cesium-native 0.67.0
A rectangle of tile availability. More...
#include <CesiumQuantizedMeshTerrain/AvailabilityRectangle.h>
| int64_t | startX = int64_t() |
| The index of the start tile in the X direction. | |
| int64_t | startY = int64_t() |
| The index of the start tile in the Y direction. | |
| int64_t | endX = int64_t() |
| The index of the end tile in the X direction. | |
| int64_t | endY = int64_t() |
| The index of the end tile in the Y direction. | |
| static constexpr const char * | TypeName = "AvailabilityRectangle" |
Definition at line 14 of file AvailabilityRectangle.h.
Definition at line 47 of file AvailabilityRectangle.h.
| int64_t CesiumQuantizedMeshTerrain::AvailabilityRectangle::endX = int64_t() |
Definition at line 34 of file AvailabilityRectangle.h.
| int64_t CesiumQuantizedMeshTerrain::AvailabilityRectangle::endY = int64_t() |
Definition at line 39 of file AvailabilityRectangle.h.
| int64_t CesiumQuantizedMeshTerrain::AvailabilityRectangle::startX = int64_t() |
Definition at line 24 of file AvailabilityRectangle.h.
| int64_t CesiumQuantizedMeshTerrain::AvailabilityRectangle::startY = int64_t() |
Definition at line 29 of file AvailabilityRectangle.h.
Definition at line 19 of file AvailabilityRectangle.h.
