CesiumQuantizedMeshTerrain::LayerSpec Struct Reference
A quantized-mesh terrain layer.json. More...
#include <CesiumQuantizedMeshTerrain/LayerSpec.h>
Inheritance diagram for CesiumQuantizedMeshTerrain::LayerSpec:
CesiumUtility::ExtensibleObject CesiumQuantizedMeshTerrain::Layer
std::string attribution
 The attribution (credit) string for the terrain.
std::vector< std::vector< CesiumQuantizedMeshTerrain::AvailabilityRectangle > > available
 The tile availability information. The outer array is indexed by tile level. The inner array is a list of rectangles of availability at that level. Tiles themselves may also contain further availability information for their subtree.
std::vector< double > bounds = {-180, -90, 180, 90}
 The bounding box of the terrain, expressed as west, south, east, north in degrees.
std::string description
 The description of this terrain tileset.
std::vector< std::string > extensionsProperty
 The extensions available for this tileset.
std::string format = "quantized-mesh-1.0"
 The format of the terrain tiles. Should be "quantized-mesh-1.0".
int64_t maxzoom = int64_t()
 The maximum level for which there are any available tiles.
int64_t minzoom = 0
 The minimum level for which there are any available tiles.
std::optional< int64_t > metadataAvailability
 The levels at which metadata is found in tiles. For example, if this value is 10, then metadata is found at levels 0, 10, 20, etc.
std::string name = "Terrain"
 The name of this terrain tileset.
std::optional< std::string > parentUrl
 The URL of the parent layer.json that this one is layered on top of.
std::string projection = "EPSG:4326"
 The map projection of this tileset. Valid values are "EPSG:4326" and "EPSG:3857".
std::string scheme = "tms"
 The tiling scheme. The only valid value is "tms".
std::vector< std::string > tiles
 The URL templates from which to obtain tiles.
std::string version = "1.0.0"
 The version of this tileset.
static constexpr const char * TypeName = "Layer"
Protected Member Functions
 LayerSpec ()=default
 This class is not meant to be instantiated directly. Use Layer instead.
Friends
struct Layer
Definition at line 18 of file LayerSpec.h.
int64_t CesiumQuantizedMeshTerrain::LayerSpec::getSizeBytes ( ) const
Definition at line 113 of file LayerSpec.h.
◆ Layer
friend struct Layer
friend
Definition at line 155 of file LayerSpec.h.
◆ attribution
std::string CesiumQuantizedMeshTerrain::LayerSpec::attribution
Definition at line 28 of file LayerSpec.h.
◆ available
std::vector<std::vector<CesiumQuantizedMeshTerrain::AvailabilityRectangle> > CesiumQuantizedMeshTerrain::LayerSpec::available
Definition at line 37 of file LayerSpec.h.
◆ bounds
std::vector<double> CesiumQuantizedMeshTerrain::LayerSpec::bounds = {-180, -90, 180, 90}
Definition at line 43 of file LayerSpec.h.
◆ description
std::string CesiumQuantizedMeshTerrain::LayerSpec::description
Definition at line 48 of file LayerSpec.h.
◆ extensionsProperty
std::vector<std::string> CesiumQuantizedMeshTerrain::LayerSpec::extensionsProperty
Definition at line 53 of file LayerSpec.h.
◆ format
std::string CesiumQuantizedMeshTerrain::LayerSpec::format = "quantized-mesh-1.0"
Definition at line 58 of file LayerSpec.h.
◆ maxzoom
int64_t CesiumQuantizedMeshTerrain::LayerSpec::maxzoom = int64_t()
Definition at line 63 of file LayerSpec.h.
◆ metadataAvailability
std::optional<int64_t> CesiumQuantizedMeshTerrain::LayerSpec::metadataAvailability
Definition at line 74 of file LayerSpec.h.
◆ minzoom
int64_t CesiumQuantizedMeshTerrain::LayerSpec::minzoom = 0
Definition at line 68 of file LayerSpec.h.
◆ name
std::string CesiumQuantizedMeshTerrain::LayerSpec::name = "Terrain"
Definition at line 79 of file LayerSpec.h.
◆ parentUrl
std::optional<std::string> CesiumQuantizedMeshTerrain::LayerSpec::parentUrl
Definition at line 84 of file LayerSpec.h.
◆ projection
std::string CesiumQuantizedMeshTerrain::LayerSpec::projection = "EPSG:4326"
Definition at line 90 of file LayerSpec.h.
◆ scheme
std::string CesiumQuantizedMeshTerrain::LayerSpec::scheme = "tms"
Definition at line 95 of file LayerSpec.h.
◆ tiles
std::vector<std::string> CesiumQuantizedMeshTerrain::LayerSpec::tiles
Definition at line 100 of file LayerSpec.h.
const char* CesiumQuantizedMeshTerrain::LayerSpec::TypeName = "Layer"
Definition at line 23 of file LayerSpec.h.
◆ version
std::string CesiumQuantizedMeshTerrain::LayerSpec::version = "1.0.0"
Definition at line 105 of file LayerSpec.h.
