CesiumPropertyTexture.h
7#include "Containers/Array.h"
8#include "Kismet/BlueprintFunctionLibrary.h"
9#include "Kismet/GameplayStatics.h"
10
11#include <CesiumGltf/PropertyTextureView.h>
12
13#include "CesiumPropertyTexture.generated.h"
14
15namespace CesiumGltf {
16struct Model;
17struct PropertyTexture;
18}; // namespace CesiumGltf
19
20UENUM(BlueprintType)
21enum class ECesiumPropertyTextureStatus : uint8 {
22 /* The property texture is valid. */
23 Valid = 0,
24 /* The property texture instance was not initialized from an actual glTF
25 property texture. */
27 /* The property texture's class could not be found in the schema of the
28 metadata extension. */
30};
31
32/**
33 * @brief A blueprint-accessible wrapper of a property texture from a glTF.
34 * Provides access to {@link FCesiumPropertyTextureProperty} views of texture
35 * metadata.
36 */
37USTRUCT(BlueprintType)
38struct CESIUMRUNTIME_API FCesiumPropertyTexture {
39 GENERATED_USTRUCT_BODY()
40
41public:
42 /**
43 * Construct an empty property texture instance.
44 */
47
48 /**
49 * Constructs a property texture from the given glTF.
50 *
51 * @param model The model that stores EXT_structural_metadata.
52 * @param propertyTexture The target property texture.
53 */
55 const CesiumGltf::Model& model,
56 const CesiumGltf::PropertyTexture& propertyTexture)
58 model,
59 propertyTexture,
60 FCesiumMetadataEnumCollection::GetOrCreateFromModel(model)) {}
61
62 /**
63 * Constructs a property texture from the given glTF.
64 *
65 * @param model The model that stores EXT_structural_metadata.
66 * @param propertyTexture The target property texture.
67 * @param pEnumCollection The enum collection to use, if any.
68 */
70 const CesiumGltf::Model& model,
71 const CesiumGltf::PropertyTexture& propertyTexture,
72 const TSharedPtr<FCesiumMetadataEnumCollection>& pEnumCollection);
73
74 /**
75 * Gets the name of the metadata class that this property table conforms to.
76 */
77 FString getClassName() const { return _className; }
78
79private:
81 FString _name;
82 FString _className;
83
84 TMap<FString, FCesiumPropertyTextureProperty> _properties;
85
87};
88
89UCLASS()
91 : public UBlueprintFunctionLibrary {
92 GENERATED_BODY()
93
94public:
95 /**
96 * Gets the status of the property texture. If the property texture is invalid
97 * in any way, this briefly indicates why.
98 *
99 * @param PropertyTexture The property texture.
100 */
101 UFUNCTION(
102 BlueprintCallable,
103 BlueprintPure,
104 Category = "Cesium|Metadata|PropertyTexture")
107 const FCesiumPropertyTexture& PropertyTexture);
108
109 /**
110 * Gets the name of the property texture.
111 *
112 * @param PropertyTexture The property texture.
113 */
114 UFUNCTION(
115 BlueprintCallable,
116 BlueprintPure,
117 Category = "Cesium|Metadata|PropertyTexture")
118 static const FString&
120 const FCesiumPropertyTexture& PropertyTexture);
121
122 /**
123 * Gets all the properties of the property texture, mapped by property name.
124 *
125 * @param PropertyTexture The property texture.
126 */
127 UFUNCTION(
128 BlueprintCallable,
129 BlueprintPure,
130 Category = "Cesium|Metadata|PropertyTexture")
131 static const TMap<FString, FCesiumPropertyTextureProperty>
132 GetProperties(UPARAM(ref) const FCesiumPropertyTexture& PropertyTexture);
133
134 /**
135 * Gets the names of the properties in this property texture. If the property
136 * texture is invalid, this returns an empty array.
137 *
138 * @param PropertyTexture The property texture.
