CesiumQuantizedMeshTerrain Namespace Reference
Classes for accessing terrain based on layer.json and quantized-mesh-1.0. More...
Classes
struct  AvailabilityRectangle
 A rectangle of tile availability. More...
class  AvailabilityRectangleReader
 Reads AvailabilityRectangle instances from JSON. More...
struct  Layer
 A quantized-mesh terrain layer.json. More...
class  LayerReader
 Reads Layer instances from JSON. More...
struct  LayerSpec
class  LayerWriter
 Writes layer.json. More...
struct  LayerWriterOptions
 Options for how to write a layer.json. More...
struct  LayerWriterResult
 The result of writing a layer.json with LayerWriter::write. More...
class  QuantizedMeshLoader
 Loads quantized-mesh-1.0 terrain data. More...
struct  QuantizedMeshLoadResult
 The results of a QuantizedMeshLoader::load operation, containing either the loaded model, an improved bounding region for the tile, and available quadtree tiles discovered, if the load succeeded - or the request made and the errors that were returned, if the load failed. More...
struct  QuantizedMeshMetadataResult
 The metadata of a Quantized Mesh tile, returned by QuantizedMeshLoader::loadMetadata. More...
--- comment: This file was generated by dep-graph-gen. DO NOT EDIT THIS FILE! title: CesiumQuantizedMeshTerrain Dependency Graph --- graph TD classDef dependencyNode fill:#fff,stroke:#ccc,color:#666,font-weight:bold,font-size:28px classDef libraryNode fill:#9f9,font-weight:bold,font-size:28px CesiumQuantizedMeshTerrain[CesiumQuantizedMeshTerrain] --> CesiumAsync[CesiumAsync] CesiumQuantizedMeshTerrain[CesiumQuantizedMeshTerrain] --> CesiumGeospatial[CesiumGeospatial] CesiumQuantizedMeshTerrain[CesiumQuantizedMeshTerrain] --> CesiumGltf[CesiumGltf] CesiumQuantizedMeshTerrain[CesiumQuantizedMeshTerrain] --> CesiumGltfContent[CesiumGltfContent] CesiumQuantizedMeshTerrain[CesiumQuantizedMeshTerrain] --> CesiumJsonReader[CesiumJsonReader] CesiumQuantizedMeshTerrain[CesiumQuantizedMeshTerrain] --> CesiumJsonWriter[CesiumJsonWriter] CesiumQuantizedMeshTerrain[CesiumQuantizedMeshTerrain] --> CesiumUtility[CesiumUtility] class CesiumAsync,CesiumGeospatial,CesiumGltf,CesiumGltfContent,CesiumJsonReader,CesiumJsonWriter,CesiumUtility,CesiumQuantizedMeshTerrain libraryNode
