.
◆ TransformEastSouthUpRotatorToUnreal()
FRotator ACesiumGeoreference::TransformEastSouthUpRotatorToUnreal ( const FRotator & EastSouthUpRotator,
const FVector & UnrealLocation ) const
The Unreal location and the resulting Rotator should generally not be relative to the Unreal world, but rather be expressed in some parent Actor's reference frame as defined by its Transform. This way, the chain of Unreal transforms places and orients the "globe" in the Unreal world.
◆ TransformLongitudeLatitudeHeightPositionToUnreal()
FVector ACesiumGeoreference::TransformLongitudeLatitudeHeightPositionToUnreal ( const FVector & LongitudeLatitudeHeight) const
◆ TransformUnrealDirectionToEarthCenteredEarthFixed()
FVector ACesiumGeoreference::TransformUnrealDirectionToEarthCenteredEarthFixed ( const FVector & UnrealDirection) const
The direction vector should generally not be an Unreal world vector, but rather a vector expressed in some parent Actor's reference frame as defined by its transform. This way, the chain of Unreal transforms places and orients the "globe" in the Unreal world.
◆ TransformUnrealPositionToEarthCenteredEarthFixed()
FVector ACesiumGeoreference::TransformUnrealPositionToEarthCenteredEarthFixed ( const FVector & UnrealPosition) const
The position should generally not be an Unreal world position, but rather a position expressed in some parent Actor's reference frame as defined by its transform. This way, the chain of Unreal transforms places and orients the "globe" in the Unreal world.
◆ TransformUnrealPositionToLongitudeLatitudeHeight()
FVector ACesiumGeoreference::TransformUnrealPositionToLongitudeLatitudeHeight ( const FVector & UnrealPosition) const
◆ TransformUnrealRotatorToEastSouthUp()
FRotator ACesiumGeoreference::TransformUnrealRotatorToEastSouthUp ( const FRotator & UnrealRotator,
◆ FCesiumGeoreferenceCustomization
friend class FCesiumGeoreferenceCustomization
friend
Definition at line 866 of file CesiumGeoreference.h.
◆ kMinimumScale
const double ACesiumGeoreference::kMinimumScale
static
Definition at line 55 of file CesiumGeoreference.h.
◆ OnEllipsoidChanged
FGeoreferenceEllipsoidChanged ACesiumGeoreference::OnEllipsoidChanged
Definition at line 106 of file CesiumGeoreference.h.
◆ OnGeoreferenceUpdated
FGeoreferenceUpdated ACesiumGeoreference::OnGeoreferenceUpdated
Definition at line 99 of file CesiumGeoreference.h.
