Properties conforming to a class, organized as property values stored in textures. More...
#include <CesiumGltf/PropertyTexture.h>
| The name of the property texture, e.g. for display purposes. | |
| std::string | classProperty |
The class that property values conform to. The value must be a class ID declared in the classes dictionary. | |
| std::unordered_map< std::string, CesiumGltf::PropertyTextureProperty > | properties |
A dictionary, where each key corresponds to a property ID in the class' properties dictionary and each value is an object describing where property values are stored. Required properties must be included in this dictionary. | |
| static constexpr const char * | TypeName = "PropertyTexture" |
Definition at line 18 of file PropertyTexture.h.
Definition at line 51 of file PropertyTexture.h.
| std::string CesiumGltf::PropertyTexture::classProperty |
Definition at line 34 of file PropertyTexture.h.
| std::optional<std::string> CesiumGltf::PropertyTexture::name |
Definition at line 28 of file PropertyTexture.h.
| std::unordered_map<std::string, CesiumGltf::PropertyTextureProperty> CesiumGltf::PropertyTexture::properties |
Definition at line 43 of file PropertyTexture.h.
Definition at line 23 of file PropertyTexture.h.