139 */
140 UFUNCTION(
141 BlueprintCallable,
142 BlueprintPure,
143 Category = "Cesium|Metadata|PropertyTexture")
144 static const TArray<FString>
145 GetPropertyNames(UPARAM(ref) const FCesiumPropertyTexture& PropertyTexture);
146
147 /**
148 * Retrieve a FCesiumPropertyTextureProperty by name. If the property texture
149 * does not contain a property with that name, this returns an invalid
150 * FCesiumPropertyTextureProperty.
151 *
152 * @param PropertyTexture The property texture.
153 * @param PropertyName The name of the property to find.
154 */
155 UFUNCTION(
156 BlueprintCallable,
157 BlueprintPure,
158 Category = "Cesium|Metadata|PropertyTexture")
160 UPARAM(ref) const FCesiumPropertyTexture& PropertyTexture,
161 const FString& PropertyName);
162
163 /**
164 * Gets all of the property values at the given texture coordinates, mapped by
165 * property name. This will only include values from valid property texture
166 * properties.
167 *
168 * In EXT_structural_metadata, individual properties can specify different
169 * texture coordinate sets to be sampled from. This method uses the same
170 * coordinates to sample each property, regardless of its intended texture
171 * coordinate set. Use GetMetadataValuesForHit instead to sample the property
172 * texture's properties with their respective texture coordinate sets.
173 *
174 * @param PropertyTexture The property texture.
175 * @param UV The texture coordinates.
176 * @return The property values mapped by property name.
177 */
178 UFUNCTION(
179 BlueprintCallable,
180 BlueprintPure,
181 Category = "Cesium|Metadata|PropertyTexture")
183 UPARAM(ref) const FCesiumPropertyTexture& PropertyTexture,
184 const FVector2D& UV);
185
186 /**
187 * Given a trace hit result, gets all of the property values from property
188 * texture on the hit component, mapped by property name. This will only
189 * include values from valid property texture properties.
190 *
191 * In EXT_structural_metadata, individual properties can specify different
192 * texture coordinate sets to be sampled from. This method uses the
193 * corresponding texture coordinate sets to sample each property.
194 *
195 * @param PropertyTexture The property texture.
196 * @param Hit The trace hit result
197 * @return The property values mapped by property name.
198 */
199 UFUNCTION(
200 BlueprintCallable,
201 BlueprintPure,
202 Category = "Cesium|Metadata|PropertyTexture")
204 UPARAM(ref) const FCesiumPropertyTexture& PropertyTexture,
205 const FHitResult& Hit);
206};
static const ECesiumPropertyTextureStatus GetPropertyTextureStatus(UPARAM(ref) const FCesiumPropertyTexture &PropertyTexture)
static TMap< FString, FCesiumMetadataValue > GetMetadataValuesFromHit(UPARAM(ref) const FCesiumPropertyTexture &PropertyTexture, const FHitResult &Hit)
Given a trace hit result, gets all of the property values from property texture on the hit component,...
static const FString & GetPropertyTextureName(UPARAM(ref) const FCesiumPropertyTexture &PropertyTexture)
static const FCesiumPropertyTextureProperty & FindProperty(UPARAM(ref) const FCesiumPropertyTexture &PropertyTexture, const FString &PropertyName)
static const TMap< FString, FCesiumPropertyTextureProperty > GetProperties(UPARAM(ref) const FCesiumPropertyTexture &PropertyTexture)
static TMap< FString, FCesiumMetadataValue > GetMetadataValuesForUV(UPARAM(ref) const FCesiumPropertyTexture &PropertyTexture, const FVector2D &UV)
Gets all of the property values at the given texture coordinates, mapped by property name.
static const TArray< FString > GetPropertyNames(UPARAM(ref) const FCesiumPropertyTexture &PropertyTexture)
Contains a set of enum definitions obtained from a CesiumGltf::Schema.
A blueprint-accessible wrapper for a property texture property from a glTF.
FCesiumPropertyTexture(const CesiumGltf::Model &model, const CesiumGltf::PropertyTexture &propertyTexture, const TSharedPtr< FCesiumMetadataEnumCollection > &pEnumCollection)
FCesiumPropertyTexture()
FCesiumPropertyTexture(const CesiumGltf::Model &model, const CesiumGltf::PropertyTexture &propertyTexture)
friend class UCesiumPropertyTextureBlueprintLibrary
