UCesiumPropertyTextureBlueprintLibrary Class Reference
#include <CesiumPropertyTexture.h>
Inheritance diagram for UCesiumPropertyTextureBlueprintLibrary:
static const ECesiumPropertyTextureStatus GetPropertyTextureStatus (UPARAM(ref) const FCesiumPropertyTexture &PropertyTexture)
 Gets the status of the property texture.
static const FString & GetPropertyTextureName (UPARAM(ref) const FCesiumPropertyTexture &PropertyTexture)
 Gets the name of the property texture.
static const TMap< FString, FCesiumPropertyTextureProperty > GetProperties (UPARAM(ref) const FCesiumPropertyTexture &PropertyTexture)
 Gets all the properties of the property texture, mapped by property name.
static const TArray< FString > GetPropertyNames (UPARAM(ref) const FCesiumPropertyTexture &PropertyTexture)
 Gets the names of the properties in this property texture.
static const FCesiumPropertyTextureProperty & FindProperty (UPARAM(ref) const FCesiumPropertyTexture &PropertyTexture, const FString &PropertyName)
 Retrieve a FCesiumPropertyTextureProperty by name.
static TMap< FString, FCesiumMetadataValue > GetMetadataValuesForUV (UPARAM(ref) const FCesiumPropertyTexture &PropertyTexture, const FVector2D &UV)
 Gets all of the property values at the given texture coordinates, mapped by property name.
static TMap< FString, FCesiumMetadataValue > GetMetadataValuesFromHit (UPARAM(ref) const FCesiumPropertyTexture &PropertyTexture, const FHitResult &Hit)
 Given a trace hit result, gets all of the property values from property texture on the hit component, mapped by property name.
Definition at line 90 of file CesiumPropertyTexture.h.
◆ FindProperty()
static const FCesiumPropertyTextureProperty & UCesiumPropertyTextureBlueprintLibrary::FindProperty ( UPARAM(ref) const FCesiumPropertyTexture & PropertyTexture,
const FString & PropertyName )
static
If the property texture does not contain a property with that name, this returns an invalid FCesiumPropertyTextureProperty.
PropertyTextureThe property texture.
PropertyNameThe name of the property to find.
◆ GetMetadataValuesForUV()
static TMap< FString, FCesiumMetadataValue > UCesiumPropertyTextureBlueprintLibrary::GetMetadataValuesForUV ( UPARAM(ref) const FCesiumPropertyTexture & PropertyTexture,
const FVector2D & UV )
static
This will only include values from valid property texture properties.
In EXT_structural_metadata, individual properties can specify different texture coordinate sets to be sampled from. This method uses the same coordinates to sample each property, regardless of its intended texture coordinate set. Use GetMetadataValuesForHit instead to sample the property texture's properties with their respective texture coordinate sets.
UVThe texture coordinates.
The property values mapped by property name.
◆ GetMetadataValuesFromHit()
static TMap< FString, FCesiumMetadataValue > UCesiumPropertyTextureBlueprintLibrary::GetMetadataValuesFromHit ( UPARAM(ref) const FCesiumPropertyTexture & PropertyTexture,
const FHitResult & Hit )
static
In EXT_structural_metadata, individual properties can specify different texture coordinate sets to be sampled from. This method uses the corresponding texture coordinate sets to sample each property.
HitThe trace hit result
◆ GetProperties()
static const TMap< FString, FCesiumPropertyTextureProperty > UCesiumPropertyTextureBlueprintLibrary::GetProperties ( UPARAM(ref) const FCesiumPropertyTexture & PropertyTexture)
static
◆ GetPropertyNames()
static const TArray< FString > UCesiumPropertyTextureBlueprintLibrary::GetPropertyNames ( UPARAM(ref) const FCesiumPropertyTexture & PropertyTexture)
static
If the property texture is invalid, this returns an empty array.
◆ GetPropertyTextureName()
static const FString & UCesiumPropertyTextureBlueprintLibrary::GetPropertyTextureName ( UPARAM(ref) const FCesiumPropertyTexture & PropertyTexture)
static
◆ GetPropertyTextureStatus()
static const ECesiumPropertyTextureStatus UCesiumPropertyTextureBlueprintLibrary::GetPropertyTextureStatus ( UPARAM(ref) const FCesiumPropertyTexture & PropertyTexture)
static
If the property texture is invalid in any way, this briefly indicates why.
