cesium-native 0.67.0
A quantized-mesh terrain layer.json. More...
#include <CesiumQuantizedMeshTerrain/Layer.h>
| std::optional< CesiumGeospatial::Projection > | getProjection (const CesiumGeospatial::Ellipsoid &ellipsoid=CesiumGeospatial::Ellipsoid::WGS84) const noexcept |
| Gets the projection specified by this layer.json. | |
| std::optional< CesiumGeometry::QuadtreeTilingScheme > | getTilingScheme (const CesiumGeospatial::Ellipsoid &ellipsoid=CesiumGeospatial::Ellipsoid::WGS84) const noexcept |
| Gets the tiling scheme specified by this layer.json. | |
| std::optional< CesiumGeospatial::BoundingRegion > | getRootBoundingRegion (const CesiumGeospatial::Ellipsoid &ellipsoid=CesiumGeospatial::Ellipsoid::WGS84) const noexcept |
| Gets the bounding region for the root tile. | |
Public Member Functions inherited from CesiumQuantizedMeshTerrain::LayerSpec | |
Public Attributes inherited from CesiumQuantizedMeshTerrain::LayerSpec | |
| std::string | attribution |
| The attribution (credit) string for the terrain. | |
| std::vector< std::vector< CesiumQuantizedMeshTerrain::AvailabilityRectangle > > | available |
| The tile availability information. The outer array is indexed by tile level. The inner array is a list of rectangles of availability at that level. Tiles themselves may also contain further availability information for their subtree. | |
| std::vector< double > | bounds = {-180, -90, 180, 90} |
| The bounding box of the terrain, expressed as west, south, east, north in degrees. | |
| std::string | description |
| The description of this terrain tileset. | |
| std::vector< std::string > | extensionsProperty |
| The extensions available for this tileset. | |
| std::string | format = "quantized-mesh-1.0" |
The format of the terrain tiles. Should be "quantized-mesh-1.0". | |
| int64_t | maxzoom = int64_t() |
| The maximum level for which there are any available tiles. | |
| int64_t | minzoom = 0 |
| The minimum level for which there are any available tiles. | |
| std::optional< int64_t > | metadataAvailability |
| The levels at which metadata is found in tiles. For example, if this value is 10, then metadata is found at levels 0, 10, 20, etc. | |
| std::string | name = "Terrain" |
| The name of this terrain tileset. | |
| std::optional< std::string > | parentUrl |
| The URL of the parent layer.json that this one is layered on top of. | |
| std::string | projection = "EPSG:4326" |
The map projection of this tileset. Valid values are "EPSG:4326" and "EPSG:3857". | |
| std::string | scheme = "tms" |
The tiling scheme. The only valid value is "tms". | |
| std::vector< std::string > | tiles |
| The URL templates from which to obtain tiles. | |
| std::string | version = "1.0.0" |
| The version of this tileset. | |
Static Public Attributes inherited from CesiumQuantizedMeshTerrain::LayerSpec | |
| static constexpr const char * | TypeName = "Layer" |
Protected Member Functions inherited from CesiumQuantizedMeshTerrain::LayerSpec | |
| LayerSpec ()=default | |
| This class is not meant to be instantiated directly. Use Layer instead. | |
noexcept |
noexcept |
The rectangle will be the maximum rectangle for the terrain's projection (geographic or web mercator). The heights will range from -1000.0 to 9000.0.
noexcept |
