Cesium for Unreal 2.31.0
#include <CesiumEllipsoid.h>
| FVector | GetRadii () |
| Gets the radii of the ellipsoid in its x-, y-, and z-directions in meters. | |
| void | SetRadii (const FVector &NewRadii) |
| Sets the radii of this ellipsoid in its x-, y-, and z-directions in meters. | |
| double | GetMaximumRadius () |
| Gets the maximum radius of the ellipsoid in any dimension, in meters. | |
| double | GetMinimumRadius () |
| Gets the minimum radius of the ellipsoid in any dimension, in meters. | |
| FVector | ScaleToGeodeticSurface (const FVector &EarthCenteredEarthFixedPosition) |
| Scale the given Ellipsoid-Centered, Ellipsoid-Fixed position along the geodetic surface normal so that it is on the surface of the ellipsoid. | |
| FVector | GeodeticSurfaceNormal (const FVector &EarthCenteredEarthFixedPosition) |
| Computes the normal of the plane tangent to the surface of the ellipsoid at the provided Ellipsoid-Centered, Ellipsoid-Fixed position. | |
| FVector | LongitudeLatitudeHeightToEllipsoidCenteredEllipsoidFixed (const FVector &LongitudeLatitudeHeight) |
| Convert longitude in degrees (X), latitude in degrees (Y), and height above the ellipsoid in meters (Z) to Ellipsoid-Centered, Ellipsoid-Fixed (ECEF) coordinates. | |
| FVector | EllipsoidCenteredEllipsoidFixedToLongitudeLatitudeHeight (const FVector &EarthCenteredEarthFixedPosition) |
| Convert Ellipsoid-Centered, Ellipsoid-Fixed (ECEF) coordinates to longitude in degrees (X), latitude in degrees (Y), and height above the ellipsoid in meters (Z). | |
| FMatrix | EastNorthUpToEllipsoidCenteredEllipsoidFixed (const FVector &EarthCenteredEarthFixedPosition) |
| Computes the transformation matrix from the local East-North-Up (ENU) frame to Ellipsoid-Centered, Ellipsoid-Fixed (ECEF) at the specified ECEF location. | |
| CesiumGeospatial::LocalHorizontalCoordinateSystem | CreateCoordinateSystem (const FVector &Center, double Scale) |
Returns a new CesiumGeospatial::LocalHorizontalCoordinateSystem with the given scale, center, and ellipsoid. | |
| const CesiumGeospatial::Ellipsoid & | GetNativeEllipsoid () |
Returns the underlying CesiumGeospatial::Ellipsoid. | |
| static UCesiumEllipsoid * | Create (const FVector &Radii) |
Creates a new UCesiumEllipsoid with the given radii. | |
Protected Attributes | |
| FVector | Radii |
| The radii of this ellipsoid. | |
Definition at line 15 of file CesiumEllipsoid.h.
static |
This is equivalent to
| CesiumGeospatial::LocalHorizontalCoordinateSystem UCesiumEllipsoid::CreateCoordinateSystem | ( | const FVector & | Center, |
| double | Scale ) |
| FMatrix UCesiumEllipsoid::EastNorthUpToEllipsoidCenteredEllipsoidFixed | ( | const FVector & | EarthCenteredEarthFixedPosition | ) |
| FVector UCesiumEllipsoid::EllipsoidCenteredEllipsoidFixedToLongitudeLatitudeHeight | ( | const FVector & | EarthCenteredEarthFixedPosition | ) |
If the position is near the center of the Ellipsoid, the result will have the value (0,0,0) because the longitude, latitude, and height are undefined.
| FVector UCesiumEllipsoid::GeodeticSurfaceNormal | ( | const FVector & | EarthCenteredEarthFixedPosition | ) |
| double UCesiumEllipsoid::GetMaximumRadius | ( | ) |
| double UCesiumEllipsoid::GetMinimumRadius | ( | ) |
| const CesiumGeospatial::Ellipsoid & UCesiumEllipsoid::GetNativeEllipsoid | ( | ) |
| FVector UCesiumEllipsoid::GetRadii | ( | ) |
| FVector UCesiumEllipsoid::LongitudeLatitudeHeightToEllipsoidCenteredEllipsoidFixed | ( | const FVector & | LongitudeLatitudeHeight | ) |
| FVector UCesiumEllipsoid::ScaleToGeodeticSurface | ( | const FVector & | EarthCenteredEarthFixedPosition | ) |
If the position is near the center of the ellipsoid, the result will have the value (0,0,0) because the surface position is undefined.
| void UCesiumEllipsoid::SetRadii | ( | const FVector & | NewRadii | ) |
Tilesets using this ellipsoid may have to be refreshed to see the changes applied.
protected |
The X coordinate of the vector should be the radius of the largest axis and the Z coordinate should be the radius of the smallest axis.
Definition at line 139 of file CesiumEllipsoid.h.
